 Old 09-05-2011, 06:57 PM   #1
IMASA's Avatar
Posts: 209   (View Stats)
Default Clicking from clutch pedal
When I'm driving at very slow speeds (ie reversing from my garage, pulling into a parking spot) and feathering the clutch, I can hear a pop sound and I feel a little click coming from the clutch pedal. This only happens when I'm feathering the clutch and the steering wheel is cranked, ie for parking purposes. It doesn't happen when driving normally or if I'm feathering the clutch but driving straight.
Any ideas? I've bled my clutch fluid but it's the pop is still there. I've checked around the driver side suspension and all looks normal.
 Old 09-05-2011, 07:04 PM   #2
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Do you have a trans mount?
 Old 09-05-2011, 07:33 PM   #3
IMASA's Avatar
Nope, only a CP-E RMM.
 Old 09-05-2011, 09:42 PM   #4
08.5MS3's Avatar
Groans: 89
I was on my phone earlier and couldn't see your signature. The reason I asked, both I and another member on here have the TRZ transmission mount and while in reverse, when we depress the clutch pedal, we hear two noticeable clicks coming from the clutch area. Again, it only happens in reverse and is more noticeable depending on how fast we are going in reverse...
Wow FML my clutch pedal broke!!! thabigo MazdaSpeed 3 - Engine, Transmission & Driveline 12 03-28-2010 08:41 PM
Clutch Pedal Stop banzairx7 MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-21-2010 05:56 PM
Clutch pedal vibration Overboost3 MazdaSpeed 3 - Engine, Transmission & Driveline 59 04-13-2009 02:48 AM
Clutch pedal to floor. Darksun280 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 11 06-10-2008 08:14 AM
Page generated in 0.23919 seconds with 21 queries
