  • 1 Post By laxplayermjd
  • 1 Post By MSFer87
 Old 06-13-2011, 08:14 PM   #1
laxplayermjd's Avatar
Posts: 779   (View Stats)
Default Clutchmasters Review
I have a 07 speed 6. My oem clutch failed the other day at 28k miles. Piece of crap. This seemed to be a pressure plate failure which made me slip it bad when i went wot. Before the you cant drive posts, i bought the car with 10k miles and it was reported stolen during that time so take it as you will.
I ve attached some pics of the stock parts, look pretty bad. The flywheel is toast and had a ton of lateral movement or i was going to resurface it.
Removal wasnt so bad at first. Had it just about out in 2 hrs. Me and my buddy both master techs for bmw. Turns out there is three sneaky bolts on the back side of the trans under the transfer case and downpipe. Getting these out took another hour. Also note the transmission is pretty heavy.
I have to say anyone in the marker for a clutch definitely look at stefan from tech/sales@em. Top notch customer service. Ive emailed back and forth for almost a week trying to make a decision on what clutch to buy. He was very knowledgable and very quick with responses. He also bought my used oem clutch disc.
Tech/sales@em Has quite a few options for you to consider. I ended up ordering the clutchmasters stg1 fx100 kit, organic disc good for 390ft/lbs. Hope to have it installed fri night or sunday morning. I will post a through review as im the first one to get this kit.
If anyone wants a brief how to i can summarize it, but i dont recommend the avg diy doing it. But for what the repair wouldve cost at the dealer id try it anyway.
UPDATE 1........
Here is a short video of the clutchmasters fx100 kit. I have the radio off, ac on. Inside the car you can hear minimal "gear rattle". This is due to the deletion of the factory dual mass flywheel. When moving the camera outside the car you can hear it rather loudly.
I placed the camera on the ground then turned off the ac, rattle drops dramtically and can rarely be heard inside the vehicle with windows up.
During driving you can hear some rattle at times. Its minimal enough that most people may never notice it. With radio at moderate volume you may never hear most of the rattle.
This was a alot noisier than expected. I also have some amsoil fluid to change out to, may or may not make any difference as its the same weight oil.
Im not sure if the cp-e rmm makes the vibs worse and contributes to the rattle.
I have 450 miles on the clutch so far going to update more shortly.....
UPDATE 2
i have about 700 miles on the clutch. First install wasnt great, this clutch is bigger than oem. I was told its about 1/2 inch bigger. When installed the pressure plate actually rubbed on some ridges inside the transmission bell housing. I have to take a grinder around the inside of the bellhousing to clear the pressure plate. I was told cutchmasters is going to be fixing this issue by taking a couple of mm off the pressure plate so it clears the trans with no grinding.
Intial impressions... damn this pedal is stiff as shit. I was expecting stiff than stock, but ended up being much more than i expected. This may be an exaggeration but it seemed almost twice as hard. Now after driving it ive gotten used to it alot and daily driving is find. However i find my self not trying to hold the pedal at a red light any longer than needed. I know a traffic jam will make me rather angry with a tired clutch leg.
I recommend anyone that has any doubt in not liking a stiff pedal for daily driving to not buy this clutch. Stick with O.E. pressure plate.
First driving i noticed a bit of a shudder when taking off from a stop only. Its dissipated mostly. Doesnt do it all the time now, not sure if its my driving style or a combination with the lightweight flywheel set up. Taking off quickly there is not a shudder.... This is my 5th vehicle all of which were manual trans, so take that whats it worth.
Single most thing im annoyed with is how noisy the setup is. Worst with ac compressor running but i can notice it with the windows down and in gear at times.
Rev matching for downshifting is effortless now. Shifting hard clutch grabs real good being organic. The slam that was there with stock setup is no longer there, since its not dual mass and lighter now. I weighed my o.e. setup vs the cm kit. It was a total of 29lbs vs 42 lbs.
To sum it up, if i had to do it again im not sure if id buy a lightweight flywheel again. But i doubt i have any issues with this clutch setup ever slipping.Im sure it will probably hold up rather well and it cost me way less than oe setup.
crazyp likes this.
laxplayermjd is offline   Reply With Quote
The Following 12 Users Say Thank You to laxplayermjd For This Useful Post:
801MS3 (06-14-2012), Alpha (06-24-2011), Burdoror (07-04-2011), crazyp (06-13-2011), djuosnteisn (07-05-2011), helmetface (06-11-2012), Metal409 (06-13-2011), paveltol (07-11-2011), SJP0tato (07-19-2011), speedms6 (06-13-2011), Tomas (07-02-2011), wette460 (07-19-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/clutch-failure-clutchmaster-review-83339/
VersaTune - View topic - clutch kit input This thread Refback 05-29-2015 12:28 PM
VersaTune ? View topic - clutch kit input This thread Refback 05-07-2014 10:02 PM
Forum Mazda Performance Series - Zobacz temat - Sprz?g?o + Dwumasa. Czyli jakie mamy opcje :) This thread Refback 05-28-2013 03:58 PM
VersaTune • View topic - clutch kit input This thread Refback 07-06-2011 02:44 PM
Forum Mazda Performance Series - Zobacz temat - [3BK 6GG] - sprzeglo - jakie zamienniki? This thread Refback 07-05-2011 02:48 AM
3rd VVT Failure JumpingJackson MazdaSpeed 3 - Engine, Transmission & Driveline 41 06-22-2011 11:12 AM
Failure Dave092 Mazdaspeed3/6 General Discussion 18 05-06-2011 09:24 AM
clutch vibration at top of clutch PLEASE HELP livetoskate06 MazdaSpeed 3 - Engine, Transmission & Driveline 84 03-06-2010 06:53 PM
ACT Clutch Review socks MazdaSpeed 3 - Engine, Transmission & Driveline 42 05-12-2009 11:54 AM
WTF do I have to do to fix my RMM after PMM failure. Adam is so pro MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-18-2009 08:23 PM
Page generated in 0.43195 seconds with 29 queries
