| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score 112,000 km (70,000 miles) on the clock and I've discovered clutch slippage in 3rd, 4th, 5th, and most likely 6th. I know it's the clutch because of the smell under the hood. I'm running 19 psi tapered to 17, with 16 degrees at 6K rpm. So roughly 280 whp and 300 wtq. Since I am on stock block, I don't plan on going higher that 320 wtq. But, I do plan on making more horsepower at higher rpm's when I get a BNR S4, Maybe around 340-350 whp up top. I want a clutch that has the longevity of the OEM, but without slippage that comes with more power as it wears out. I have read that the OEM clutch, when new, can handle quite a bit. But as it wears out it starts to slip. Here are the options I've been looking at: 1) OEM clutch kit with fidanza flywheel. 2) ACT heavy duty street clutch kit with prolite flywheel. 3) ACT heavy duty 6 puck clutch kit with prolite flywheel. These are all within my budget, and like I said 320 wtq and maybe 350 whp with a BNR S4 are my eventual goals for the street, with the stock block. Thanks for any help!
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) |
| Not Ranked : 0 score FWIW, you can do those power numbers on the luk/fidanza combo. Heck, you can do em with the BNRs3 for that matter, tho it would be easier with the s4 for sure. I've been daily driving more power for over 26,000 miles on my luk/fidanza combo. That said, if you're often launching hard- drag strip, mexico, whatever, you'd be better served with something stronger than the factory clutch with a lighter fw. I drive aggressively, but don't really put the hard launch on it all that often. When I do tho, the LC is set to 4750 with AWD.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | BuddySpeed3 (04-10-2016) |
(Thread Starter) | Not Ranked : 0 score I will most likely end up going with the ACT street clutch kit.
(Thread Starter) | Not Ranked : 0 score Hey everyone, I still haven't decided what clutch setup to go with. I did some more reading and found that with aftermarket clutches, the clutch slave cylinder can leak from the added strength of the pressure plate fingers, which is why I started to lean towards the Oem clutch / fidanza flywheel combo. I just have a few questions: 1 - If my car currently has the aluminum housed clutch slave cylinder, will I be OK with a stage 1 ACT clutch kit, or are there other things that require replacement? 2 - Is the ACT stage 1 clutch kit reliable? 3 - If I go with the ACT kit, should I go with the street lite, or pro lite flywheel? Thank you!
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score 6 puc or South bend 3 endurance
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() Join Date: May 2014 Location: Coopersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score |
![]() Join Date: Jun 2010 Location: Near sac, Amador County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score I was told to stay away from the ATC |
![]() Join Date: Jan 2015 Location: Holden Louisiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 182
| Not Ranked : 0 score What @TiGraySpeed6; said, the luk/fidanza will be all you need especially if your going bnr s4. IMO with the short time I've had the s4 it is easier on the clutch than the k04.
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ |
| Not Ranked : 0 score I got to enjoy my s4 for 300 miles before zzb Sent from my iPhone using Tapatalk |
| Not Ranked : 0 score Sucks man. But that avatar
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ Last edited by voodoo2crue; 05-15-2016 at 10:53 AM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score Sorry to hear about that man. How many clicks on the odometer and what was your tune like?
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
170xxx and not really sure. I only got to drive on the base map. The first revision was only on for a few miles before she gave. Last edited by MS3Shadow; 05-18-2016 at 08:11 PM. | |
| The Following User Says Thank You to Kevopg For This Useful Post: | BuddySpeed3 (05-17-2016) |
![]() I wonder what the difference is between the street disk and 6 puck in terms of longevity.
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by MS3Shadow; 05-18-2016 at 08:12 PM. | |
I've had the car since 09 with low miles, I was good on maintenance and only had intake and ap with one of the base maps. I did all my upgrades at once which might have had something todo with it. Last edited by MS3Shadow; 05-18-2016 at 08:13 PM. | ||
| The Following User Says Thank You to Kevopg For This Useful Post: | BuddySpeed3 (05-21-2016) |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| That's why I ultimately went with the street disc. I've talked to several BT guys making 400-450 wheel HP/TQ and they've all got 30k+ out of them. But I've also heard some 6 puck guys say they had plenty left after 20-30k when they pull their motor.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | BuddySpeed3 (05-21-2016) |
| Not Ranked : 0 score Yeah, with the k04 we're trying to squeeze every bit of power we can much earlier in the rpm band which creates big torque numbers early in the rpm. But with the S4 having the potential that it does in the upper rpms you can run a reverse taper boost curve and steadily gain power all the way to RL.
| The Following User Says Thank You to voodoo2crue For This Useful Post: | BuddySpeed3 (05-18-2016) |
Then again I haven't done much research on the JMF intake manifold and what characteristics it has in terms of drive-ability and cold starts. I have a feeling it is mainly designed for high boost applications, but also wonder if it flows even amounts of air to all 4 cylinders. I've read that the stock intake manifold does not flow evenly.
| Not Ranked : 0 score Yea that's what got me looking for a new clutch since engine is coming out. The cheapest I could find the Luk/fidanza combo is 550. Anyone know of a cheaper route or cheapest way to get this combo? Already going to spend 4K on engine Sent from my iPhone using Tapatalk |
Groans: 122
| I have a street disc, and I think its pretty decent. I still kind of wish I had gone with a 6 puck.
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | BuddySpeed3 (05-17-2016) |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score ACT 6 puck with Street lite fly. Over build it or you'll end up regretting it later. The new ACT 6 puck is easy on the left leg, only slightly stiffer than stock. The Prolite will have more chatter but less rotational mass.
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
| The Following 2 Users Say Thank You to 08cosmic3 For This Useful Post: | BuddySpeed3 (05-18-2016), CWP_MS3 (05-18-2016) |
Groans: 122
Plus they have the same pressure plate, so there will be no difference in feel, only bite.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() | |
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | BuddySpeed3 (05-18-2016) |
![]() Join Date: Apr 2011 Location: La Grange, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Correct me if I'm wrong but the SteedSpeed doesn't really flow any better than OEM. If you're going to spend that kind of jack on an exhaust mani, I would look to get something tubular. There are quite a few options for that price. Then when you do look to upgrade the intake mani to a JMF or whatever, you won't be exhaust mani restricted.
__________________ 2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not). |
![]() | | #24 | ![]() |
| Not Ranked : 0 score The stock flange Steedspeed mani isn't any better than stock |
![]() | | #25 | ![]() |
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score They advertise that the length of the runners are not all even, but would it be worth buying one over an equal length one? Does the Steedspeed manifold flow better than stock at all? I kind of like to simplistic bolt on sorta deal and the ruggedness of it. Could you elaborate on that?
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 05-24-2016 at 08:52 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #27 | ![]() |
Groans: 128
| Not Ranked : 0 score someone swapped from the steadspeed to stock manifold and picked up g/s airflow with stock being better then the steadspeed.
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Wow really?
| Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? | Douggievee | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 05-14-2015 10:44 AM |
| New OEM Clutch with Fidanza Flywheel Soft Clutch Feel | zer010gic | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-15-2014 11:12 PM |
| clutch/flywheel bad??? | stonecold0469 | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 03-17-2013 10:01 PM |
