  • 1 Post By Kevopg
  • 1 Post By dealerjohn1
 Old 06-10-2016, 02:13 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
Default Complete pulley kit interest thread
I, like many others...am in the process of building an engine. In an attempt to get everything out of this motor that i can, i started looking into a complete lightweight pulley kit. In comes BoombaRacing, which i'm sure many of you already know. They make some nice parts for the ST, including a pulley kit. Since our platforms are very similar and some parts are interchangeable, i got in contact with BoombaRacing and asked about either modifying their current pulley kit to fit ours or start from scratch and make us a kit. It will be discussed at their meeting on monday and i should hear back afterwards, but i am seeing if others would have any interest in this?
Here is the link for the ST pulley kit (offered in 4 different colors) Focus ST Lightweight Pulley Kit
I'm well aware that corksport makes some, but it's not a complete pulley kit (no crank pulley..and they are a little bland)
I'm also well aware i'll probably get flamed for this, but oh well. Anyways, let me know who's interested. I will follow up with more details as i get them.
wes3id is offline   Reply With Quote
 Old 06-11-2016, 03:45 PM   #2
wes3id's Avatar
Really? no interest in this?
 Old 06-11-2016, 09:22 PM   #3
Kevopg's Avatar
Posts: 120   (View Stats)
Kevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to all
If they work for you I'm in. Not really a fan of cs
wes3id likes this.
Kevopg is offline   Reply With Quote
 Old 06-12-2016, 12:25 PM   #4
dealerjohn1's Avatar
Posts: 268   (View Stats)
dealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the world
I would be down for this
wes3id likes this.
dealerjohn1 is offline   Reply With Quote
 Old 06-12-2016, 01:33 PM   #5
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I think once we hear back from Boomba more people will get interested. It doesn't seem like a whole ton of people even use the CS pulleys. But as always, more options are always more better.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
wes3id (06-12-2016)
 Old 06-13-2016, 01:39 PM   #6
wes3id's Avatar
Just got off the phone with Boomba, they said it is something they are willing to pursue..but currently have a lot of smaller projects on the table for their existing platforms. It would be at least a few months before they are ready for the project and will give me a call for testing.
I will keep you guys up to date on any news.
The Following 3 Users Say Thank You to wes3id For This Useful Post:
Code Monkey (06-13-2016), Kevopg (06-13-2016), Mazdazilla6 (06-14-2016)
 Old 03-10-2017, 09:38 PM   #7
WookieeOne's Avatar
Posts: 1   (View Stats)
WookieeOne is an unknown quantity at this point
Has there been any news from Boomba?
WookieeOne is offline   Reply With Quote
 Old 03-11-2017, 04:21 PM   #8
wes3id's Avatar
Nope, nor have i really pushed the issue since there was a lack of interest.
 Old 03-11-2017, 04:55 PM   #9
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
Yea, sounds like the answer you received was actually a nice "no". Aka "Yes, we'd love to do it BUT we have these other 'more relevant to us' projects going on that will always be a higher priority. Also, not sure if you knew this BUT your nice mazdaspeed 3/6 platform is essentially dead...soooooooo"
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
 Old 08-30-2019, 11:24 PM   #10
Flying's Avatar
Posts: 3   (View Stats)
Flying has a little shameless behaviour in the past
Down for that
Flying is offline   Reply With Quote
The Following User Says NO Thank You to Flying For This Un-useful Post:
MSMS3 (08-31-2019)
 Old 08-31-2019, 12:08 AM   #11
Posts: 2,825   (View Stats)
Originally Posted by Flying View Post
Down for that
You do realize the last post was two and a half years ago, right?
Stealthbox Interest Thread Nazarite MazdaSpeed 3/6 - Car Audio & Electronics 152 03-24-2013 07:15 PM
2011 AP interest thread vatordoc 2010 MS3 - ECU Computer Tuning 22 03-18-2011 11:47 AM
Page generated in 0.30694 seconds with 27 queries
