  • 1 Post By Kevopg
  • 1 Post By dealerjohn1
 Old 06-10-2016, 02:13 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
Default Complete pulley kit interest thread
I, like many others...am in the process of building an engine. In an attempt to get everything out of this motor that i can, i started looking into a complete lightweight pulley kit. In comes BoombaRacing, which i'm sure many of you already know. They make some nice parts for the ST, including a pulley kit. Since our platforms are very similar and some parts are interchangeable, i got in contact with BoombaRacing and asked about either modifying their current pulley kit to fit ours or start from scratch and make us a kit. It will be discussed at their meeting on monday and i should hear back afterwards, but i am seeing if others would have any interest in this?
Here is the link for the ST pulley kit (offered in 4 different colors) Focus ST Lightweight Pulley Kit
I'm well aware that corksport makes some, but it's not a complete pulley kit (no crank pulley..and they are a little bland)
I'm also well aware i'll probably get flamed for this, but oh well. Anyways, let me know who's interested. I will follow up with more details as i get them.
wes3id is offline   Reply With Quote
Stealthbox Interest Thread Nazarite MazdaSpeed 3/6 - Car Audio & Electronics 152 03-24-2013 07:15 PM
2011 AP interest thread vatordoc 2010 MS3 - ECU Computer Tuning 22 03-18-2011 11:47 AM
Page generated in 0.30606 seconds with 27 queries
