 Old 07-18-2010, 12:20 PM   #1
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Default coolant line configuration for non-water cooled turbo
Alright so my new turbo is just oil cooled, just gathering thoughts on what I should do with the existing lines...
Forming the passage for the stock turbo you have one line coming from the back of the egr unit, and the second coming from the primary hard-line that goes into the firewall.
To me, the best way to do it would be to just connect a line from the back of the egr to the nipple on the hard line. To me, this would basically be replicating the stock setup except you don't have a turbo in the middle of the line.
John (cageyvet) blocked the flow from both the back of the egr as well as the nipple on the hard line. This was one of my first thoughts, but to me this would eliminate any sort of flow to that branch of the system feeding the egr unit.
Any thoughts anyone? Or does anyone have a diagram of the coolant system? Perhaps with the direction of flow?
Thanks guyz in advance
 Old 07-18-2010, 08:13 PM   #2
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
i too haz wondered this. i'd just connect the lines together and call it a day
The Following User Says Thank You to turd burglar For This Useful Post:
madvillain (07-20-2010)
 Old 07-19-2010, 09:42 AM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I am redoing it on my car, you can just connect the lines.
2006 Mazdaspeed 6
 Old 07-20-2010, 01:23 AM   #4
madvillain's Avatar
Groans: 78
thanks man, i hoped you'd chime in
 Old 07-20-2010, 05:09 AM   #5
SRTie4k's Avatar
Posts: 1,715   (View Stats)
Or just block them off. I did the same thing with my SRT-4 - removed the coolant feed and installed a threaded plug on the head and cut the drain tube short and wedged a "bullet" plug in the tube.
The Following User Says Thank You to SRTie4k For This Useful Post:
 Old 07-20-2010, 06:05 AM   #6
i would connect them for sure, no use loosing cooling ability
Stock turbo oil and coolant lines 06Speed6 MazdaSpeed 3/6 - Turbo Induction 16 02-06-2010 10:22 AM
Mazdaspeed 3 @ Buttonwillow Configuration 13 and Willow Springs AlpineFD Auto-X / Road Racing / Time Attack 11 01-27-2010 05:12 PM
Turbo Oil Return Line 11cruzito11 MazdaSpeed 3/6 - Turbo Induction 21 09-27-2009 09:15 PM
OCZ claims record for water-cooled Flex II DDR2 Haltech Computers & Technology News 0 04-11-2008 03:20 AM
Page generated in 0.26909 seconds with 24 queries
