Closed Thread
 Old 03-31-2008, 05:21 AM   #1
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
Default Cosworth balance shaft delete/F2 oil pan baffle installed
I had completed the balance shaft delete months ago. The kit was a cheap 30 bucks from Focussport. They were advertising the Cosworth oil pan baffle as well but no longer had them in stock. After speaking directly with Cosworth, they had no plans to make another batch so I was basically SOL>
"Averia" from the 6 club stumbled on this F2 Motorsports pan baffle(made by Gillis Motorsport) and forwarded the link to me. If you don't know, these are crossover parts from the Focus Duratec engine. You may ask what other parts "corssover" and I'll answer, that's about it lol
It was 125 bucks. I honestly would have prefered the Cosworth piece over this but it will do. The fitment was OK due to elongated holes and choppy fabrication but again, it will suffice.
The removal of the oil pan is super simple
a bunch of 10mm bolts running along the front and back of the pan
there are 4 - 8mm bolts that connect the side of the oil pan to the timing chain cover and there are 4 - 14mm bolts that connect the other side of the oil pan to the transmission housing.
remove all of them, use the small "pry" area in front near the oil filter housing to seperate the pan from the block>then the messy fun begins
*you will also have to remove the 8mm bolt holding the oil dipstick to the intake mani>pull out the dip stick
If you attempt this, be prepared to spend a lot of time cleaning the block mounting area and the oil pan itself.
A parts washer is a valuable tool during this mod.
One of the highlights is that your engine will now hold almost 7 quarts of oil(I use 6.8)
If you are concerned with $, then don't do this.
I use Eneos oil and 7 quart changes every 4K isn't cheap lol
The car revs noticable quicker
And by removing the balance shaft assembly, you are removing about 17 lbs. of metal from your engine
It's one heavy SOB
We could speak for days why you should and should not remove the balance shafts and if you like let's discuss....
Mine have been removed for over 8K miles or 2 oil changes
This is my third oil change with the B/S removed and now the baffle installed.
Enjoy the pics and ask away if you need some additional info
this is a pic of the engine with the balance shafts removed - the gear you see "was' turning the balance shafts
this is the Cosworth B/S delete plug - which blocks the oil that "was" feeding the balance shafts
this is a pic of the OEM pan with the OEM small side baffles
these are pics of the F2 baffle & installed
Last edited by whoosh@Realtune; 03-31-2008 at 05:27 AM. Reason: its early>gimme a break
whoosh@Realtune is offline
The Following 3 Users Say Thank You to whoosh@Realtune For This Useful Post:
occschemguy (04-01-2008), SLS MS3 (04-01-2008), spek1098 (04-02-2008)
 Old 03-31-2008, 05:31 AM   #2
Wow dude, perfect for those draggin or doing serious road course racing!
So, since you put it out there, i understand the balance shafts are considered necessary in 4 cyl motors to remove vibrations.
So you havent experienced any more vibrations from their removal?
Haltech is offline
 Old 03-31-2008, 05:38 AM   #3
I could give you a better answer if my engine mount wasn't upgraded before the balance shafts were removed.
I have the 88 dur AWR mount that has made my speed a heavy duty vibrator since that was installed. So basically it wouldn't matter either way to me and decided to take advantage of the quicker revs, improved oil control, increased oil capacity, less weight, etc etc etc
Not an instant HP gain monster mod but I think a worth while mod
 Old 03-31-2008, 05:45 AM   #4
It's nice to have some people with some balls around here.
Haltech is offline
 Old 04-01-2008, 01:20 PM   #5
Bravnik's Avatar
Posts: 383   (View Stats)
Bravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond repute
Groaned at 33 Times in 22 Posts
I have balls! I mean every now and then my wife will let me borrow them and play with them.
Bravnik is offline
 Old 04-01-2008, 02:09 PM   #6
occschemguy's Avatar
Posts: 1,149   (View Stats)
occschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the world
good info thanks, i talked to mechanic and we are deleting the balance shaft on mine but using his remedy he came up with.
You can see more on mymyspace
occschemguy is offline
 Old 04-01-2008, 08:06 PM   #7
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Great, informative post you made. Too bad about the Cosworth oil pan baffle, that would have been nice to have.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline
 Old 04-01-2008, 09:05 PM   #8
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
Hey Woosh,
You ever make it down to south VA to virginia international raceway? I figure if you're installing better baffles, you've gotta be tracking or autox'in!
Crossbow is offline
 Old 04-01-2008, 10:07 PM   #9
ptperformance's Avatar
Posts: 4,123   (View Stats)
We have the baffle with a windage tray coming out for it here very soon. I wonder why the skipped on the windage tray when they did the baffel? Odd.
ptperformance is offline
 Old 04-01-2008, 10:15 PM   #10
redrocketz's Avatar
Posts: 1,122   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
they copied the Cosworth and they probably realized that it wasn't needed. We offer the option of the balance shaft delete with our built motors. It would be much easier than reinstalling the balance shaft. I've built 5 of them so far and no one wanted the damn delete.
redrocketz is offline
 Old 04-02-2008, 01:02 AM   #11
Any way that the BS assembly could strip the gears when the power starts to get up higher? 17lbs is going to be tough to keep up with the motor if things start getting to much for them power wise. As far as the tray goes, big ass flat piece of metal to bounce the oil back up into the crank? I am sure Cosworth did there homework but come on, that can not be good or eff in getting the oil back into the pan.
 Old 04-02-2008, 05:05 AM   #12
Originally Posted by Crossbow View Post
Hey Woosh,
I live in PA and honestly, have never been to VA
Come to Maple Grove > you'll see me there
 Old 04-02-2008, 10:18 AM   #13
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
Any concerns that the increased vibes might destroy the oil pump or other components?
I'm asking because, with the Miata engines, replacing the crank pulley with a light-weight aluminum billet one induced vibrations into the oil pump causing it to disintegrate in the engine... The stock crank pulley had a dampener in it...
This wasn't an issue with rebuilt blue printed and balanced engines.
Just wondering if this has similar effects on this engine...?
2008 Stage 3 Roush Mustang
AutoXRacer is offline
 Old 04-02-2008, 11:56 AM   #14
redrocketz's Avatar
Not too sure honestly the gears are pretty beafy but there really is no way to tell until it does happen I guess. Cosworth removes it on their race engines though.
 Old 04-02-2008, 12:06 PM   #15
Averia's Avatar
Posts: 34   (View Stats)
Averia will become famous soon enough
Yeah my car has been sitting for about 4 months now. I 'm sure all the oil has drained to the pan - now is the time to do this for me.
Averia is offline
 Old 04-02-2008, 12:25 PM   #16
I like to think that anything is possible but this senario is not likely
Our crank pulley is a dampener as well
 Old 04-02-2008, 12:35 PM   #17
17lbs is a bathroom weight scale measurement of the entire B/S assembly after removal>not rotating weight
the big ass plate sits higher than the oil level of the pan and is there to reduce the windage effect as well as control oil during hard cornering/acceleration
I do think that a few drain holes wouldn't have hurt but I seriously doubt that oil starvation will be an issue. Especially since the pan has an almost 7 quart capacity now that the huge B/S assembly is no longer submerged in the pan
 Old 04-02-2008, 12:56 PM   #18
AutoXRacer's Avatar
What does the B/S assembly look like...? Pics???
 Old 04-02-2008, 01:04 PM   #19
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
this is the best I could find without having done it yet myself... it should be pretty damn close to ours.
Duratec » modification-BSD
L76-powered
mdogg is offline
The Following User Says Thank You to mdogg For This Useful Post:
SLS MS3 (04-02-2008)
 Old 04-02-2008, 01:08 PM   #20
thanks for posting that mdogg
they are identical
 Old 04-02-2008, 01:08 PM   #21
redrocketz's Avatar
it's a huge piece with 2 cams on it and a gear that goes onto the crankshaft all held in a cast housing.
 Old 04-02-2008, 02:58 PM   #22
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
zach should i do this?
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline
 Old 04-02-2008, 03:19 PM   #23
redrocketz's Avatar
If you already have it all apart why not. We have a direct account with Cosworth FYI
 Old 04-02-2008, 03:28 PM   #24
go for it!
 Old 04-02-2008, 08:48 PM   #25
whats the cost? I haven't looked into this at all?
 Old 04-02-2008, 08:52 PM   #26
mdogg's Avatar
Groans: 86
it should only be around $20 for the "kit".... which consists of the plate and the bolt.... and if there's already no oil pan on then there really isn't anything to it.
L76-powered
mdogg is offline
 Old 04-03-2008, 05:16 AM   #27
as far as I know
there are 3 companies that make the delete plug w/bolt
Marcy Motorsport(cheapest price and "look" of quality)
Cosworth
Massive Motorsports>my favorite...it's anodized PURPLE "OH HOW PRETTY"
and as far as I know, the Massive purple delete plate is the newest out there
 Old 04-03-2008, 08:22 AM   #28
mdogg's Avatar
Groans: 86
F2 also makes a BS delete kit along with the oil pan baffle - a complete one-stop solution
L76-powered
mdogg is offline
 Old 04-03-2008, 09:29 AM   #29
F2? I found their BS kit but not the baffle. I'm going to do this I guess.
 Old 04-03-2008, 10:39 AM   #30
mdogg's Avatar
Groans: 86
BS delete kit:
F2 Balance Shaft Delete Kit [F2BSD] - $23.00 : Zen Cart!, The Art of E-commerce
Baffle:
F2/GMS Oil Sump Baffle Kit [F2-Sump Baffle] - $125.00 : Zen Cart!, The Art of E-commerce
L76-powered
mdogg is offline
The Following 3 Users Say Thank You to mdogg For This Useful Post:
Crossbow (04-03-2008), dadasracecar (04-04-2008), whoosh@Realtune (04-04-2008)
 Old 04-03-2008, 10:45 AM   #31
thank you sirrrrr. much appreciated!
 Old 04-03-2008, 07:58 PM   #32
Shouldn't. There is no proof that removing the BS assembly can cause dangerous conditions other then those that you can not create because of the redline. The LW pully's on the other hand have been linked to many destroed oil pumps and gearotor assemblys.
The Following User Says Thank You to ptperformance For This Useful Post:
 Old 04-03-2008, 08:02 PM   #33
I want to ask again, does anyone think that if your going to put a huge plate in the motor should you not also but some sort of way to wipe the oil from the crank, windage tray anyone? Something other then a huge ass metal plate that is perfect for bouncing the oil back up into the crank.
 Old 04-03-2008, 10:26 PM   #34
ZooZoom's Avatar
Posts: 178   (View Stats)
ZooZoom is a name known to allZooZoom is a name known to allZooZoom is a name known to allZooZoom is a name known to allZooZoom is a name known to allZooZoom is a name known to all
for us dummies, can you show a pic of a "windage tray" or provide a bit more detail on how/why it works? what purpose does it serve?
always lookin to learn more......
ZooZoom is offline
 Old 04-04-2008, 10:02 AM   #35
Crossbow's Avatar
Basically a piece of metal that helps prevent oil from splashing onto the crankshaft from the sump. This helps prevent hp loss from the crank having to deal with chucks of oil being thrown at it while its spinning around. Usually works in conjunction with baffles to provide excellent oil control in high g situations.
Here's a photo of one installed.
http://www.coopofdoom.net/images/eng...16-06_1110.jpg
Crossbow is offline
 Old 04-04-2008, 10:03 AM   #36
ZooZoom's Avatar
again, forgive my ignorance, but what harm comes from splashing oil onto the crankshaft?
ZooZoom is offline
 Old 04-04-2008, 10:07 AM   #37
Crossbow's Avatar
Keeps the oil where its supposed to be, allows for efficient drain of oil away from the crankshaft, and prevents horsepower loss from the oil splashing on the crank while its trying to turn. (ie. Only the oil thats supposed to be there is there).
Crossbow is offline
 Old 04-04-2008, 02:13 PM   #38
just ordered the BS delete. I guess the baffle goes hand in hand with that or no?
 Old 04-05-2008, 12:51 AM   #39
Thank you. I thought it was only me thinking that a windage tray or at least a crank scraper would be a nice option to have on that set up.
 Old 04-06-2008, 10:02 AM   #40
Crossbow's Avatar
I completely agree. If you're going to have the whole thing apart and in pieces, you might as well put everything you can on there .
Crossbow is offline
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/cosworth-balance-shaft-delete-f2-oil-pan-1449/
What You Need to Know to Build a Motor | SpeedForums.org This thread Refback 06-20-2012 08:16 AM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-02-2008 10:26 AM
egr delete a no no??? bova MazdaSpeed 6 - Engine, Transmission & Driveline 11 07-25-2009 06:49 PM
Wii Fit with Balance board $78.99 free shipping Haltech Hot Deals Section 0 04-06-2008 09:02 AM
PG Manifold installed SLS MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 25 04-04-2008 12:53 PM
Kensington Contour Balance Backpack (up to 15.4in) $19.99 Free Shipping Haltech Hot Deals Section 0 03-26-2008 01:24 AM
Page generated in 0.58210 seconds with 32 queries
