Like Tree41Likes
 Old 11-30-2009, 09:32 PM   #1
Default DISI Compression Results
We have seen quite a few people with low compression numbers and blowby. Is this cylinder wear? Is it bent rods?
Go and grab a test of your motor, post up the results along with mileage and mods. Let's see if we can find something useful out.
JCSPEED3 likes this.
Downmented (07-24-2013), Jeremy M (12-07-2014), ms3blackmica (11-22-2012)
 Old 11-30-2009, 09:34 PM   #2
just a note u can rent a compression gauge from autozone for free. im gona do mine soon so ill post up when im ready.
djuosnteisn (11-30-2009), xdm88 (01-09-2012)
 Old 11-30-2009, 09:35 PM   #3
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
just pull spark plug one at a time and crank over motor a few times?
 Old 11-30-2009, 09:37 PM   #4
yah make sure the motor is warmed up and pull the [inj relay] bottom left most in blue (on MS6)
if you find your low on one cylinder then pour a teaspoon of oil into it and repeat test. if the number comes back normal you have a problem in that cylinder.
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
djrich26 (12-22-2014), djuosnteisn (11-30-2009), Fail_6 (08-06-2013), sh4d0w (08-31-2015), xdm88 (01-09-2012)
 Old 11-30-2009, 09:37 PM   #5
Warm up engine. Pull all spark plugs. Pull fuel inj fuse. Step on clutch and gas at the same time. Crank for 5-7 seconds. Repeat for all cylinders.
The Following 13 Users Say Thank You to Lex For This Useful Post:
86AmishMs3 (03-23-2012), aaronc7 (11-30-2009), Atticaz (02-11-2016), Downmented (11-20-2012), dp3 (11-07-2014), Fail_6 (08-06-2013), LatinKraze (07-20-2014), razortechrs (07-25-2014), Realgib3 (11-30-2009), silvapain (01-16-2012), SLOWHATCH (03-27-2013), wette460 (07-21-2011), xdm88 (01-09-2012)
 Old 11-30-2009, 09:55 PM   #6
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I'm going to retest with above suggestions right now.
More results to come.
Oh, and it's best to pull all plugs at once, it makes it easier for the engine to crank. And you may want to put a trickle charger on your battery while you test.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Last edited by djuosnteisn; 11-30-2009 at 09:56 PM. Reason: MSF Database - Automerged Doublepost
Realgib3 (11-30-2009), SLOWHATCH (03-27-2013)
 Old 11-30-2009, 10:03 PM   #7
is stepping on the gas just to open the throttle plate?
and does all the charge piping need to be connected when doing this?
 Old 11-30-2009, 10:06 PM   #8
Captain
charge piping is pointless w/out boost. Doesn't need to be connected imo. Only thing i didn't do is warm engine up. So i guess we'll get a cold vs. warm comparison, lol.
www.permtuning.com
SLOWHATCH (04-05-2012)
 Old 11-30-2009, 10:10 PM   #9
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
Groans: 70
Holding the gas pedal down when cranking stops spark from being generated right? or is it fuel getting sent into cylinders? i know it does something..
2007speed3 is offline   Reply With Quote
 Old 11-30-2009, 10:18 PM   #10
Captain
cars warming up. brb in like 15 mins with results.
www.permtuning.com
 Old 11-30-2009, 11:15 PM   #11
m4tic's Avatar
Posts: 4,928   (View Stats)
holding the gas keeps the injectors from firing....
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
2007speed3 (12-01-2009)
 Old 11-30-2009, 11:24 PM   #12
Captain
Sigh of relief...
Let me stress the importance of warming the car up first, lol otherwise you'll think your ship is tanked.
23k miles.
3071 for 5kish
int, tbe, wmi, ap, bsd, etc (except for exh mani) for 10kish
dnp exh mani with ewg for like 30 miles, lol.
fuel pressure scalar (DJ CKT) for 20 miles
Here's cylinder 1:
Here's cylinder 2:
Here's cylinder 3:
gf accidentally hit pause between cranks.
and of course the one cylinder most suspect is blurry lol, but it's obviously on par with the others.
Here's cylinder 4:
So i retract my previous compression data in the fuel ckt thread, and now feel much more comfortable about my motor. Though now that i said that, the god's have been tempted lol.
www.permtuning.com
2007speed3 (12-01-2009), 6-Speed-6 (12-22-2009), bioevolve (12-01-2009), xdm88 (01-09-2012)
 Old 11-30-2009, 11:30 PM   #13
Lol good stuff Dustin! The warmup is indeed important!
Nice nails btw
Broxer (01-18-2012), djuosnteisn (12-01-2009), kgb (12-03-2009), SLOWHATCH (04-05-2012)
 Old 11-30-2009, 11:59 PM   #14
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
Yeah Lex, those are some nice nails indeed!!!!
glocK23 is offline   Reply With Quote
The Following User Says Thank You to glocK23 For This Useful Post:
 Old 12-01-2009, 12:07 AM   #15
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
you guys should also post what the first "puff" puts the gauge to. It should get right up around 100psi or more on the first puff of a healthy cylinder. If you do end up doing a wet test as well the readings will be higher with the oil in there, they need to be considerably higher to know your compression isnt holding in that cyl.
bykeryder4life is offline   Reply With Quote
 Old 12-01-2009, 01:11 AM   #16
silversurfer3's Avatar
Posts: 618   (View Stats)
silversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond repute
Groaned at 26 Times in 11 Posts
I got 0's all across ?? What does that mean????
Rota wheel whore #1
MOdS list
shaved with a razor moldings (EDGE cream)~de-BaGEd FTW~
painted StoCk wheels secret color ~ rattl;e caned RooF~ jdm painted brake conversion~ clear tint ~ light weight black hood and trunk with wing option ~ japanese amber side markers/ running lights ~ tw0 light weight car seats ~ shifter weight reduction ~ stock recaros with red stitching ~ mp3 mazda stereo
for sale: ms3 transmission second gear is worn out. Perfect if you want to Upgrade it or if you don't want to have any down time if you're trans is messed up!
PM me with offers
silversurfer3 is offline   Reply With Quote
The Following 3 Users Say Thank You to silversurfer3 For This Useful Post:
2007speed3 (12-01-2009), DaleNixon (12-01-2009), Darksun280 (12-01-2009)
 Old 12-01-2009, 05:49 AM   #17
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
doh, i was gonna test mine, but i cant warm up the engine. i have no exhaust on the car...
I am running 8.8:1 compression, so im looking for 155-160 per cylinder to match your 170's
 Old 12-01-2009, 06:00 AM   #18
2007speed3's Avatar
Groans: 70
good job home boy, thanks for posting this up...
The Following User Says Thank You to 2007speed3 For This Useful Post:
 Old 12-01-2009, 06:44 PM   #19
wassup61's Avatar
Posts: 1,232   (View Stats)
Uhh... here is the procedure for comp test.
1. beat shit out of car to warm up
2. come home and pull plugs
3. depress clutch AND gas all the way to the floor and crank 5-8 times (will keep injectors from firing and open throttle plate).
4. Measure compression per cyl.
5 charge battery.
I have 8.8:1 arias, after beating on it and getting it hot i comp tested 183,182,184,187, which is high for a low comp. motor.
All wagon, No traction
The Following User Says Thank You to wassup61 For This Useful Post:
TheProYodler (07-28-2017)
 Old 12-01-2009, 07:07 PM   #20
Captain
Very high! Your at sea level?
www.permtuning.com
 Old 12-01-2009, 07:13 PM   #21
wassup61's Avatar
720 ASL
 Old 12-01-2009, 09:28 PM   #22
so after fighting with the POS compression gauge i rented from auto zone i ended up testing 180's across the board. might have been +/- 2 but w/e still good nonetheless. what a sigh of relief.
 Old 12-01-2009, 10:28 PM   #23
Captain
Might as well post your mileage, mods, and altitude.
Basically, 30psi on a re-worked, and not scared to catch a lil air now and then lol.
www.permtuning.com
superskaterxes (12-02-2009)
 Old 12-02-2009, 06:04 AM   #24
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
Groaned at 31 Times in 16 Posts
we should test mine on sat anthony. We will actually..
if my car is about to blow im parting out and taking to dealer. SOLD
Deadman is offline   Reply With Quote
 Old 12-02-2009, 06:34 AM   #25
damm straight thats how i roll haha
like 75' ASL 38k
PTP SST ~ TXS BOV ~ CPE Xcel CAI w/Injen Hydroshield ~ AP PROtuned by me @26psi ~ Grimmspeed EBCS ~ Custom Side-to-Side FMIC ~ Corksport Downpipe (Heat Wrapped) ~ DNP Mani w/Tial 38mm MV-S EWG VTA'd~ Custom Turbo Inlet Pipe ~ TWM Stage 1 Short Shifter ~ CPE RMM ~ TTFMM ~ CPE RDM ~ BC CO's slammed ~ SPC BJ's ~ EBC Red's ~ Stoptech's ~ Technafit SS Lines ~ Autometer Boost & STRI EGT in Custom Built Vent Pod ~ 20% Tint ~ LED Tails ~ Denso ITV-24's ~ Xtra Shorty Antenna ~ Dashhawk ~ Magnaflow Catback ~ TXS Test Pipe ~ Custom Strut tower bar ~ Whiteline RSB ~ PnP'd IM ~ CDFP Internals ~ labonte meth kit ~ VC tapped OCC ~ 290WHP/337WTQ on a MD ~ 12.9 @ 107 1.8 60' ~ fastest stock turbo trap speed in the USA
 Old 12-21-2009, 09:41 AM   #26
socks's Avatar
Groans: 125
Ok, so I finally got around to testing mine.
Spec is 175. on a 9.5:1 compression ratio.
175 / 9.5 = 18.421
18.421 x 8.8 = 162.1
This is what i was looking for when i tested mine.
My results
1........162
2........165
3........165
4........162
Im pretty stoked. Those numbers are in line with eachother, and in line with what i expected. Im 800' ASL, have 11,000 miles on my motor, with a 3071 @ 20+ psi.
The Following User Says Thank You to socks For This Useful Post:
djuosnteisn (12-21-2009)
 Old 12-21-2009, 10:09 AM   #27
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
I just yanked out my leakdown gear a couple days back...cuz I can. I tested all four and found they all read low for leakdown. I could hear some air escaping into the crankcase but, obviously not alot. Turbo motors need fairly loose tolerances anyway. All four were pretty equal in terms of leakdown so, it looks like I haven't killed anything with my fail stock CD fuel pump and in and out mods.
The modestly tricky bit was actually getting the cylinders to exact TDC. This became much easier to see when the leakdown fitting jammed in the 3 plug hole and I had to pull the cam cover.
Here's a little cool thing: The cam cover bolts are captured so you don't have to remove them and drop them into the engine bay, ne'er to be seen again. The also act as spacers so, tighten down til it stops and you're torqued.
Plus, the bolt on the end of the crank for turning the engine over is standing proud of the pulley and is easily reached with a simple undoing of two 10mm bolts and push pin from the plastic shroud.
I love little examples of practical engineering excellence. This car is stuffed with them and, I appreciate it.
The Following User Says Thank You to darth vader For This Useful Post:
FreeFlyFreak (12-21-2009)
 Old 12-21-2009, 03:49 PM   #28
awd>fwd
jwdp54's Avatar
Posts: 627   (View Stats)
jwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the world
Groans: 27
Groaned at 53 Times in 33 Posts
i got mine checked on sat. not sure what to think about the results..
1-145
2-145
3-140
4-145
MS3 310whp/320tq- SOLD finally(5/5/10)
evo 8-tuned to E85
jwdp54 is offline   Reply With Quote
 Old 12-21-2009, 03:51 PM   #29
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
1-145
2-145
3-140
4-145
What are your miles? Im gonna do this soon as well.
 Old 12-21-2009, 03:57 PM   #30
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
1-145
2-145
3-140
4-145
The actual numbers are less important than the consistency of the numbers. I would keep an eye on #3, but wouldn't be overly worried..
 Old 12-21-2009, 04:26 PM   #31
awd>fwd
jwdp54's Avatar
Groans: 27
they were actually closer in numbers. he said cyl 3 was dead on 140 which he tested 3 times and same results. the other cylinders read between 140-145. car has no problems with 22k of hard driving, fully bolted, very minimal kr and stock ecu. runnin like a champ
evo 8-tuned to E85
 Old 12-21-2009, 04:39 PM   #32
wassup61's Avatar
Your numbers are borderline replace motor...
 Old 12-21-2009, 04:40 PM   #33
Captain
did you warm the car up before testing?
www.permtuning.com
 Old 12-21-2009, 04:46 PM   #34
socks's Avatar
Groans: 125
129psi is the minimum according to the FSM, and there should be no more than 28.5psi variance in the cylinders.
 Old 12-21-2009, 04:47 PM   #35
awd>fwd
jwdp54's Avatar
Groans: 27
i don't know if he did. i meant to ask him. i'll call him tomorrow.
he said borderline is 129 which does have me worried but i've been looking for a new toy if i do run into problems.
evo 8-tuned to E85
 Old 12-22-2009, 08:21 AM   #36
When you get #s that concern you on a comp test...#1, redo the test, making sure it was done properly with a strong battery, throttle open and engine warmed up well.
If you get the same results you don't like, time to do a leakdown test and determine actual engine condition. These motors should leak a fair bit over an NA engine, as is, being turbo engines and thus having fairly loose bore tolerances. However, if you're seeing over 20%, that cylinder is tired out. Listen for where the leak is going and that'll tell you what's worn. Hear it out of the oil fill? Rings. Hear it out of the exhaust? Exhaust valve. Hear it out of the intake? You get the idea.
I just pulled out my gear and did this on my own car a couple days back. It's really easy on this car, I have to say, due to the manufacturer's foresight in design.
 Old 12-22-2009, 04:18 PM   #37
awd>fwd
jwdp54's Avatar
Groans: 27
lol i hate troubleshooting on this car cuz of all the noises in the engine bay. i always think my cars knocking yet it's just my fp ticking and all the rattling from motor mounts.
i didn't get a chance to call him today. hopefully i can tomorrow so i can figure this shit out.
evo 8-tuned to E85
The Following User Says Thank You to jwdp54 For This Useful Post:
sLow6 (06-30-2011)
 Old 12-26-2009, 06:30 PM   #38
evidence's Avatar
Posts: 1,033   (View Stats)
1000ft ASL, 18k miles. Heated the coolant to 190, and started on the right, ~6 cranks each.
left to right from the front of the car:
175
175
175
178
BTW, just pulled the blue fuse near the top right that says 'injector', but also depressed clutch and gas just to be safe. Figure the later is enough to keep the cylinders dry though.
Some things.
The Following 2 Users Say Thank You to evidence For This Useful Post:
djuosnteisn (12-26-2009), jwdp54 (12-27-2009)
 Old 04-05-2010, 08:11 PM   #39
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
I just wanted to come in here to bump an old thread to piss off the mods.
kidding!
Just did mine tonight-- 180ish across the board. Think I got one of the good motors. Tranny is smooth as glass too. Now for some more mods...
'08 CWP MS3 w/ T3 3071r
thanox2 (04-05-2010)
 Old 04-05-2010, 10:00 PM   #40
Fullmetal's Avatar
Posts: 87   (View Stats)
Fullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the worldFullmetal is the leader of the world
Groans: 35
Groaned at 9 Times in 6 Posts
sorry but may i point out all compression and tdc and valve clearance measures should be taking at cold and heated to get true comparisons. cold engines will show true wear cause as metal heats it expands. that is basic metallurgy, cause you might have great starting compression when warm. this may not be true for cold engines and i have seen many cold engine running problems! if you have cold engine running problems this will effect you warm engine closed loop operation. since the computer learns how to get the engine hot it thinks once the engines hot i can start pulling timing and allow for more emission control. this causes lean conditions which will raise the leaning out of engines to increase proper burn and near zero emissions thank you to the federal gov't. And now one key thing to remember is that taking non running compression will not give you true compression number. your compression may drop once you induce fuel into the cylinders, from the fact that most liquid takes more to compress and if you have any type of bend in the rod or cylinder leakage do to higher dynamic compression you can not tell this at @ 700-800 rpm cranking compression test. this test is mainly used to find blown or warped heads. running compression will net you more info. plus you must compare your cold vs hot reading to tell of true cylinder problems. also you need to check your valve lash to see if your running problems are not to to improper valve seating. high cylinder temps can cause valve seats and stem seals to morph allowing more cylinder problems not able to be told by a cranking compression test. load will always affect cylinder pressure along with engine temp. this is why the ecu has complex fuel and load tables based on a very complex algorithm of up to 8- 10 different sensor readings. and it uses an average of cold verse hot to tell which is the most economical and efficient way to use the engine. just my two cents. years of diagnosing all engine types and running problems i will follow what i have learned based on what i read.
Always do cylinder leak down test.
Fullmetal is offline   Reply With Quote
The Following 4 Users Say Thank You to Fullmetal For This Useful Post:
802MS3 (04-05-2010), danesti (04-12-2010), Mizzle (04-10-2010), OSN (11-21-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.61781 seconds with 39 queries
