 Old 03-05-2010, 07:07 PM   #1
desertrat's Avatar
Posts: 132   (View Stats)
desertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant future
Default EGR valve cleaning
For those of you who have removed and cleand the EGR valve did you replace the gasket or reuse the old one?
desertrat is offline   Reply With Quote
 Old 03-05-2010, 07:59 PM   #2
zfreebird's Avatar
Posts: 44   (View Stats)
zfreebird has a spectacular aura aboutzfreebird has a spectacular aura about
Haha...answered on my post...but i would suggest not reusing the gasket between the main EGR and manifold...thing may break apart and since radiator fluid runs through it, it needs a nice seal.
zfreebird is offline   Reply With Quote
 Old 03-05-2010, 08:12 PM   #3
desertrat's Avatar
Thanks I bought one just in case as well. I'm going to try and plug the coolant line or save it in a bucket.
 Old 03-05-2010, 08:17 PM   #4
zfreebird's Avatar
Wooah hold on! I thought the same thing but the coolant DOES NOT come from the hose. It comes from the EGR valve. When I EVENTUALLY popped the line off i was also ready to plug it but was like, wait where is this fluid coming from. I ended up losing a good amount of coolant before i could get the hose back on because of its WONDERFUL spot. I honestly dont think there is any other way around it other than draining the fluid.
 Old 03-05-2010, 08:49 PM   #5
desertrat's Avatar
Good to know, thanks. That kind of sucks, I had just changed my coolant a few months ago.
Instead of draining the coolant from the drain plug what do you think about just taking off the hose from the radiator to the block?
scratch that idea it would just be a big mess.
Last edited by desertrat; 03-05-2010 at 08:53 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-06-2010, 09:17 AM   #6
zfreebird's Avatar
haha yeah im a little unsure about that one. I still need to change mine at some point.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/egr-valve-cleaning-50449/
mazdaspeed3 egr valve - Zuula Search This thread Refback 05-22-2010 06:23 PM
2/28 cleaning.... 09Speed3Z Appearance - WHITE 0 02-28-2010 01:59 PM
Car cleaning ChrisH Exterior 1 01-13-2010 05:37 PM
Cleaning Interior? nyghtryder MazdaSpeed 3/6 - Appearance 17 06-12-2009 06:50 PM
Cleaning the MS3 blackrs99 Mazdaspeed3/6 General Discussion 46 05-24-2009 08:45 PM
CAI + Pre-Filter.. cleaning silverspd3 MazdaSpeed 3 - Engine, Transmission & Driveline 8 02-09-2009 08:16 AM
Page generated in 0.25714 seconds with 21 queries
