 Old 12-26-2009, 01:24 PM   #1
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
Default First CDFP internals ***RESULTS***
I need a touch of help, see attached photos. How do I get the little spring retainer off the stock internal's shaft?
Thanks in advance.
 Old 12-26-2009, 01:33 PM   #2
JmkC's Avatar
Posts: 871   (View Stats)
JmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the world
Groans: 109
why do you need to? haha i am actually curious
JmkC is offline   Reply With Quote
 Old 12-26-2009, 02:08 PM   #3
Well, I guess I need to retain the spring on the new shaft that came with my internals kit with something. The instructions don't detail this little part of the process at all.
It's allright, I figured it out. I thought it must be like a valve lock, in that a tap on a socket the size of the retainer would release the lock and, I was correct.
Last edited by darth vader; 12-26-2009 at 02:52 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-26-2009, 02:55 PM   #4
fjames's Avatar
Posts: 1,058   (View Stats)
Thanks in advance.
Retainer
 Old 12-26-2009, 04:43 PM   #5
Thanks. Got another question now. How do you get the little button back ON the retainer and, it's bevel side OUT, right?
 Old 12-26-2009, 04:47 PM   #6
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
AWE Tuning Flash Videos
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
atenza_freak (12-28-2009)
 Old 12-26-2009, 05:47 PM   #7
Yeah, they use a lot of special tools. Here's my answer: I pushed the shaft up as high as it would go, slid a 14mm box wrench under the retainer, laid it between my slightly open vise jaws, with the wrench overhanging the gap, then putting the button on and smacking it with a deadblow hammer. Went on right away, doing that.
Thanks for the guidance, though.
The Following 2 Users Say Thank You to darth vader For This Useful Post:
IshiKage (12-27-2009), mazdaspeedmike (01-07-2010)
 Old 12-28-2009, 02:25 PM   #8
Results are in. After 100 miles of break in, some WOT pulls datalogged today. 17-1800 psi, up from 700, over 5K. Car runs like a maniac. WOT was hard to find because I kept smacking the boost cut, like Bruce Lee giving me the 3" punch. I had to keep feathering the gas to keep it under the cut, it being only a couple degrees above freezing here.
Mods are: CS DP/RP, AEM CAI, PG TIP, Forge BPV w. red spring
Pump guts are PtP. Delivering on their promise, so far. The boost cut issue is outside temp/DP design related, can't tell which just yet, it being so cold.
The Following User Says Thank You to darth vader For This Useful Post:
IshiKage (12-28-2009)
 Old 12-28-2009, 06:59 PM   #9
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
glad u got it all worked out
 Old 12-28-2009, 07:38 PM   #10
Looks like something else got "worked out" in this thread, too and, I'll thank you for that, I'll bet.
 Old 01-07-2010, 08:23 PM   #11
mazdaspeedmike's Avatar
Posts: 49   (View Stats)
mazdaspeedmike is just really nicemazdaspeedmike is just really nicemazdaspeedmike is just really nicemazdaspeedmike is just really nice
Thanks to Darth for his method of removal and installation of the retainer! PTP needs to detail this out with some instructions. The ones they send you are from a KMD installation with two piece shims and everything...not useful at all.
mazdaspeedmike is offline   Reply With Quote
 Old 01-07-2010, 09:18 PM   #12
Yer welcome...I thought it was pretty weird to be sending out picture instructions that are for another company's product. Not too professional, that, imho. 95% of the job is the same but, there are some detail elements that differ. The supplied instructions also give no torque values, which is bullshit. Reasoning it out based on the thread pitch used and size, like we used to have to do in antediluvian times, serves well here. No more than 50 pounds/ft on the cap and 16 on the mounting screws.
 Old 01-07-2010, 09:22 PM   #13
IshiKage's Avatar
Groans: 278
yeah, thats was bull. i installed mine today. cant wait til they are broken in
dropped to 58psi once
2015 Mazda 6
 Old 01-07-2010, 10:18 PM   #14
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
Groans: 70
when did yours drop to 50psi?
i put my pump in today, hasnt gone lower then 392
2007speed3 is offline   Reply With Quote
 Old 01-07-2010, 11:00 PM   #15
IshiKage's Avatar
Groans: 278
your preinstalled pump is probably broken in already.
PTP pumps have a 100mile break in period. got the cut in second holding 6k rpms just to break them in at that rpm. i go between 3-6k to break in the pump
2015 Mazda 6
 Old 01-09-2010, 11:51 AM   #16
evidence's Avatar
Posts: 1,033   (View Stats)
You sure it's not boost cut but fuel cut? Logging fuel pressure should show you if it's the case, it'll drop to around 50. Seems like it's somewhat common for these to need more than 100 mile break in.
Some things.
 Old 01-09-2010, 12:43 PM   #17
I'm really sure. The boost gauge pegs, the fuel pressure is up, according to my datalogs, at 1700-1800 psi, Bruce hits me in the face.
 Old 01-10-2010, 03:11 PM   #18
evidence's Avatar
That's good news then, I should be receiving my replacement Monday. Hopefully no more fuel caused Bruce in the face for me
Some things.
 Old 01-10-2010, 03:30 PM   #19
A manual boost controller put Bruce back in his cage for me...now it shoots to 17, where I want it and holds there.
Good luck on the install!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/first-camshaft-driven-fuel-pump-internals-job-45290/
Fuel Pump Upgrades what are you running? - Page 5 This thread Refback 06-09-2012 03:40 PM
Fuel Pump Upgrades what are you running? This thread Pingback 07-15-2010 09:54 AM
CDFP internals upgrade CraigHJr MazdaSpeed 3 - How-To's 144 06-06-2014 01:59 PM
Before and After CDFP upgrade (PG internals) Jarods7920 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 13 01-05-2009 11:16 AM
CDFP internals or new pump Jarods7920 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 10-23-2008 04:33 PM
Page generated in 0.38742 seconds with 28 queries
