| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Aug 2009 Location: Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score SLP Performance sells "Loudmouth" resonators that look nearly identical, nothing inside, the flow goes from inlet size to 4" back to the original inlet size with no internal packing or anything. I'm wondering why they would sell these if they destroyed flow balancing or caused a power loss. I can maybe see the downpipe being a different story considering the dead elephant baby shape, etc. Thoughts? I know a few have done this and have not reported any issues with performance, but wanted to get some other thoughts. "SLP Loudmouth I Resonator" "SLP Loudmouth I Resonator Inside view" "Stock Speed3 2nd Cat Shape (assume empty)"
__________________ 08.5 MGM Mazdaspeed3 Sport - VQ37VHR Conversion - RWD Conversion - Custom 2.5" X-Pipe - Weldina Catback Motordyne A.R.T. pipes coming shortly |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score "I'm wondering why they would sell these if they destroyed flow balancing or caused a power loss." Companies will sell anything, regardless if it will help or harm the car's performance. A quick search on ebay will turn up $25 "performance chips", $40 electric superchargers and those tornado things that go in your intake and supposedly increase mileage. I don't think those SLP pipes will rob power but it doesn't seem like it would increase it either.
__________________ 2009 MS3 sport MGM |
(Thread Starter) | Not Ranked : 0 score SLP is a pretty reputable company, and they dont sell their's to increase power, but as an option to drop the noise on an exhaust system. I was stating that I dont think they would use this type of noise control shape if it hurt power too. The only gain in the speed3 situation would be that the cat no longer had internals, and again the dispute being whether the power gains would be lost to poor flow after their removal.
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score Head over to the dynos section and check out bioevolve's build. He gutted the stock downpipe and gained 20HP or so. Now I can see an aftermarket downpipe as having a "smoother" flow than stock, so it will probably make more power, but even the stocker will gain some power without the catalyst in the way. That's just fluid dynamics.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
(Thread Starter) | Not Ranked : 0 score Definately agree regarding the power and have seen those posts, was just wondering regarding the stock 2nd cat only, and also how it would affect exhaust resonance, throttle input, etc.
![]() Join Date: Jun 2009
| Not Ranked : 0 score Given that a race/test pipe is pretty cheap and only gains maybe 5 whp, (as previously noted, it's the dp where the serious restriction is located). I'm wondering whether it's worth the effort to gut that cat. Just a cost-benefit question. Free is always better, if you are sure you might not need to go back to stock for any reason. You could just about as cheaply cut out that cat and weld in a straight pipe between the flanges and not worry about the change in internal contours and what that might do to exhaust turbulence and flow characteristics. Just a thought. I welded in a 3 inch Vibrant reso (straight through design) in my 3 inch rp to tame droning and did not see any loss in power, but it is absolutely a 3 inch straight tube with a shell around the center core. The shell is filled with solid sound absorbing material, so there is no change in internal contour.
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score I would replace the 2nd cat with a straight pipe and sell the cat for 50 bucks or so. They will only pay if the cats intact not if it's gutted. I ended up gutting my CPE cat because I wanted it to look like I still had one. Those are much smaller than stock though. Sent from my iPhone using Tapatalk
__________________ 2012 WRX HB w/mudflaps yo! |
| Which Dry Flow | KayWhy | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 11-05-2009 09:05 AM |
| Need High Flow Cat? | rtaylor60 | Cobb Access Port/Maps | 6 | 07-22-2009 10:23 PM |
| Anyone Weld In a Hi-flow CAT into the CS DP? | LBV | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 09-28-2008 06:44 PM |
| Adding Hi Flow Cat to TXS DP? | freebird_78 | MazdaSpeed 3/6 - Turbo Induction | 9 | 06-07-2008 03:30 PM |
