 Old 11-19-2013, 04:11 PM   #1
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
hnda etr has some of plunger seals. He could sell you some.
Originally Posted by Etipp98 View Post
I have used these in about 10 pump with no issues, direct fit.
Yeah i have a shit load of them cuz they only sell in packs of 100 and 50
McMaster-Carr part numbers:
90025k135 = Buna material (Standard OEM)
6540K121 = Viton material (Upgrade over Buna)
They're called Quad-Rings, X-rings or Double-seal O-Rings
The Following 2 Users Say Thank You to hnda etr For This Useful Post:
crutch77 (12-02-2013), SFWD 1934 (12-03-2013)
 Old 11-30-2013, 01:55 PM   #2
crutch77's Avatar
Posts: 493   (View Stats)
crutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the world
I got the rings yesterday, thanks again! Unfortunately the quad ring was apparently not the problem. Add me to the KMD haters group. My internals still look brand new, I am 100% confident that there are no installation issues, and my fuel pressure is still dropping at WOT.
So what now? I bought a set of Autotechs (bonus on timing this with the Black Friday sale, I guess). I have replaced the quad seal and the largest o-ring on the outside of the HPFP assembly. Just to cover all my bases, I'd like to replace the other o-ring: the one on the outside of the 18mm nut assembly. Does anyone know the size or have a McMaster Carr number for that o-ring? I haven't been able to find it searching these forums.
I'd also like to replace the spring if possible. Corksport is including a stiffer spring in their kits when they start selling them, but they won't sell the spring separately. I haven't hit up cp-e yet to see if they will, but I'm not optimistic. Anyone know a source for this spring? At 79,000 miles, my spring may be fatigued.
2008.5 MS3 GT | Forged | Self-Built, Self-Tuned | E85 | Torque (lots of it)
crutch77 is offline   Reply With Quote
 Old 12-01-2013, 05:00 AM   #3
hnda etr's Avatar
Groans: 90
No problem. Protegegarage.com used to sell upgraded hpfp springs, but I don't see them on their site any more. You might try them to see where they sourced them from.
crutch77 (12-01-2013)
 Old 12-01-2013, 09:27 AM   #4
crutch77's Avatar
Thanks for the tip, I just emailed them. Do you have a part number for the large o ring you sent me?
 Old 12-01-2013, 03:02 PM   #5
hnda etr's Avatar
Groans: 90
No sorry. That actually came from Brydon at Corksport. He sent a couple to me.
 Old 12-02-2013, 05:54 AM   #6
crutch77's Avatar
Nice! Do you think Brydon might be willing to help us out with the other o-ring (the mid-sized one that goes on the 18mm nut assy) and maybe even a spring? The random person I got with Corksport customer service was not inclined to help...
 Old 12-03-2013, 06:33 PM   #7
hnda etr's Avatar
Groans: 90
Originally Posted by SFWD 1934 View Post
hnda etr;
Is this the one you have? I must be blind because I did not see it
6540K121
Double seal viton fluoroelastomer
Cross reference over to Grainger as:
3CRT2 (pack of 5) for $10.63
Also found them at:
ww.theoringstore.com for .36 cents each for 1-24, 0.18 cents for 25-99 (that is the QR NBR (nitrile rubber).
These are in inner small o ring that the piston shaft makes contact with. Let me measure and verify the outer o ring that is on the 18MM hat.
Jason
In the below post # 18
 Old 12-20-2019, 01:49 PM   #8
MS3NOOBIE's Avatar
Posts: 1   (View Stats)
MS3NOOBIE is on a distinguished road
Default Still have some?
I’m having the same problem.
MS3NOOBIE is offline   Reply With Quote
The Following User Says NO Thank You to MS3NOOBIE For This Un-useful Post:
Db09ms3 (12-23-2019)
 Old 12-21-2019, 03:01 PM   #9
Posts: 2,825   (View Stats)
You have another problem: Trying to activate a four year old dead thread. People in that thread are no longer following it and probably don’t even own their cars anymore. Best to start a new thread.
Most auto parts stores carry a wide variety of o-rings. Just take your pump in and get them to match up the o-rings to your old ones. Ain’t rocket science.
HPFP internal question??? chris.s.85 2010 MS3 - Troubleshoot/Diagnostics 6 09-26-2013 08:30 AM
Fuel pump internal/HPFP,really necessary? RMCAT MazdaSpeed 6 - Engine, Transmission & Driveline 13 08-09-2013 09:22 AM
Hpfp internal/Cobb ap question maddocx240 Mazdaspeed3/6 General Discussion 24 04-29-2012 09:30 PM
Page generated in 0.32127 seconds with 24 queries
