 Old 01-28-2020, 06:13 PM   #1
ctkao2112's Avatar
Posts: 3   (View Stats)
ctkao2112 is an unknown quantity at this point
Default JDM engine swap. Will it pass CA emissions?
Blew up my engine, so I'm planning to buy a JDM engine with 50k miles and swap that in. It's a long block, with turbo and all accessories included, so it *should* be an easy drop in. Will it pass California emissions? For example, EGR? Anything else I should ask the seller before committing to the purchase? Can someone who has done this before share their experience? Somehow I cannot find many posts on this...
ctkao2112 is offline   Reply With Quote
 Old 01-29-2020, 06:49 AM   #2
LenSpeed6's Avatar
Posts: 164   (View Stats)
is there really any difference with a jdm engine with these cars?
people part these cars out like they are going out of style, you should be able to find something here.
06 Speed6
White/Black interior
 Old 01-29-2020, 10:22 AM   #3
Posts: 2,235   (View Stats)
experiences with JDM engines could be win or fail as like any other used engine bought without warranty...
I got 2x KL from them in Canada, the first one was better but both times i had surprises later on....Not the performance cams expected. Got a very used engine the second time and get it replaced after almost a fight and got one without performance head nor the cams....
Those was without emission but we talk about more than a decade ago.....
You could take no chances and swap everything electronics from your old engine to make sure it will work.
And I would check the timing chain and bender at bare minimum and probably think about putting a new chain/VVT in it while the engine is out of the car....
If you look for a cheap option, getting one from a junkyard with a minimum warranty is probably the best one over jdm...
For JDM story, I even saw a guy looking for the reason why is jdm kl engine wasn't performing and figured out he got a 2.0l instead of a 2.5... This was for KL engines but i did see some 2.0l with direct injection from overseas....just make sure you really get a 2.3l turbo engine, nothing else....My experience let me learn that they can go very far to make money...
 Old 01-29-2020, 06:09 PM   #4
SaveMelMac's Avatar
Posts: 485   (View Stats)
Swap over all your electronics, smog nazis won’t know the difference if there are any with this “JDM” engine.
Engine swap help Lilrobbie1127 Mazdaspeed3/6 General Discussion 3 10-11-2017 12:38 PM
Help me pass IL Emissions (O2 Sim?) Alpha MazdaSpeed 3/6 - Troubleshoot/Diagnostics 48 12-08-2014 07:36 PM
Need to pass emissions with EGR delete aviator79 Mazdaspeed3/6 General Discussion 7 08-10-2012 11:44 PM
Pass. side engine mount... ATE BALLER MazdaSpeed 6 - Engine, Transmission & Driveline 59 08-06-2008 01:28 PM
Page generated in 0.24717 seconds with 23 queries
