 Old 06-20-2011, 10:04 PM   #1
holeinmypocket's Avatar
Posts: 1,129   (View Stats)
holeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the world
Default Look At My Crankshaft
See how the gear for the balance shaft is off center on the crankshaft. What can I do to get the gear back in place so that it is balanced when the machine shop balances it? I won't be running the BSD but I think that if you took that gear off it would make the crank unbalanced.
holeinmypocket is offline   Reply With Quote
 Old 06-20-2011, 10:12 PM   #2
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
you cant if you go through that trouble get a new crank made custom
i simply had my whole crank balanced with it on
Last edited by Nitr0EngiE; 06-20-2011 at 10:12 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-20-2011, 10:14 PM   #3
right...i want to just get it balanced with that gear on but how am i going to get that gear to sit flushly on that crankshaft? like use a big machine press to press it on there like what they do with wheel bearings etc?
 Old 06-20-2011, 10:16 PM   #4
Daily Driver
Nitr0EngiE's Avatar
people dont do it you just balance it without balance shaft otherwise its said only mazda can do it with special tool or some shit just leave it out and run an extra quart of oil
i run 7 quarts now
 Old 06-20-2011, 10:24 PM   #5
i wonder if i take it off if it would effect the balance of the crank though...i guess there is only one way to find out
looking to get DJ's torque plate in sometime next week after he sends it to me...then very shortly my motor can be assembled and thrown into the car which has been empty like this for two years..
Last edited by holeinmypocket; 06-20-2011 at 10:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-20-2011, 10:34 PM   #6
Daily Driver
Nitr0EngiE's Avatar
no what you do is send the crank to machine shop and they blance it and you blance the rods and pistons as well then its all balanced ... then there is no need for the shaft.
the BS is there because not every factory motor has pistons rods and crank weighed so they use that to kinda make up for it. get motor balanced you really need to
they weigh every piston alone and make them all the same weight
then each end of the rod gets weighed and matched to lowest weight
then they spin the crank on a machine similar to tire balancing and drill some material until its balanced
shit man i even think they weighed my harmonic balancer and my flywheel was balanced by spec when i sent them my fidanza
Last edited by Nitr0EngiE; 06-20-2011 at 10:34 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Nitr0EngiE For This Useful Post:
holeinmypocket (06-20-2011)
 Old 06-21-2011, 05:09 AM   #7
cut that ring off. its not fused to the crank and if u dont have a BSD you dont need it. i wouldent have any unnecessary weight on the crank that u dont need esp if its off center like that.
FORZDA 1 (06-27-2011)
 Old 06-21-2011, 11:19 AM   #8
I am sure though once its off its going to effect the balance and rotation of the crankshaft..
 Old 06-21-2011, 11:41 AM   #9
no that ring is already perfectly balanced. a couple people even cut theirs off while doing the BSD. plus your getting your crank balanced afterwards right?
 Old 06-21-2011, 12:51 PM   #10
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Less rotating mass is always better...
The machinist shouldn't have any trouble correcting what little imbalance removing that gear creates...
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
holeinmypocket (06-21-2011), superskaterxes (06-21-2011)
 Old 06-21-2011, 09:19 PM   #11
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I would say that it would be more off balance being off center like that. Ide cut it off.
2006 Mazdaspeed 6
 Old 06-22-2011, 08:48 PM   #12
Boother's Avatar
Posts: 139   (View Stats)
Boother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant futureBoother has a brilliant future
Actually, you are incorrect. The balance shafts have NOTHING to do with the balance of the rotating assembly.
The purpose of the balance shafts is to cancel the inherent second order vibrations created by an inline 4 engine. That is why they rotate at twice crank speed too.
Even if your rotating assembly was perfectly balanced to the microgram, you would still have this inherent flaw in an inline 4.
Boother is offline   Reply With Quote
The Following 5 Users Say Thank You to Boother For This Useful Post:
Fobio (06-24-2011), FORZDA 1 (06-27-2011), kmac (06-26-2011), Nitr0EngiE (01-25-2012), silvapain (06-22-2011)
 Old 06-24-2011, 02:21 PM   #13
awesome just got comfirmation from Costa Mesa R&D Automotive Machine Shop that i can just knock that gear off the crankshaft...now to find a place locally that will check out my crankshaft...fuck
 Old 06-24-2011, 03:43 PM   #14
Tech/Sales@EM's Avatar
Posts: 1,173   (View Stats)
Tech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the world
Groaned at 28 Times in 11 Posts
Yeah I plan on taking off that stupid gear once I do a build. Ive held the crank in hand many years ago and I remember it being ~28lbs. Ridiculous weight actually. A billet crank on this car would go a long way.
Tech/Sales@EM is offline   Reply With Quote
 Old 06-26-2011, 08:48 AM   #15
Speeeeeed
06Speed6's Avatar
Try picking up a v8 crank lol, 28lb is pretty light. The crankshaft is one place where I dont mind alot of weight.
2006 Mazdaspeed 6
 Old 06-26-2011, 11:02 AM   #16
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
drop forged carbon titanium crank ftw.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-26-2011, 03:31 PM   #17
On the contrary try picking up a billet aluminum crank
 Old 06-27-2011, 10:12 AM   #18
Boother's Avatar
I really hope you are joking....
 Old 06-27-2011, 11:03 AM   #19
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
My crank will not go back in with that worthless gear attached. Just cut it off and be done with it, no re-balance necessary. It is ROUND and circumvents the entire crank, so there is NO (measureable) balance impact. Just think about it for a few seconds. Even the best balancing rigs only measure to around 1/10th gram, or about 1 tooth on the gear.....
FORZDA 1 is offline   Reply With Quote
The Following User Says Thank You to FORZDA 1 For This Useful Post:
holeinmypocket (06-27-2011)
 Old 06-27-2011, 05:09 PM   #20
 Old 06-27-2011, 05:39 PM   #21
Dont know how ballz to the wall some of you guys are but I always WPC treat my cranks. I can do the same for anyone interested as well.
Crankshaft specs??? holeinmypocket MazdaSpeed 3 - Engine, Transmission & Driveline 3 07-13-2010 07:18 PM
Crankshaft End-Play Tolerance pbblaster MazdaSpeed 3 - Engine, Transmission & Driveline 0 06-18-2008 08:08 PM
Page generated in 0.41188 seconds with 28 queries
