 Old 09-19-2017, 05:21 PM   #1
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Default Looks like Autozone now can rent the CRANK pulley tool
So, I went to autozone because I needed a pilot bearing puller. Looks like they have the crank tool.
Someone still needs to verify it will work but it should.
And here it is on amazon for $50 https://www.amazon.com/CTA-Tools-102...er+puller+1025
 Old 10-12-2019, 12:31 PM   #2
DOS GRID's Avatar
Posts: 2   (View Stats)
DOS GRID will become famous soon enoughDOS GRID will become famous soon enough
Nope! Picked it up last night ($30). You would need to shave about 1/4" off of each post on the tool making the major diameter smaller. But that is probably what I will do considering the price and 30 minutes of work for a custom tool!
DOS GRID is offline   Reply With Quote
The Following User Says Thank You to DOS GRID For This Useful Post:
Db09ms3 (10-12-2019)
 Old 11-17-2019, 12:08 PM   #3
DOS GRID's Avatar
With some modifications you can make it work. You will need an offset grinder with a grinding wheel and bring each peg down to 14-14.25 mm. Its hard to see in the pics, but I did add a radius to each corner also. Fits like a glove.
Db09ms3 (11-18-2019)
Mazda crank pulley tool vs Ford crank pulley tool SPEED6 KILLAH MazdaSpeed 6 - Engine, Transmission & Driveline 52 03-11-2017 09:46 AM
Crank Pulley Tool maisonvi Mazdaspeed 3/6 Hardparts (2006-2013) 25 03-17-2016 06:04 AM
Looking to borrow crank pulley tool! Elrodd MazdaSpeed 6 - Engine, Transmission & Driveline 1 01-01-2016 07:34 AM
Page generated in 0.23580 seconds with 22 queries
