 Old 10-07-2019, 05:29 PM   #1
Ced2142's Avatar
Posts: 10   (View Stats)
Ced2142 will become famous soon enough
Default Main bolt torque procedure
Hey guys,
Anyone here built an engine with the OEM main bolts?
The assembly manual indicates to oil the bolts before torquing. My question: Should i completely submerge the bolts in oil? As in threads and bottom of the head of the bolt? Reason I ask is because i am aware that oil on the threads will change torque specs and I don't want to screw up this part by over/under torquing. Also, I did some reading and heard that the OEM mains should be ok for a sub-400 Hp application. Anyone able to confirm this?
06 MS6; Cpe catted dp; HSK BPV; 3" Catback; K&N intake
Build in progress -> 07 MS6; Supertech 4032 pistons; Manely H beam rods; bnr s4;
Ced2142 is offline   Reply With Quote
 Old 10-08-2019, 06:48 AM   #2
Posts: 2,235   (View Stats)
oem main aren't a problem for 400....rods are more sensitives and head bolts...
You either don't want to have thread friction to limit clamping force and you don't want the hole to have oil in the hole that limit the bolt from going down...
I use oil but i sink the bolt in it and let it drop or wipe any excess. i don't put any oil in the thread hole...This worked fine for few engines and i did see my machinist using special grease where it was critical....
Maybe @MSMS3 can comment about the right technique
Ced2142 (10-10-2019)
Turbine Tech forward diff mount bolt & torque help Izapyou MazdaSpeed 6 - Engine, Transmission & Driveline 1 03-13-2019 05:56 PM
The correct procedure for bleeding brakes KNS Brakes MazdaSpeed 3/6 - Suspension & Brakes 24 07-15-2013 10:51 AM
bnoon oil restrictor bolt torque specs Chicagospeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 7 11-11-2012 09:15 PM
A few problems with Cobb's suggested maf cal procedure djuosnteisn
Cobb ATR Support
5 01-14-2010 08:55 AM
ARP main torque spec 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 5 03-10-2009 06:22 AM
Page generated in 0.24534 seconds with 21 queries
