 Old 11-17-2010, 04:40 PM   #1
relenger's Avatar
Posts: 17   (View Stats)
relenger will become famous soon enough
Default Mazda3 Crank vs Speed3 Crank
Hey fella's new here and too mazda's. I'm helping my buddy build a spare motor he has. It's a 2004 Mazda3 2.3L engine, Now his crank is shot and they want 1200 for a new one and its cast. Good for what? 300HP???? I have been searching around and cant seem to figure this out>> So here are few Q's for you guys.
Found The Answers to some
1. Is the speed3 Crank Forged?? YES
2. How much HP can a Speed3 crank take before breaking??
3. Is there a crank that can hold upto 700ish HP other then the Billet one for $3400??
4. other then the rod journals being bigger on the speed 3 crank will the crank fit a mazda3 2.3L??? YES it bolts right in!! The rods journals are bigger on the speed3 Crank
Any help would be awsome
relenger is offline   Reply With Quote
 Old 11-17-2010, 05:38 PM   #2
speed23's Avatar
Posts: 1,480   (View Stats)
Yes its forged, and I dont think we know the limit cause nobodys busted one. Not sure about your other questions.
 Old 11-17-2010, 05:39 PM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The rod and main journals on the ms3 crank are both larger and the ms3 crank may have a bigger stroke, I cant remember what the stoke is for the 2004 2.3l
The ford ranger 2.3l crank was/is forged and should a bolt in.
2006 Mazdaspeed 6
 Old 11-22-2010, 01:48 PM   #4
relenger's Avatar
Accourdint to my Mazda speed3 spec sheet (right from Mazda who sponsors are schools race speed3s) Its showin the mains as the same size as the mazda3..... the rods look to be bigger but no big deal. Looks like the crank throw is also the same.... HHHmmmm???????
 Old 11-22-2010, 03:23 PM   #5
Speeeeeed
06Speed6's Avatar
The speed 3 crank specs:
The block/girdle ID is ~58.42mm or ~2.3"
The crank main OD is 2.045"
Crank main available width on crank .835"
Crank main bearing width .747"
Main bearing thickness ... I forgot to get... I think its ~.115" but im prolly wrong.
Rod ID 2.16"
Crank rod OD 2.045"
Rod bearing width .655"
Rod bearing thickness .055"
Rod bearing available room on rod .78"
Rod bearing available width on crank .665"
Those are approximate because every crank and bearing is slightly different.
2006 Mazdaspeed 6
 Old 11-23-2010, 02:23 PM   #6
relenger's Avatar
Thanks for the info... Any guys with 600hp steet driven car?
 Old 11-23-2010, 02:26 PM   #7
TRex's Avatar
Posts: 3,139   (View Stats)
.................................................. ..........why not just buy a speed3............................................ ...........
The Following User Says Thank You to TRex For This Useful Post:
BrianZX10R (11-23-2010)
 Old 11-23-2010, 02:28 PM   #8
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
You should get sponsored by Oxford Dictionary so you can learn sum engrish ski11z
MS33SM is offline   Reply With Quote
The Following 3 Users Say Thank You to MS33SM For This Useful Post:
gtarman77787 (11-23-2010), kgb (12-03-2010), ZipprSuitdSungod (11-29-2010)
 Old 11-23-2010, 02:47 PM   #9
m4tic's Avatar
Posts: 4,928   (View Stats)
lol
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following 2 Users Say Thank You to m4tic For This Useful Post:
Dash08 (11-28-2010), SIXual Panda (12-19-2010)
 Old 11-23-2010, 03:15 PM   #10
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I think a guy called Cagey has one.... Wait, no, nevermind. He just wanted one.
essejkcamraw (11-23-2010), SIXual Panda (12-19-2010), spoolin00 (11-29-2010)
 Old 11-23-2010, 05:50 PM   #11
Amazon's Avatar
Posts: 2,679   (View Stats)
Groans: 214
Xtremeboost is suppose to be bringing us a 600 hp one....
Amazon is offline   Reply With Quote
 Old 11-24-2010, 02:59 PM   #12
relenger's Avatar
I could care less how stuff is spelled... So 600 must be a hard number to reach??
 Old 11-24-2010, 03:27 PM   #13
gaoes's Avatar
Posts: 66   (View Stats)
gaoes is just really nicegaoes is just really nicegaoes is just really nicegaoes is just really nicegaoes is just really nice
this far i think cagevet has only gotten ~550 and i think he only did it once. but i stopped checking that thread a while ago because theres too many posts in it for me to care anymore lol. if you're ambitious enough though, i say go for it.
2008 true red MS3
gaoes is offline   Reply With Quote
 Old 11-28-2010, 11:52 AM   #14
relenger's Avatar
We are We are.... The speed3 is direct cylinder injection right?? How are you guys tuning? Handheld?
 Old 11-28-2010, 12:03 PM   #15
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Not really.
It comes right after 599
neotide87 (11-29-2010)
 Old 11-29-2010, 03:00 PM   #16
relenger's Avatar
Not really.
LMAO.... yeah yeah
The Following User Says Thank You to relenger For This Useful Post:
Tomas (11-29-2010)
 Old 11-29-2010, 03:04 PM   #17
MS33SM's Avatar
Groans: 132
I usually tune my car using a harmonica cause I'm tight like that. It may be the reason my g string is a little flat when I go wot.
The Following User Says Thank You to MS33SM For This Useful Post:
Tomas (11-29-2010)
 Old 11-29-2010, 04:35 PM   #18
Bob Ross Fanclub
Tomas's Avatar
similar problem here. My slingshot needs retuning. Too jammed at part throttle.
 Old 11-29-2010, 04:40 PM   #19
ZipprSuitdSungod's Avatar
Posts: 497   (View Stats)
ZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the world
Groans: 68
Evidently an attitude way too common among too many young Americans. Enjoy your job flipping burgers.
ZipprSuitdSungod is offline   Reply With Quote
 Old 11-29-2010, 05:02 PM   #20
spoolin00's Avatar
spoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the world
eye kan haz inglish lezzonz? aye
-2006 BCM Speed6
--SRI
I'm hoping this turbo is big enough to bring sea level to me.
spoolin00 is offline   Reply With Quote
 Old 11-29-2010, 05:21 PM   #21
Groans: 68
ROFL
 Old 12-01-2010, 12:50 PM   #22
relenger's Avatar
Im not sure that 28yrs old and 45,000 a year is young or a burger job...
I see this must be a kiddie forum?? Im not here to talk trash or be a a$$ hole to anyone.
Simple questions... if you cant answer them then please dont bother to post...
 Old 12-01-2010, 01:04 PM   #23
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
yes...we iz kiddiez 4um.
You want answers tho, be an active part of the community, you get out what you put in here. If you're not willing to do that...go fuck yourself and good luck finding info elsewhere.
 Old 12-01-2010, 01:16 PM   #24
TRex's Avatar
24 and 61k...now whose dick is bigger?
 Old 12-01-2010, 08:51 PM   #25
overdrift's Avatar
Posts: 93   (View Stats)
overdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant future
Groaned at 6 Times in 4 Posts
Something is wrong on the internet.
overdrift is offline   Reply With Quote
The Following User Says Thank You to overdrift For This Useful Post:
06Speed6 (12-02-2010)
 Old 12-02-2010, 02:39 PM   #26
relenger's Avatar
Thank you for pointing out nothing
 Old 12-02-2010, 03:01 PM   #27
XLT_66's Avatar
Posts: 850   (View Stats)
I don't think he gets it.
1. He thinks he's doing pretty well for himself considering his lack of spelling skills. (Hell, maybe he is; I'm not sure I know anyone else who can't spell to compare salaries to.)
2. He does't take to dick-ish sarcasm very well.
Welcome to the forum buddy. Now DONATE!
2009 CWP MS3 Sport
SOLD!
XLT_66 is offline   Reply With Quote
 Old 12-03-2010, 06:16 AM   #28
relenger's Avatar
Your right! but why would i donate when it goes in one ear and out the other?
Pointless, as is this thread
and when did i say " He thinks he's doing pretty well for himself considering his lack of spelling skills"???
Imagine if i could spell..
"2. He does't take to dick-ish sarcasm very well."
Grow up!! do you see your parents talking like retards to one another?? Im here to help a local mazda3 guy get his car together!!! i think im donating RIGHT there!! i could care less about a speed3!! i got two SRT's that are faster in stock form then a modded speed3... Im not big into getting grocerys
The Following 2 Users Say NO Thank You to relenger For This Un-useful Post:
I Love Brownies (12-07-2010), tbot (12-03-2010)
 Old 12-03-2010, 08:01 AM   #29
bcmountainspeed's Avatar
Posts: 361   (View Stats)
bcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the world
then why the fuck are you on a speed forum?
41000 hahahaha I pay that in taxes little fella
bcmountainspeed is offline   Reply With Quote
 Old 12-03-2010, 01:00 PM   #30
relenger's Avatar
im trying to HELP a guy with a mazda3 thats putting a turbo on it.
if you pay more then that in taxes then why are you driving a speed3??? are you budget challenged???
 Old 12-06-2010, 10:15 PM   #31
TRex's Avatar
1. the amount of dough it would take to make a n/a speed remotely fast would greatly exceed that of a stock speed 3...and it would still be slow
2. maybe he realizes the value of a speed 3 and because he understands the value of items is the reason he has so much money
3. fuck off brownie
The Following 2 Users Say Thank You to TRex For This Useful Post:
Cataphract_40 (12-06-2010), SIXual Panda (12-19-2010)
 Old 12-06-2010, 10:21 PM   #32
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Originally Posted by TRex View Post
3. fuck off brownie
this
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 12-06-2010, 10:46 PM   #33
meh, no ideas
Jedyboyrokr's Avatar
Posts: 528   (View Stats)
Jedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the world
Groaned at 20 Times in 4 Posts
oh dear lol lets move on....im not much help but the highest ive seen personally is jwilkens88 on here who dynoed 410 i believe on stock internals ..... oh and btw dont take anything personally on here. welcome and GL......oh and one more thing, its cool if you wanna go for a NA-T Mazda 3 its cool to be different lol
89 toyota supra 1JZ Twin Turbo---Sold
2006 MS6 GT few mods ---Sold
Monaco White '13 Genesis 2.0T R-Spec-- ISIS downpipe/testpipe, Agency Power CBE, Injen SRI, Forge BOV, JBR Heavy Shift knob should be 240ish wheel right now, tune coming April 27th
Jedyboyrokr is offline   Reply With Quote
 Old 12-06-2010, 10:56 PM   #34
theschrum's Avatar
Posts: 1,031   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
Maybe you should try posting this on mazdas247.
06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block...
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
 Old 12-07-2010, 02:32 PM   #35
relenger's Avatar
I found a local guy who is big into mazda's. Thank you to all the guys who helped
06Speed6 (12-07-2010)
 Old 12-07-2010, 02:42 PM   #36
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
Groans: 371
 Old 12-19-2010, 08:22 AM   #37
relenger's Avatar
I got ahold of a speed3 Crank and it bolted right in!!!
Power at the crank - after tuning bcmps MazdaSpeed 3/6 - Dyno Sheets/Discussions 2 08-17-2009 09:11 AM
Crank gear & BSD info 06Speed6 Mazdaspeed3/6 General Discussion 85 04-04-2009 10:19 AM
Crank case filter? Element MazdaSpeed 3 - Engine, Transmission & Driveline 4 03-09-2009 07:37 PM
Page generated in 0.53550 seconds with 39 queries
