Like Tree9Likes
 Old 10-19-2008, 06:06 PM   #41
Boosted333's Avatar
Posts: 75   (View Stats)
Boosted333 is a jewel in the roughBoosted333 is a jewel in the roughBoosted333 is a jewel in the roughBoosted333 is a jewel in the rough
Doesn't the manual say 7,500 miles? I figured with a good synthetic I'd be fine. I think i'm going to stick to about 5,000 miles or so from now on.
Dan L.
'08 Mazdaspeed3
Cobb SRI/AP/DP, TurboXS FMIC
Custom tune from EFI Logics
Boosted333 is offline   Reply With Quote
The Following User Says Thank You to Boosted333 For This Useful Post:
Speed13 (12-31-2016)
 Old 10-20-2008, 05:34 AM   #42
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Originally Posted by Frequentflyer View Post
SLS, what are your commuting habits? Lots of highway, city or a mix?
I drive around 70 miles a day during the week, with a nearly 50/50 mix of highway and city driving. I do slightly more highway driving, but it's a negligible amount.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 10-20-2008, 05:51 AM   #43
Originally Posted by xcoldricex View Post
thanks to everyone who posted UOA's.
hal did you ever get some RP tested?
Im sending off my sample tomorrow when i change to the PP 5/40
 Old 10-20-2008, 05:53 AM   #44
Wow Boosted, 7355 miles between changes. You're brave.
Seems like 5-6k is the sweet spot.
I've got a sample kit on the way to me and will be sending them off some of my Rotella T syn 5w-40 soon.
Ive heard good things about the Rotella.. if your samples come back on par with the PP, ill probably switch. It costs me $60 to get 6 qts of PP 5/40 Euro blend.
 Old 10-23-2008, 08:20 PM   #45
MadOzodi's Avatar
Posts: 686   (View Stats)
First oil change was just under 1,500 miles...used Mobil 1 then and for the next 2 oil changes at roughly 5k and 10k miles up until 14,987 miles when I switched to PP 5w-30.
"Nothing too unusual showed up in this first sample from your Mazda (Matsuda in Japan). Universal averages show typical wear from this type of engine after 4200 miles on the oil. Iron was a bit higher than average, but all other wear looks okay, so we don't think this shows a problem developing. We'll watch iron next time. You ran the oil longer and this caused some of the high iron. The viscosity was a little low, but not low enough to affect wear. The TBN was 3.9; additive life remained. We think 1.0 is too low for extended use. Resample @ 4K miles to keep iron at bay."
Miles on oil - 5,124
Miles on engine - 20,021 (at time sample was taken)
Date sampled - 09/20/08
Make Up Oil Added - 0.0 qt.
OEM Mazda Filter
Pennzoil Platinum 5w-30
Aluminum - 4
Chromium - 1
Iron - 34
Copper - 13
Lead - 1
Tin - 0
Molybdenum - 51
Nickel - 0
Manganese - 1
Silver - 0
Titanium - 0
Potassium - 0
Boron - 25
Silicon - 5
Sodium - 2
Calcium - 2590
Magnesium - 14
Phosphorus - 593
Zinc - 735
Barium - 0
Sus Visc @ 210F - 54.4 (should be 56-63)
cST Visc @ 100 C - 8.59 (should be 9.1-11.3)
Flashpoint in F - 410 (should be >365)
Fuel % - <0.5 (should be <2.0)
Antifreeze - 0.0
Water % - 0.0 (should be <0.1)
Insolubles % - 0.3 (should be <0.6)
TBN - 3.9
spals likes this.
07 COSMIC BLUE MS3 GT
MadOzodi is offline   Reply With Quote
The Following User Says Thank You to MadOzodi For This Useful Post:
div2 (10-24-2008)
 Old 01-25-2009, 09:37 AM   #46
div2's Avatar
Posts: 273   (View Stats)
div2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the world
Groans: 57
Here are the results of my last two UOAs- along with Blackstone's comments. I'm still running Mobil 1 5W-30.
"Everything looks good in the latest sample from your Mazda. Silicon finally reads close enough to average levels that we can consider it normal, and no other harmful contaminants were found. Iron is still a bit above average but all wear has been steadily moving in the right direction. It took a little longer than usual for your engine to mature past break-in but better late than never. This oil still had some active additive left in it with a TBN of 3.4. 1.0 is low. It looks like you're going to keep your oil runs around 5,000 miles and we think that's working well for you."
Miles on engine 25109
Miles on oil 4989
Date sampled 10/06/08
Make Up Oil 0.0 qt.
OEM Mazda Filter
Mobil 1 5W-30
Aluminum 4
Chromium 1
Iron 27
Copper 5
Lead 0
Tin 1
Moly 97
Nickel 0
Manganese 0
Silver 0
Ti 0
Potassium 2
Boron 53
Silicon 7
Sodium 7
Calcium 2365
Magnesium 13
Phosphorus 627
Zinc 832
Barium 0
Sus Visc @ 210F- 55.5 should be 55-62
cST Visc @ 100C- 8.92 should be 8.8-11.1
Flashpoint in F-385 should be >365
Fuel %- <0.5 should be <2.0
Antifreeze 0.0
Water % 0.0 should be <0.1
Insolubles % 0.4 should be <0.6
TBN 3.4
"Wear and silicon dropped in this sample, which was run about the same miles as you've been using for your Mazda. Compare this sample to universal averages and you can see that your engine is wearing normally, so we think you could easily run the oil longer, if you want. Averages are based on 4,130-miles on the oil. You were up to 5,182-without incident. No moisture, fuel, or coolant found. Insolubles (oil oxidation due to heat, use and blow-by) were okay at 0.4%, showing good oil filtration. The TBN was 3.8, good to go for more miles."
Miles on engine 29870
Miles on oil 4546
Date sampled 1/13/09
Make Up Oil 0.0 qt.
OEM Mazda Filter
Mobil 1 5W-30
Aluminum 2
Chromium 1
Iron 25
Copper 2
Lead 1
Tin 1
Moly 82
Nickel 0
Manganese 0
Silver 0
Ti 0
Potassium 0
Boron 46
Silicon 5
Sodium 16
Calcium 2165
Magnesium 13
Phosphorus 583
Zinc 730
Barium 0
Sus Visc @ 210F- 57.2 should be 55-62
cST Visc @ 100C- 9.43 should be 8.8-11.1
Flashpoint in F- 385 should be >365
Fuel % <0.5 should be <2.0
Antifreeze- 0.0
Water %- 0.0 should be <0.1
Insolubles %- 0.4 should be <0.6
TBN- 3.8
Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts
Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II
Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs
Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust
div2 is offline   Reply With Quote
 Old 01-26-2009, 03:36 PM   #47
dirtyspeed3's Avatar
Posts: 78   (View Stats)
dirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond repute
Groans: 35
Sending my break in oil w/1100 miles on it just to see how bad it is. Next sample will be in ~1500 miles (which will be 5k on the odometer). I have Motul 8800 in right now, curious to see how it handles everything. Will post results.
dirtyspeed3 is offline   Reply With Quote
 Old 01-29-2009, 06:51 PM   #48
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
I've got a bottle of Rotella T Syn 5W-40 waiting to be mailed to Blackstone. I'll probably get it out tomorrow, so stay tuned for a UOA for Rotella.
 Old 02-02-2009, 03:31 PM   #49
Groans: 35
Just got my sample back from Blackstone. Some of the values are pretty high, but it was the break in oil changed out early. Glad to see the fuel was not obnoxious, hopefully it stays that way.
Stock 09 MS3
The Following User Says Thank You to dirtyspeed3 For This Useful Post:
Dash08 (05-15-2009)
 Old 02-02-2009, 10:29 PM   #50
udontknowjack's Avatar
Posts: 201   (View Stats)
udontknowjack has a spectacular aura aboutudontknowjack has a spectacular aura about
did you ever get the result back hal??
udontknowjack is offline   Reply With Quote
 Old 02-05-2009, 06:48 PM   #51
Ok, here's my first UOA on my Speed using Rotella T Syn 5W-40. This was my second fill using the Rotella. Looks like I'll continue to use it. Note the high phosphorus and zinc levels that are common with heavy duty oils like Rotella. They are anti-wear additives and detergents. Not sure why my magnesium level is so damn high, but they didn't say it was bad, so I'm not going to worry about it.
MI/HR on Oil = 5,000
MI/HR on Unit = 16,500
Sample Date = 1/28/09
Make Up Oil Added = 0
Universal Averages shown in ( x )
ALUMINUM = 2 (3)
CHROMIUM = 0 (1)
IRON = 12 (18)
COPPER = 28 (23)
LEAD = 1 (1)
TIN = 0 (0)
MOLYBDENUM = 55 (68)
NICKEL = 0 (0)
MANGANESE = 0 (0)
SILVER = 0 (0)
TITANIUM = 0 (0)
POTASSIUM = 0 (0)
BORON = 30 (45)
SILICON = 4 (5)
SODIUM = 4 (26)
CALCIUM = 852 (2,337)
MAGNESIUM = 941 (83)
PHOSPHORUS = 870 (645)
ZINC = 1006 (779)
BARIUM = 0 (0)
SUS Viscosity @ 210°F = 65.9 (65-78)
cSt Viscosity @ 100°C = 11.86 (11.6-15.3)
Flashpoint in °F = 350 (>375)
Fuel % = 1.3 (<2.0)
Antifreeze % = 0.0 (0)
Water % = 0 (<0.1)
Insolubles % = 0.3 (<0.6)
TBN = 4.9
COMMENTS: Nothing too unusual showed up in the initial sample from your Mazda. All wear read at or below averages, which is a very good indication of normal wearing parts, especially since this oil was run a little longer than average. Universal averages show normal wear after ~4,100 miles use on the oil. Fuel dilution was found at 1.3%. This is below our problem level and since it didn't hurt the viscosity, we don't think it's a concern, but we will watch it next time. The TBN was strong at 4.9, so the oil has lots active additive left. 1.0 is low. Try 6,500 miles on the next oil.
The Following 2 Users Say Thank You to Frequentflyer For This Useful Post:
phillyb (06-02-2009), xcoldricex (05-09-2009)
 Old 02-06-2009, 11:40 AM   #52
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
Just wanted to thank everyone for posting UOA's. Keep in mind that not only do you aid others in picking oils, but every submission of a speed3/speed6 UOA, adds to the lab's database for what's considered "normal" or "average" helping us detect when problems might be occurring.
Remember if you want additional comments on your UOA's, post them to the bobistheoilguy.com forums!
Crossbow is offline   Reply With Quote
 Old 02-06-2009, 11:57 AM   #53
There is still traces of RP in my oil, so around March i can send a sample back. The cool thing is, they didnt charge me for the sample this time around because of that. This next sample will be completely flushed of RP to give me a good breakdown.
I want to see how the Rotella is doing since they are advising him to go 6500. Rotella is easier for me to purchase locally, then PP.
 Old 02-07-2009, 06:12 PM   #54
I'll probably go 5,000 mile again and get another analysis done before I start going higher. I don't want to bet everything on one analysis. Remember it's winter now. Much lower temps and oil cooling probably isn't a problem. Once summer roles around, I'm not about to go 6,500 miles on the oil.
 Old 02-07-2009, 06:59 PM   #55
Well i dumped my oil today and filled up with 5/40 PP once again. Im going to dump it at 3K and send it off. I will probably get a higher change interval, but since i have no issues getting my PP locally now, i will stick with it for the time being.
 Old 02-13-2009, 01:42 PM   #56
Nikolai's Avatar
Posts: 21   (View Stats)
Nikolai is a jewel in the roughNikolai is a jewel in the roughNikolai is a jewel in the rough
Here's my latest UOA, and first post for that matter. PP FTW!
Nikolai is offline   Reply With Quote
 Old 05-08-2009, 05:35 PM   #57
Here's my latest analysis. This is my 3rd pan full of Rotella T Syn. All I can say is I will definitely continue to use this oil. Look at that viscosity, flashpoint and TBN. There's definitely enough additive and viscosity to go abit more miles. I may try 6,000 miles next time, which will probably be the sweet spot for me.
OSN (11-17-2014), xcoldricex (05-09-2009)
 Old 05-09-2009, 03:20 PM   #58
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
thanks frequentflyer for both of the UOA's! looks like the rotella works well - probably start using that instead of pp 5w30
 Old 05-11-2009, 09:23 PM   #59
evidence's Avatar
Posts: 1,033   (View Stats)
The high manganese is from the 'Octanium' octane booster I've been using since I get crazy knock with the OTS for my mods. Working through it with ATR now and should be weened off it soon. Not sure why they didn't not engine miles.. I'm at 10k
Some things.
 Old 05-26-2009, 09:58 PM   #60
div2's Avatar
Groans: 57
My latest UOA:
The Following User Says Thank You to div2 For This Useful Post:
802MS3 (05-28-2009)
 Old 05-28-2009, 09:21 AM   #61
div2's Avatar
Groans: 57
Did you actually add 5.5 quarts of oil during the OCI?
 Old 05-28-2009, 03:03 PM   #62
evidence's Avatar
Oil change interval? No I have not had to top off at all, probably just a mistake on the report. I use ~5.5 when I do the changes.
Some things.
 Old 06-02-2009, 05:19 PM   #63
xEradx's Avatar
Posts: 25   (View Stats)
xEradx will become famous soon enough
Has anyone tried to just change the oil filter every 3k and send in the oil from the filter for a UOA, to see how long you can go on the same synthetic oil???
After reading this article I will post I was wondering how long I could go with my MS3. Right now I go 3.5k and change oil filter. Then at 7k change both oil filter & oil with synthetic.
Making Sense of Synthetic Lubricants -
All of the manufacturers of synthetic oil tout the benefits of reduced wear, more horsepower, lower operating temperatures, and improved fuel mileage. All of these benefits are derivatives of better cold flow characteristics and higher levels of friction reducing additives that are found in synthetic oils. I can confirm better cold driving characteristics, increased fuel mileage of nearly 10%, noticeably lower operating temperatures, better heat dissipation capability, and long term high temperature stability based on my own experience with synthetic lubricants. Are these benefits enough, however, to persuade average drivers to give up their trusted petroleum oils and pay the extra price for synthetics? Enthusiasts, yes. Average drivers, perhaps not. However, synthetic lubricants can endure extended drain intervals, which is a major consideration toward justification of the higher costs. This benefit is not widely promoted by the major oil producers most likely because they want you to pay a premium for their synthetic oils every 3000 miles just like their regular oils. Most companies don’t bother to tell you that synthetic oils are capable of going 25,000 miles or more without significant breakdown. One customer told me he drove his Toyota more than 50000 miles (with filter changes every 10000 miles) before oil analysis results told him it was time for a change. It is not uncommon for over the road truckers to go several hundred thousand miles between synthetic oil changes but it should also be noted that most are equipped with finer oil filtration devices than most passenger cars. The short trips and stop and go city driving that most of do is much tougher on motor oil than over the road highway driving. In fact, frequent short trips (2 miles or less) and stop and go city driving is considered by some raters as extreme and our cars need increased protection. Fortunately, we can achieve the superior protection and the economic benefits of synthetic oils while staying within the recommendations of our car manufacturers.
xEradx is offline   Reply With Quote
 Old 06-23-2009, 12:10 PM   #64
xEradx's Avatar
Originally Posted by Boosted333 View Post
Here's my oil sample analysis, from Blackstone labs. I had 7,355 miles with Amsoil Signature Series oil and a Wix oil filter, was still on break-in.
this is mine with almost same miles on oil.
The Following User Says Thank You to xEradx For This Useful Post:
802MS3 (06-23-2009)
 Old 06-23-2009, 12:25 PM   #65
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
^^this is nice to see, thanks for sharing. any mods on the car?
akurma likes this.
'08 CWP MS3 w/ T3 3071r
 Old 06-23-2009, 03:02 PM   #66
rabble rabble
802MS3's Avatar
Groans: 221
my analysis just got emailed to me. Looks decent. 15k on the car now. oil was PP 5w-40.
 Old 06-24-2009, 10:14 AM   #67
xEradx's Avatar
Not yet, Im paying off my credit card after being out of work last spring. Once that gets to $0 I will be getting a few like... CP-e nano, engine mount & DP. Cobb inlet & AP. Synapse BOV and I will stop there before I get too addicted to moding my car lol
 Old 06-24-2009, 10:18 AM   #68
xEradx's Avatar
Oh, also... I change my oil filter 1/2 way thru my oil life. So with this oil report I posted I changed the filter at 3.5k and then changed both at about 7k. So this time I will change filter at 4k and both at 8k.
 Old 06-26-2009, 11:56 AM   #69
xEradx's Avatar
Has any one used AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil in there MS3???
Also what are the benefits of using 5W-40 over recommended 5W-30??? - Plz don't respond to 2nd question unless you know your $hit.
 Old 06-26-2009, 11:59 AM   #70
rabble rabble
802MS3's Avatar
Groans: 221
for some people the heavier oil has stopped the smoking from the turbo
 Old 07-01-2009, 10:32 AM   #71
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
Heres my first oil change, done at 1000miles. Completely stock, no oil catch can. Next oil change will be at 3000miles.
Heres my second oil change, done at 3000miles. Mods are OCC, Cobb SRI, Cobb Inlet, Turbosmart BPV
nyghtryder is offline   Reply With Quote
 Old 09-27-2009, 11:56 AM   #72
zman's Avatar
Posts: 9   (View Stats)
zman is an unknown quantity at this point
Default 5/30 PP UOA
i am using 5/30 Penzoil Platinum.
Not happy with the lower viscosity results compared with other oils posted on this board.
below is the result of the second oil change on the car, showing the performance of PP.
MI/HR on Oil = 3891
MI/HR on Unit = 7330
Sample Date = 8/09
ALUMINUM = 3
CHROMIUM = 1
IRON = 14
COPPER = 111
LEAD = 3
TIN = 1
MOLYBDENUM = 48
NICKEL = 0
MANGANESE = 2
SILVER = 0
TITANIUM = 0
POTASSIUM = 1
BORON = 30
SILICON = 11
SODIUM = 2
CALCIUM = 2737
MAGNESIUM = 11
PHOSPHORUS = 638
ZINC = 736
BARIUM = 2
SUS Viscosity @ 210°F = 53.9 (56-63)
cSt Viscosity @ 100°C = 8.44 (9.1-11.3)
Flashpoint in °F = 390
Fuel % = <0.5
Antifreeze % = 0.0
Water % = 0
Insolubles % = 0.3
TBN = 4.5
zman is offline   Reply With Quote
 Old 09-27-2009, 01:37 PM   #73
nyghtryder's Avatar
Maybe Im missing something, but it doesnt look any better than the rest of the synthetic oils.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
 Old 11-16-2009, 10:38 AM   #74
xEradx's Avatar
Still wanting to know... Has any one used AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil in there MS3???
Thanks
 Old 01-10-2010, 06:51 PM   #75
shpankey's Avatar
Posts: 496   (View Stats)
out of curiousity.. are you getting the PP Euro Formula?
09 Speed 3 GT
shpankey is offline   Reply With Quote
 Old 02-17-2010, 04:19 PM   #76
shpankey's Avatar
Oil: 5 quarts of Pennzoil Platinum 5w-30 & .6 quart of Mobile 1 0w-30 (I had to do this).
Total Miles: 11,000
Miles on Oil: 2,700
Car: 09 Mazdaspeed 3 w/ mods: Cobb Short Ram Intake & Turbo Inlet Pipe, High-Pressure Fuel Pump Internals, Street Unit's Test (mid/race) Pipe, Step colder Denso Iridium Plugs w/ upgraded coil pack springs, CP-e Rear Motor Mount (60 dur),
Driven: Sometimes very hard. Maybe 10-15 full, hard pulls running through all the gears to redline. 60% highway 40% city. I have a daily commute of 20 miles all highway to work, and 20 miles back Monday through Friday. I did a few car warmups as temps have been near or below freezing this entire oil use.
Info: The reason for the short change of only 2,700 miles is b/c I've recently felt the car was "off" and not running near its potential after doing some of the upgrades. Worse than it was running before them. I don't know if this was just the cold weather or what but I was a little worried and wanted to make sure all was well. Also, as I didn't have a UOA on it yet, and I wanted to quickly get a baseline down and start moving the miles up. I will be running my current fill (German Castrol) for 4,200 miles so I can directly compare to the universal averages.
Filter was a Fram Cartridge.
09 Speed 3 GT
 Old 02-17-2010, 09:26 PM   #77
Why does it say Miles on Oil is 8,312 miles? Shouldn't it be 2,700? Seems to me they think you put way more miles on the oil than you actually did.
 Old 02-18-2010, 10:25 AM   #78
shpankey's Avatar
It's corrected now.
09 Speed 3 GT
 Old 02-19-2010, 12:30 PM   #79
shpankey's Avatar
This is one heck of an impressive UOA. Your silicon is high, which means you needed to change your air filter, which explains the higher than avg Iron. Despite that, you wear is great. If you had a clean filter, I'd dare say you'd have the best UOA of this engine I've ever seen.
The 40 weight Pennzoil Platinum perfectly sheared down to a high 30 weight. Which is awesome and I'm guessing exactly what you wanted. Any chance you have another new UOA with this oil? I'd love to see the numbers on a clean run with a good air filter, I'd bet they would be astonishing.
I'm going to compare my German Castrol run to this UOA and decide which one to go with. But I'm MIGHTY impressed with the PP 5w-40 Euro formula!!
Here's some online for those that are interested ($32 for 6 quarts)...
Pennzoil Synthetic 5W40 European Formulation - Case 6/1 Qt
Note these Euro formulations are made specifically for long drain intervals. This oil could go 7k miles easy, even on our engines.
09 Speed 3 GT
The Following User Says Thank You to shpankey For This Useful Post:
802MS3 (02-25-2010)
 Old 02-24-2010, 05:08 PM   #80
nyghtryder's Avatar
Third oil change still with mobil one 5W30(doesnt have averages because they renamed it to an 07 instead an 09, but they are fixing it)
Fourth I changed to mobil one 5W40
NATOR PA
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/mazdaspeed-3-6-uoa-results-20783/
Oil performance/quality - Page 4 This thread Refback 06-27-2014 12:50 PM
Oil for my Mazdaspeed3... | Passenger Car Motor Oil (PCMO) - Gasoline Cars/Pickups/Vans/SUVs | Bob Is The Oil Guy This thread Refback 12-09-2013 07:28 PM
Cobb downpipe mazdaspeed 3 launch control. This thread Refback 09-12-2012 04:45 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 06-17-2012 03:20 PM
Amsoil XL 5W30 7,100 miles Mazdaspeed 3 turbo - Bob Is The Oil Guy This thread Refback 04-20-2012 03:28 AM
Oil for my Mazdaspeed3... - Bob Is The Oil Guy This thread Refback 01-31-2011 06:49 PM
Amsoil XL 5W30 7,100 miles Mazdaspeed 3 turbo - Bob Is The Oil Guy This thread Refback 11-03-2010 12:36 PM
dyno results speedyhans MazdaSpeed 3/6 - Dyno Sheets/Discussions 11 01-11-2009 10:25 AM
My Dyno Results aaronc7 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 06-09-2008 09:44 AM
well, the results are in sleeper3 Drag Racing 52 05-05-2008 06:27 AM
Page generated in 0.59808 seconds with 37 queries
