 Old 04-25-2011, 06:54 AM   #1
Tech/Sales@EM's Avatar
Posts: 1,173   (View Stats)
Tech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the world
Groaned at 28 Times in 11 Posts
-You should unbolt both cams so the sprockets are loose (preferably)
-Put chain in place
-Pull tensioner pin
-Check for even tensioner in all parts of chain, up top in between the cams, below down by the oil pump sprocket
-With Cam alignment tool in place tighten the sprockets down
-Pull alignment tool. You will notice the exhaust cam stays 100% but the intake cam moves counterclockwise or in the direction of engine movement. <- Which I dont like. Stupid Mazda Engineers
-Preferably put crank sprocket in place and bolt it down lightly and rotate engine 2 full turns to check for valve clearance and at that time the tensioner may become more tense.
-Use impact or other method to break the crank sprocket loose and reinstall front cover or if timing is off repeat above procedure.
-Now with front cover in place install crank sprocket (making sure you place the sprocket in position for TDC!
-Reinstall all pulleys and belt as well as crank position sensor. Be mindful when installing and removing this sensor as it has the capability of advancing and retarding timing. It needs to be exactly where it was when you removed it.
Stealthvr4 likes this.
Tech/Sales@EM is offline   Reply With Quote
The Following 7 Users Say Thank You to Tech/Sales@EM For This Useful Post:
Juyoung (12-19-2012), Raider (04-25-2011), SJP0tato (04-25-2011), SKiZ0TT (12-20-2011), speed23 (04-25-2011), theschrum (06-06-2011), vbt101 (04-25-2011)
 Old 04-25-2011, 09:06 AM   #2
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
-Put chain in place
-Pull tensioner pin
This is the correct info ^^^^^. Your method set the cam timing pretty far off. I just hope your valve(s) didn't hit any of the pistons....
Note that you should use the old crank bolt and a few washers or a socket to space it out and have something to snug up to when rotaing the engine by hand.
FORZDA 1 is offline   Reply With Quote
The Following 2 Users Say Thank You to FORZDA 1 For This Useful Post:
SJP0tato (04-25-2011), vbt101 (04-25-2011)
 Old 04-25-2011, 09:35 AM   #3
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
1. Put chain in place
2. Pull tensioner pin
3. Check for even tensioner in all parts of chain, up top in between the cams, below down by the oil pump sprocket
4. With Cam alignment tool in place tighten the sprockets down
5. Pull alignment tool. You will notice the exhaust cam stays 100% but the intake cam moves counterclockwise or in the direction of engine movement. <- Which I dont like. Stupid Mazda Engineers
6. Preferably put crank sprocket in place and bolt it down lightly and rotate engine 2 full turns to check for valve clearance and at that time the tensioner may become more tense.
7. Use impact or other method to break the crank sprocket loose and reinstall front cover or if timing is off repeat above procedure.
8. Now with front cover in place install crank sprocket (making sure you place the sprocket in position for TDC!
9. Reinstall all pulleys and belt as well as crank position sensor. Be mindful when installing and removing this sensor as it has the capability of advancing and retarding timing. It needs to be exactly where it was when you removed it.
1. When does the crank peg come out?
2. Doesn't the chain mechanically couple the cam and crank sprockets? Step 6. makes it seem like the crank sprocket doesn't need to be there prior to tensing the chain, and then in step 7, we just take it off?
vbt101 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/my-mazdaspeed-6-vvt-chain-fix-added-78796/
Mazdaspeed 6 vvt actuator kit This thread Refback 11-26-2015 12:24 AM
VVT ïðîáëåì? Ðåìîíòíè sugestions? Ïîñúâåòâàòå? - Mazda 6 Ôîðóìè: Mazda 6 Ôîðóì / Mazda Atenza ôîðóìà This thread Refback 09-19-2014 08:30 AM
Mazda6 Forum ? Toon onderwerp - technische brieven voor de mps6 This thread Refback 06-28-2013 03:56 AM
XceedSpeed This thread Refback 10-14-2012 07:19 PM
VVT problem? Repair sugestions? Advise? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-14-2012 06:39 AM
Mazda6 Forum • Toon onderwerp - technische brieven voor de mps6 This thread Refback 01-31-2012 03:13 PM
Group buys This thread Refback 01-12-2012 08:06 PM
Replacing timing chain cbspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 193 10-18-2019 08:16 PM
Timing chain Boosted Beluga MazdaSpeed 3 - How-To's 10 03-21-2013 11:48 AM
timing chain (almost) dspider CX-7 > Engine, Transmission & Driveline 2 03-07-2011 12:30 PM
Timing chain slack? Thestaplegunkid MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-05-2009 03:47 PM
Page generated in 0.30405 seconds with 23 queries
