 Old 03-14-2014, 06:37 PM   #1
zer010gic's Avatar
Posts: 401   (View Stats)
zer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the world
Default New OEM Clutch with Fidanza Flywheel Soft Clutch Feel
So I just had a new OEM clutch and Fidanza lightweight fly wheel put in my 2006 MS6. So I picked the car up and one of the first things I noticed was the clutch is now super light/soft compared to before. Is this normal?
Corey
Autotech Internals | ETS TMIC | Cobb AP | JBR Tru-3.5" Wide Path Aluminum | JBR RMM | JBR TMM | JBR PMM | JBR Short Shift Plate | Fidanza Flywheel | TWM Weighted Shift Knob | Hawk HPS 5.0 Pads | Techna-Fit Brake Lines | RedLine Fluids and Unicorn Blood | NGK 1 Step Colder | Damond OCC | TurboSmart Duel Port | CP-e SafeSeals | JBR TIG | JBR TBG | Damond EGR Delete
Miltuned!!!
Ready to Install
ATP Downpipe
zer010gic is offline   Reply With Quote
 Old 03-14-2014, 10:10 PM   #2
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
Try bleeding the slave cylinder. Make sure you don't have any air in the lines.
Or you could try replacing the slave cylinder.
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
 Old 03-15-2014, 05:30 AM   #3
zer010gic's Avatar
Only thing is that its easy to shift gears and it does not feel spongy. Its just not as stiff as my old clutch.
I was wondering if it could be I had a version 1 clutch since mine was an early 06 and now I have a later version. Especially since Mazda reworked the clutch and issued a TSB due to clutch engagement point and pressure profile.
Here is the TSB I am referring to: TSB: 05-003/07
Miltuned!!!
Ready to Install
ATP Downpipe
 Old 03-15-2014, 11:12 PM   #4
gmoney542's Avatar
Reading the TSB it sounds like they revised the pressure plate. If you did have the original design then it's likely the new pressure plate that is giving you a softer pedal feel.
The LuK clutch with Fidanza Flywheel Combo CaseyBueno Mazdaspeed3/6 General Discussion 22 05-14-2015 08:30 AM
Soft Clutch? SRHTX 2010 MS3 - Engine, Transmission & Driveline 1 10-15-2013 02:09 PM
Page generated in 0.25379 seconds with 21 queries
