| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
| Robust Mongoloid ![]() Join Date: Aug 2009 Location: South Charlotte, NC
Rep Power: 6482 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,137
Groans: 399
(Thread Starter) | ***** The Official Mazdaspeed Forums Short Shifter Thread ***** DISCLAIMER: This is an informative thread and a resource for gathering information on which form of shifter you may want (Short Shift Plate, Full Replacement, or just a simple stem). All-in-all it is up to you to decide on which form to go with. So you've decided that the factory shifting assembly is not up to your standard of performance. The following information will give you insight into what aftermarket parts you can buy for your specific model vehicle to transform the feel and performance of your shifter assembly. The Mazdaspeed platform has many different ways to adjust the height, distance of throw, and feel of the transmission while driving. We'll start at a very simple install and work up to the hardest level. For additional Information Please See The Following Contacts List For The Specific Vendor You Have In Mind: For CorkSport Performance Contact: @CorkSport CorkSport Mazda Performance Website Mazdaspeed Forums Vendor Area - Corksport For James Barone Racing Contact: @jbarone James Barone Racing Website Mazdaspeed Forums Vendor Area - JAMES BARONE RACING For TWM Performance Contact: @TWM Performance TWM Performance Website Mazdaspeed Forums Vendor Area - TWM Performance For COBB Tuning Contact: @Cobb Tuning @Evan@COBB @David@COBB COBB Tuning Website Mazdaspeed Forums Vendor Area - COBB Tuning ***** First Generation Mazdaspeed3 ***** Short Shift Plates The first way of adjusting the distance of the gear change (see: the "throw") is to add a SSP, an abbreviation for Short Shift Plate. The name is almost an exact description of the piece. A solid piece of metal with 4 holes in it that sits on top of the transmission housing connecting the linkage. There are currently 3 Companies who manufacture Short Shift Plates for the First Gen Mazdaspeed3. 1. James Barone Racing Price: $80.00 The Stage 1 Kit From Jamie Includes both the Plate AND a counterweight. A stage 2 kit can be ordered which includes base bushings for $95.00 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 3. Corksport Mazda Performance Price: $69.00 The SSP from CorkSport includes a Counterweight ![]() ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Base Bushings At the base of every First Gen MS3 gear lever there are 4 rubber grommets that hold the shifter cage to the floor board. These bushings give the side-to-side movement of the shifter a very soft feel. Upgrading to solid aluminum Base Bushings improves the feel of the shifter when navigating throughout the gears. 1. James Barone Racing Price: $25.00 ![]() ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 3. CorkSport Mazda Performance Price: $39.00 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 4. TWM Performance Price: $34.95 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Shift Counterweights At the opposite end of the gear linkage lies the counterweight. A counterweight provides a balance at each end of the linkage and also provides improved shift response while also ensuring the transmission stays in gear during aggressive driving. 1. James Barone Racing Price: $20.00 Color options include Red, Blue, and the pictured Black below ![]() ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 3. TWM Performance Price: $49.95 While pricey, the TWM Counterweight is the only weight on the market which can be adjusted to personal preference. ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 4. COBB Tuning Price: $25.00 The simplest design and only one option to choose from. ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Replacement Stems The gear lever itself within the cabin is capable of being shortened. A 30% reduction in the distance of the throw can be seen when adding an actual short shifter. Two companies currently manufacture a short shifter for the platform. 1. COBB Tuning Price: $275.00 COBB's Shifter Features double adjustments for both Shift knob height and Throw Length To view how to install your COBB Tuning Double Adjustable Short Throw Shifter Please See This Thread: COBB Tuning Mazdaspeed3 STS Install ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 1. TWM Performance Price: $249.95 The TWM features no adjustment in throw or knob height, it is one size only. ![]() To view how to install your TWM Performance Short Shifter Please See This Tutorial courtesy of Krystm's Garage Tutorial: Short Throw Shifter Install ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Full Replacement Systems If you're feeling an overhaul of your complete shifting package, TWM Performance is currently the only company for our platform who manufactures a direct replacement system. 1. TWM Performance Price: $449.95 The Full Replacement System from TWM includes everything except a Counterweight and Shorter Shift Plate ***** Mazdaspeed6 ***** Short Shift Plates The first way of adjusting the distance of the gear change (see: the "throw") is to add a SSP, an abbreviation for Short Shift Plate. The name is almost an exact description of the piece. A solid piece of metal with 4 holes in it that sits on top of the transmission housing connecting the linkage. 1. James Barone Racing Price: $80.00 The Stage 1 Kit From Jamie Includes both the Plate AND a counterweight. A stage 2 kit can be ordered which includes base bushings for $95.00 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Base Bushings At the base of every Mazdaspeed6 gear lever there are 4 rubber grommets that hold the shifter cage to the floor board. These bushings give the side-to-side movement of the shifter a very soft feel. Upgrading to solid aluminum Base Bushings improves the feel of the shifter when navigating throughout the gears. These are the bushing locations: 1. James Barone Racing Price: $25.00 ![]() ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Shift Counterweights At the opposite end of the gear linkage lies the counterweight. A counterweight provides a balance at each end of the linkage and also provides improved shift response while also ensuring the transmission stays in gear during aggressive driving. 1. James Barone Racing Price: $20.00 Color options include Red, Blue, and the pictured Black below ![]() ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 3. COBB Tuning Price: $25.00 The simplest design and only one option to choose from. ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Replacement Stems The gear lever itself within the cabin is capable of being shortened. A 33% reduction in the distance of the throw can be seen when adding an actual short shifter. Unfortunately, only 1 company currently manufactures a short shifter for the Speed6 platform. 1. TWM Performance Price: $139.95 for a Stage 1, Add $50 for a Stage 2 The TWM features no adjustment in throw or knob height, it is one size only. (Stage 2 Shown) ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Full Replacement Systems Unfortunately, no full replacement system is currently offered for the MazdaSpeed6 platform as the shifter assembly is much more complex compared to that of the Speed3. ***** Second Generation Mazdaspeed3 ***** Short Shift Plates The first way of adjusting the distance of the gear change (see: the "throw") is to add a SSP, an abbreviation for Short Shift Plate. The name is almost an exact description of the piece. A solid piece of metal with 4 holes in it that sits on top of the transmission housing connecting the linkage. There are currently 3 Companies who manufacture Short Shift Plates for the Second Gen Mazdaspeed3. 1. James Barone Racing Price: $80.00 The Stage 1 Kit From Jamie Includes both the Plate AND a counterweight. A stage 2 kit can be ordered which includes base bushings for $95.00 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 3. Corksport Mazda Performance Price: $69.00 The SSP from CorkSport includes a Counterweight ![]() ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Base Bushings At the base of every Second Gen MS3 gear lever there are 4 rubber grommets that hold the shifter cage to the floor board. These bushings give the side-to-side movement of the shifter a very soft feel. Upgrading to solid aluminum Base Bushings improves the feel of the shifter when navigating throughout the gears. These are the bushing locations: 1. James Barone Racing Price: $25.00 ![]() ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 3. CorkSport Mazda Performance Price: $39.00 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 4. TWM Performance Price: $34.95 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Shift Counterweights At the opposite end of the gear linkage lies the counterweight. A counterweight provides a balance at each end of the linkage and also provides improved shift response while also ensuring the transmission stays in gear during aggressive driving. 1. James Barone Racing Price: $20.00 Color options include Red, Blue, and the pictured Black below ![]() ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 3. TWM Performance Price: $49.95 While pricey, the TWM Counterweight is the only weight on the market which can be adjusted to personal preference. ----------------------------------------------------------------------------------------------------------------------------------------------------------------- 4. COBB Tuning Price: $25.00 The simplest design and only one option to choose from. ----------------------------------------------------------------------------------------------------------------------------------------------------------------- Replacement Stems Unfortunately, no company currently offers just a Stem Replacement for the Second Generation Mazdaspeed3. Full Replacement Systems If you're feeling an overhaul of your complete shifting package, TWM Performance is currently the only company for our platform who manufactures a direct replacement system. 1. TWM Performance Price: $449.95 The Full Replacement System from TWM includes everything except a Counterweight and Shorter Shift Plate I Think I got Everything.......If you spot anything wrong with this thread please bring it to my attention. Thanks, Dump
__________________ ______________________ Built By NATOR Tons of Ricer Mods
| The Following 8 Users Say Thank You to 09Speed3Z For This Useful Post: | castrocastro (07-13-2012), ILspeed3 (07-12-2012), JBR (07-12-2012), jeoje (07-12-2012), Mortose (07-12-2012), navyspeed3 (04-03-2013), Raider (07-12-2012), smoogs12 (07-12-2012) |
| Not Ranked : 0 score Don't forget maperformance, etc. Taking shape, subbing for progress and will send $$$ when done! |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score Did I see that Matt Damond has one now as well?
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
Groans: 399
(Thread Starter) | I'm sure there are spelling mistakes and the like in there somewhere if someone can find them and point them out I'd appreciate it. @Raider
| The Following User Says Thank You to 09Speed3Z For This Useful Post: | Raider (07-12-2012) |
Bumping for input about any possible missing options... | |
Groans: 399
(Thread Starter) | This forum has quite the history with E4 Performance. If it's in the forums best interest, I'll be glad to throw that in tomorrow.
| Not Ranked : 0 score I know, but people still buy it. I've got 40,000 miles on mine.... |
Groans: 399
(Thread Starter) | Fair enough It's on the add list for tomorrow.
Groans: 399
(Thread Starter) | Not an authorized MSF Member and frankly one that doesn't return goddamn phone calls!!!!!! Lol
| The Following User Says Thank You to 09Speed3Z For This Useful Post: | Royer366 (04-15-2014) |
![]() Join Date: Feb 2011 Location: Aurora, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,094
Groans: 39
| Not Ranked : 0 score I vote sticky. +1 for the TWM STS and JBR SSP. In combo, i have about a 3 inch throw now. I LOVE IT.
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" |
Groans: 399
(Thread Starter) | @Raider I looked on E4's website. There STS isn't listed anymore so I'd be a little skeptical about listing it if you can't find it. They have their counterweight shown so I'll add that to the list in the counterweight section.
| Not Ranked : 0 score I got mine through pg- Protege Garage - E4P Short Shifter - Mazdaspeed3 But if op does not want to post it, I'm ok since pg is banned. I only said them because ive had one with no problems, |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 427
Groaned at 27 Times in 21 Posts
| Not Ranked : 0 score |
![]() Join Date: Mar 2013 Location: FT Lauderdale, FL
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score would you ever put a shifter plate in if you already have a TWM short throw shifter and a jbr shifter weight, just wondering, thanks. |
![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Im curious if anyone has attempted to bolt a TWM full replacement in an ms6 without the 1in risers or are the bolt locations different |
| Not Ranked : 0 score @09Speed3Z; look up the JBR ones to add for ms3/ms6 |
![]() Join Date: Jul 2014 Location: Los Angeles, CA
| Not Ranked : 0 score How is the shift plate? I never even knew that there was such a thing. Only thought that you have to replace the whole gear box and stick if you wanted to reduce the throw. Anyone have any recommendations on which brand and if the short shift plate is worth it? |
| Not Ranked : 0 score Read the OP. Pick one. |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7119 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
| Not Ranked : 0 score I run the JBR it's the best. |
| Not Ranked : 0 score Only slightly biased. |
| The Following User Says Thank You to Raider For This Useful Post: | JBR (08-01-2014) |
![]() Join Date: May 2012 Location: Ottawa Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score would a tmwm short shifter from a gen 1 fit a gen 2?
__________________ 2012 MAZDASPEED 3 BLACK MICA -COBB SRI - COBB TIP - STEBRO CBE -ULTIMATE RACING CATLESS DOWNPIPE- STREET UNIT TEST PIPE -AUTOTECH INTERNALS - STREET UNIT TMIC - CORKSPORT TRUNK BRACE- STREET UNIT RMM (BROKE) JBR 88A RMM - CPE PASSENGER MOUNT - CPE TRANSMISSION MOUNT -COBB ACCESSPORT -SNOW PERFORMANCE STAGE 2 BOOST METH INJECTION KIT- DAMOND OCC -XXR 531 18X9 HYPER SILVER 235/40/18 GFORCE TIRES- PIRRELI PZERO RACING SLICKS ON OEM RX8 R3 RIMS- KSPORT SPEC AR COILOVERS - TURBO SMART BPV-DENSO ITV22'S STRATIFIED TUNE BY LEX |
| Not Ranked : 0 score Not even close. We will be releasing our GEN 2 shifter in the next month. ![]() uploadfromtaptalk1412968815763.jpg uploadfromtaptalk1412968839107.jpg |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | kbz0129 (10-10-2014), Mauro_Penguin (10-13-2014) |
![]() | | #24 | ![]() |
![]() Join Date: May 2014 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
| Not Ranked : 0 score [QUOTE= We will be releasing our GEN 2 shifter in the next month. Hell yeah, looks like I'm waiting to get one. You guys recommend stacking this with your SSP?
__________________ "Keep your head clear and suffer like a man" |
![]() | | #25 | ![]() |
-Jamie | |
![]() | | #26 | ![]() |
![]() Join Date: Dec 2015
Rep Power: 0 ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score The jbr short shift plate and shifter bushings don't specify the year while the ones for cork sport do. What are the differences between first and second gen? |
![]() | | #27 | ![]() |
Can the OP be updated? The pictures are missing or out of date. All of the pictures on our website have been re-shot. Also some prices have changed. I can help if need be. -Sabrina | |
![]() | | #28 | ![]() |
| The Following User Says Thank You to rotarican21 For This Useful Post: | JBR (01-13-2016) |
![]() | | #29 | ![]() |
![]() Join Date: Apr 2015 Location: Central Coast, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Hey All, I am using a Cork Sport shifter and aluminum base bushings. Can anyone recommend a way to get rid of the slop when in gear? The slop I mean is when the shifter is in gear there is a lot of play in the shifter. Will the plate help or do I have to go with a full TWM replacement?
__________________ 2008 MS3 GT, Fully Bolted, Cobb AP V3, TR8 FMIC, JBR Piping, JBR 3.5 Wide Path, Autotech Internals, CPE Stage 2 Rear Motor Mount, CNT Catless DP, CNT Cat Back, 51R Battery Box, Cobb Short Shifter, Enkei RPF1's, Koni Yellows, GTX3076R, Freektuned. |
![]() | | #30 | ![]() |
![]() Join Date: Sep 2017
| Not Ranked : 0 score Hello: I don't see a lot of activity here lately but hoping for some feedback. Is there an actual difference between the Gen 1 and Gen 2 short shift plates? I have only ever seen one listing (nothing specifying a certain year or gen)? And I don't see any mention of the Sure Short Shift Plate (https://www.suremotorsports.com/product-p/sure0513.htm). Has anyone used that option? I have heard that short shift plates can cause transmission or linkage damage. Is that the case or is that more incorrect installation? |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
Groans: 105
| Not Ranked : 0 score From what I gather, Sure gets shit on for a lot of stuffs. Read up on that. If you search on websites for short shift plates, cross reference the years and compare part numbers. Fuck being lazy. Best bet is to buy an actual short shifter as oppose to running a plate. I am rocking a Damond plate. JBR makes a real sweet short shifter that I keep eyeballing to replace my plate.
__________________ Stockish |
| The Following User Says Thank You to Db09ms3 For This Useful Post: | JBR (04-27-2018) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score We have replacement short shifters for both the GEN 1 & 2. They are very reasonably priced too at $125 and $155 respectively. |
| The Following User Says Thank You to JBR For This Useful Post: | Db09ms3 (04-27-2018) |
![]() | | #33 | ![]() |
I will also check out the JBR short shifter. | |
![]() | | #34 | ![]() |
![]() Join Date: Oct 2015 Location: Twin Lakes, WI
Rep Power: 0 ![]() ![]() Thanks: 3
![]() | | #35 | ![]() |
| Not Ranked : 0 score A shift knob is icing on the cake. Most do it. |
| OFFICIAL Broken Shifter NHTSA Reports Thread | Mizzle | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 12-20-2012 07:48 AM |
