  • 1 Post By Db09ms3
 Old 01-05-2020, 06:39 PM   #1
rudydecc's Avatar
Posts: 113   (View Stats)
rudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud of
Default Oil leak - recommended fixes
Have a slight oil leak on top of the valve cover. It’s been there for a while (4-6 years, and in someways maybe longer 🤷🏼—♂️).
Any idea on where it would be from and what it would cost to fix it? I think it’s the oil pressure sensor, but that’s just a guess.
File Type: jpeg B34229F0-476D-4FC8-BD3E-5021F1AA3A49.jpeg (1.00 MB, 12 views)
2008 Mazdaspeed3 GT ::COBB STS/Turbo Inlet/AP/SW/BPV, Fujita F5 CAI, CP-E RMM/DP/CBE/FMIC, TWM Shifter Bushings/JBR Side Mounts::
2019 Audi Q7
rudydecc is offline   Reply With Quote
 Old 01-06-2020, 10:56 AM   #2
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Looks like the vvt solenoid seal is leaking.
https://edgeautosport.com/mazda-oem-...d-6-2006-2013/
kwambe5 likes this.
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
cyclist20 (01-06-2020)
 Old 01-07-2020, 03:10 PM   #3
Posts: 2,237   (View Stats)
but to change it you have to lift the v cover and get a new vc seal with it...and a can or 2 of brake cleaner...
Db09ms3 (01-08-2020)
 Old 01-08-2020, 09:21 AM   #4
Db09ms3's Avatar
Groans: 105
YAS, dis.
Stockish
P0126 fixes dubunderpar MazdaSpeed 3 - Engine, Transmission & Driveline 17 11-12-2015 01:16 AM
Boost leak testing, possibly Wastegate/Actuator leak AgentWh0 2010 MS3 - Troubleshoot/Diagnostics 0 08-04-2015 12:29 PM
Injen CAI Fixes keychain12 Mazdaspeed3/6 General Discussion 15 03-18-2013 12:00 PM
Injen CAI Fixes keychain12 MazdaSpeed 3/6 - Turbo Induction 1 03-13-2013 06:07 PM
COBB/TWM/OTHER FIXES bioevolve MazdaSpeed 3 - Engine, Transmission & Driveline 11 09-06-2008 02:29 PM
Page generated in 0.25918 seconds with 23 queries
