 Old 02-17-2012, 12:35 AM   #1
zlatan's Avatar
Posts: 166   (View Stats)
zlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the worldzlatan is the leader of the world
Groaned at 8 Times in 4 Posts
Default Overheating Issues
2007 MS3 57K miles ( Do I still have warranty?)
My car has been experiencing intermittent overheating issues. I've spiked as high as 237 before and shut the car off and let it cool down. Cruising around my temps are normal. However, @ random times I get heat spikes and I overheat or hit temps I don't want to see (220's) I also am having heater issues where the car blows hot air at idle and stops @ times. This happens as randomly as the overheating does. I have no signs of a blown headgasket. No oil in coolant/coolant in oil. The car still pulls like a champ. However, I've reached a point of frustration where I don't know what else to try and swap out to fix it.
I've swapped/tried the following:
Thermostat (tried a used one and had the same issue now I'm on a brand new OEM)
Water pump
Coolant box and cap
Checked lines for leaks (none found)
Burped the system
I'm just tired of having to monitor temps all the time on AP. I have no idea what else to check. I've heard that the ECT sensor could be a possibility as well.
Your thoughts?
-Anon.
zlatan is offline   Reply With Quote
 Old 02-17-2012, 12:55 AM   #2
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
flush it out
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
 Old 02-17-2012, 02:38 AM   #3
zlatan's Avatar
Originally Posted by zenger View Post
flush it out
did that
-Anon.
 Old 02-17-2012, 09:20 AM   #4
driver311's Avatar
Posts: 1,769   (View Stats)
I think its the cap. When we crack the cap the thermostat opens and it cools right off. Its got suction in the system that doesnt allow the thermostat to open. But its intermittent. itll work for two days with 0 issues then out of no where its a pain again and overheats. I tried everything I knew.
therostat
water pump
flush
but it got bad when we replaced cap and overflow. Its like it cant breath and builds up pressure????
Mazdaspeed
 Old 02-17-2012, 10:25 AM   #5
zenger's Avatar
Sorry burp the system must be flush? Lol
Sent from my Galaxy Nexus using Tapatalk
2007-Mazdaspeed 6
 Old 02-17-2012, 10:27 AM   #6
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Could be a pinhole in the radiator
NATOR PA
rfinkle2 (02-17-2012)
 Old 02-17-2012, 02:43 PM   #7
driver311's Avatar
Somethings creating suction keepin the thermostat from opening consistantly. its very weird. Its like the system cant breath
Mazdaspeed
 Old 02-17-2012, 02:46 PM   #8
Groans: 224
Pinhole in the rad would mean no leaks (fluid wise) and that air is being pulled into the system at a very slow rate. Which would explain why the overheating issue would only come back every couple of days instead of immediately.
I know you recently worked on his car, did you guys bang it or hit it with any tools by chance?
NATOR PA
 Old 02-17-2012, 04:06 PM   #9
driver311's Avatar
I have an idea. thanks for the suggestion.
Mazdaspeed
 Old 02-17-2012, 04:17 PM   #10
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
i was going through a similar situation. I tired burping, changing cap, and tstat but it kept over pressuring and spilling out of the bottom of the res. The service manual said to bleed with the cap on the res. Not sure how it works, but i guess it does. Im assuming with the cap off when trying to burp will pull in air when the tstat opens. Manual says to get car to op temp and hold the rev to 2500 for 2 or 3 mins ... do it twice and on the 3rd time rev to 3000 and hold for 5 secs. Let the car completely cool till the needle is at the C and then you can open the cap to fill if needed. This worked for me .. but i ended up replacing the res because i think i had a hair line crack somewhere.
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 02-17-2012, 04:29 PM   #11
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
So are any of you guys pushing coolant out of the overflow while boosting because it is over filling and pushing past the cap?
Also is your fan coming on? Here is a test there is a wire harness on the passengerside of the radiator with a single red wire (speed6 not sure about the speed3) just unplug it while the car is running and this will cause the fan to run all the time. If your car doesn't over heat like it has been then your fan module might be bad..
track weight 3220
street weight 3370
 Old 02-17-2012, 05:52 PM   #12
zlatan's Avatar
Will be replacing some hoses tonight and burping the system. I will update the thread after with results.
-Anon.
 Old 02-17-2012, 11:35 PM   #13
zlatan's Avatar
Changed out the two bottom hoses going into the other side of the block and refilled with coolant. The hoses had bulges on the edges and seemed weak and swollen. Did some WOT pulls and never hit over 199. Did some cruising around down and saw high 180's low 190's. Got home after doing some pulls and idled at 210 after sitting 5 min. Drove on it and immediately had temps go back down. Checked the bottle and noticed it was empty. I topped it off now.
Cliff note?
I think it's fixed!
-Anon.
The Following 3 Users Say Thank You to zlatan For This Useful Post:
06Speed6 (02-19-2012), atvfreek (02-18-2012), MS3-a(sore)ASS-rex (02-19-2012)
 Old 02-19-2012, 01:14 AM   #14
driver311's Avatar
I think the system just had some very small air leaks and needed to be bled. Im gonna try the burp deal again and check the fan. . Thanks guys for the help. Mine never gave me any grief like this. LOL
Mazdaspeed
How I solved me power steering overheating issues MATT DAMOND MazdaSpeed 6 - Engine, Transmission & Driveline 20 04-09-2015 05:57 PM
overheating Vinnie MazdaSpeed 3 - Engine, Transmission & Driveline 10 09-13-2011 07:00 PM
overheating help please johnnybochamp MazdaSpeed 6 - Engine, Transmission & Driveline 9 07-24-2010 04:16 PM
Overheating dutchbuffalo MazdaSpeed 6 - Engine, Transmission & Driveline 2 06-01-2010 11:45 AM
Page generated in 0.33720 seconds with 25 queries
