| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
Groans: 793
| Not Ranked : 0 score And by oversize we mean that the bore the bearings create is undersize?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following User Says Thank You to Tokay444 For This Useful Post: | rfinkle2 (01-25-2012) |
| Mazda crank pulley tool vs Ford crank pulley tool | SPEED6 KILLAH | MazdaSpeed 6 - Engine, Transmission & Driveline | 52 | 03-11-2017 09:46 AM |
| Mazda3 Crank vs Speed3 Crank | relenger | MazdaSpeed 3 - Engine, Transmission & Driveline | 36 | 12-19-2010 08:22 AM |
| LCA Spherical bearings | Todd98SE | 2010 MS3 - Suspension & Brakes | 7 | 02-03-2010 01:00 PM |
| LCA Spherical bearings | Todd98SE | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 01-31-2010 06:07 PM |
| Rod and Main Bearings | 06Speed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 10 | 02-26-2009 02:22 AM |
