  • 1 Post By 06Speed6
 Old 01-25-2012, 12:58 PM   #1
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Default Oversized crank bearings
Just got off the phone with my parts guy at the mazda dealership in town and he said he has a listing on over sized crank bearings for the mazdaspeed disi motor. .025 and .05 over for the main and .025 over for the connecting rods.
Can anyone else verify this?
Sent from my ADR6425LVW using Tapatalk
 Old 01-25-2012, 01:27 PM   #2
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
Here is a link for the mains:
STD
OS .25
OS .50
1100A - PISTON, CRANKSHAFT & FLYWHEEL. Fits: 2007 Mazda MazdaSpeed6 | Jim Ellis Mazda
I am in the process of having some connecting rod bearings done by ACL. So those will be available soon.
Here are the sizes that are available for the mains from ACL now:
STD
.25
.50
.75
Part number 5M8174A
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following 4 Users Say Thank You to SFWD 1934 For This Useful Post:
06Speed6 (01-25-2012), Chimmike (01-25-2012), rfinkle2 (01-25-2012), silvapain (04-26-2013)
 Old 01-25-2012, 01:57 PM   #3
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
And by oversize we mean that the bore the bearings create is undersize?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 01-25-2012, 01:59 PM   #4
tbot's Avatar
Groans: 40
Yes, basically allows the crank to be machined if necessary. For a long time these weren't available
The Following 2 Users Say Thank You to tbot For This Useful Post:
 Old 01-25-2012, 02:02 PM   #5
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
I was just about to say that the .50s were not available anymore as i think that is why dustin had his problem.
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
 Old 01-25-2012, 02:06 PM   #6
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
stuck
07 MS3
The original Genpoo Hater
 Old 01-25-2012, 02:22 PM   #7
SFWD 1934's Avatar
Since it is stuck now, here are the part numbers if someone wanted to use Clevite or Federal Mogul or King as an option. Some people like to have other options:
Mains:
Clevite 77: MS-2245AL
Federal Mogul: 7411MA
King: MB5442SI
Jason
www.full-race.com
06Speed6 (01-25-2012), Alpha (01-25-2012), NJSPEED3 (03-13-2012), silvapain (04-26-2013)
 Old 02-15-2012, 07:28 PM   #8
Tech/Sales@EM's Avatar
Posts: 1,173   (View Stats)
Tech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the world
Groaned at 28 Times in 11 Posts
Mains:
King: MB5442SI
Jason
I was just in the process of starting the same project with King Bearings for Rod Bearings.
Tech/Sales@EM is offline   Reply With Quote
 Old 03-10-2012, 01:40 AM   #9
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I just posted the oversize bearing part numbers in my ms6 part number thread. I couldnt find them forever but I finally found them for the crank, rod, and thrust bearing.
2006 Mazdaspeed 6
The Following 2 Users Say Thank You to 06Speed6 For This Useful Post:
Chimmike (03-27-2012), Tokay444 (03-10-2012)
 Old 03-27-2012, 12:37 PM   #10
Will fuck up ur day
Chimmike's Avatar
Groans: 433
PLEASE post in here!!!!!!
07 MS3
 Old 04-01-2012, 09:06 PM   #11
SFWD 1934's Avatar
Alright, thought that I would update everyone about the con rod bearings. ACL actually had them already. They are the same ones that are used on the Mitsubishi 4B11T 2.0L motor. Here are the part numbers for not only ACL, but Clevite 77 interchanges if you are interested:
ACL: 4B1236H
Clevite: CB1918H
That is the "standard" part number for the ACL and Clevite. ACL has the .025, .25, and the "X" which have an additional .001".
Jason
www.full-race.com
06Speed6 (04-03-2012), Alpha (04-24-2012), bcmurphy87 (04-23-2013), theschrum (10-20-2012)
 Old 06-04-2012, 12:45 AM   #12
wangna's Avatar
Posts: 3   (View Stats)
wangna is an unknown quantity at this point
________________________
Nike Free Run
Hollister Dundrum
New Balance Sneakers
wangna is offline   Reply With Quote
 Old 06-04-2012, 05:49 AM   #13
Tokay444's Avatar
Groans: 793
Nike Free Run
Hollister Dundrum
Ummm....
You trolling me nigga?
Demodded.
The Seals
 Old 06-21-2012, 06:02 AM   #14
Posts: 2,826   (View Stats)
When the crank is machined, it's journals have metal removed, thus making each journal's outside diameter smaller. Thus the replacement bearings must be oversize, with a larger assembled inside diameter to maintain specified clearance. To my knowledge, no bearing manufacturer makes smaller than stock rod or main bearings.
Of necessity, they will be either standard or oversize.
BTW: if bearings are now available (mains and rods) from Clevite, that company's uniform quality is superb. You really can't do better than Clevite 77.
 Old 06-21-2012, 06:49 AM   #15
Tokay444's Avatar
Groans: 793
If the crank journal is smaller, and the bore the bearing makes is bigger, your clearances are growing.
You cannot remove material from the crank, and the bearing bore and expect clearances to be maintained.
The term oversized, refers to the thickness of the bearing halves.
Demodded.
The Seals
Last edited by Tokay444; 06-21-2012 at 06:49 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-21-2012, 02:35 PM   #16
tbot's Avatar
Groans: 40
I think u guys are saying the same thing in different ways...
The Following User Says Thank You to tbot For This Useful Post:
MSMS3 (06-21-2012)
 Old 06-21-2012, 04:36 PM   #17
^ Exactly! The backing of bearing shells will the thicker and the O.D. of the bearing surfaces when combined will be larger to compensate for the loss of metal on the crank journals.
In an earlier part of my life and growing up in an automotive/industrial/diesel production engine rebuilding company and machine shop, I spent a LOT of time at the controls of crankshaft grinders, rod reconditioning machines, cylinder boring bars, milling machines, etc., and in assembly of short blocks and cylinder heads. About the only machine I did not have time to learn to operate before my journey through business school and a post-graduate degree was the camshaft grinder and the development of the lobe blank masters for custom (read: performance) grinds.
I am still very much involved in that business, but now on the management side.
 Old 06-21-2012, 06:10 PM   #18
Speeeeeed
06Speed6's Avatar
Main Crankshaft Bearings: Use Oversized or Undersized Bearing
There ya go
Tokay444 likes this.
2006 Mazdaspeed 6
Tokay444 (06-21-2012)
 Old 06-21-2012, 08:00 PM   #19
Tokay444's Avatar
Groans: 793
He said larger inside diametre. That's not the same as smaller inside diametre.
Demodded.
The Seals
MSMS3 (06-22-2012), tbot (06-21-2012)
 Old 06-22-2012, 07:21 AM   #20
^ You are right. The assembled I.D. of the bearings must be smaller to match the smaller journal size (plus the oil clearance). Misstatement brain fart in my first post, corrected above.
Tokay444 (06-22-2012)
 Old 11-27-2012, 06:44 PM   #21
Speeeeeed
06Speed6's Avatar
Just thought ide post in here that the ACL bearings work great and were ~.0003" in spec and the king mains were perfectly in spec, I was very impressed with them.
2006 Mazdaspeed 6
tbot (11-28-2012)
 Old 04-23-2013, 07:23 PM   #22
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
Just scored those ACL std size bearings for 46 shipped off ebay. Makes me a happy person
ACL: 4B1236H
Clevite: CB1918H
Jason
06 Speed6 GT- Sold
The Following User Says Thank You to bcmurphy87 For This Useful Post:
Funkster777 (04-23-2013)
 Old 04-23-2013, 08:23 PM   #23
Funkster777's Avatar
Posts: 1,254   (View Stats)
Funkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the world
I appreciate this information. I'll talk with @silvapain; about this possibility. A few extra dollars saved would be worthwhile, especially if they work as well or better.
Funkster777
2010 Black Cherry Metallic Mazda 6 DD (well as needed)
2006 Black Mica Mazdaspeed6 Sport
Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.
Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS
Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails
Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod
Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port?
Funkster777 is offline   Reply With Quote
 Old 07-24-2015, 05:20 PM   #24
Jdraps13's Avatar
Posts: 703   (View Stats)
Jdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the world
Groaned at 18 Times in 5 Posts
Does anyone know the nominal thickness of oem main bearings .25 and .50 were trying to get clearances proper, and need to know the thickness of oem King bearings were a little too loose
Jdraps13 is offline   Reply With Quote
Mazda crank pulley tool vs Ford crank pulley tool SPEED6 KILLAH MazdaSpeed 6 - Engine, Transmission & Driveline 52 03-11-2017 09:46 AM
Mazda3 Crank vs Speed3 Crank relenger MazdaSpeed 3 - Engine, Transmission & Driveline 36 12-19-2010 08:22 AM
LCA Spherical bearings Todd98SE 2010 MS3 - Suspension & Brakes 7 02-03-2010 01:00 PM
LCA Spherical bearings Todd98SE MazdaSpeed 3/6 - Suspension & Brakes 1 01-31-2010 06:07 PM
Rod and Main Bearings 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 10 02-26-2009 02:22 AM
Page generated in 0.44296 seconds with 31 queries
