  • 1 Post By
 Old 06-21-2012, 06:02 AM   #1
Posts: 2,826   (View Stats)
When the crank is machined, it's journals have metal removed, thus making each journal's outside diameter smaller. Thus the replacement bearings must be oversize, with a larger assembled inside diameter to maintain specified clearance. To my knowledge, no bearing manufacturer makes smaller than stock rod or main bearings.
Of necessity, they will be either standard or oversize.
BTW: if bearings are now available (mains and rods) from Clevite, that company's uniform quality is superb. You really can't do better than Clevite 77.
Mazda crank pulley tool vs Ford crank pulley tool SPEED6 KILLAH MazdaSpeed 6 - Engine, Transmission & Driveline 52 03-11-2017 09:46 AM
Mazda3 Crank vs Speed3 Crank relenger MazdaSpeed 3 - Engine, Transmission & Driveline 36 12-19-2010 08:22 AM
LCA Spherical bearings Todd98SE 2010 MS3 - Suspension & Brakes 7 02-03-2010 01:00 PM
LCA Spherical bearings Todd98SE MazdaSpeed 3/6 - Suspension & Brakes 1 01-31-2010 06:07 PM
Rod and Main Bearings 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 10 02-26-2009 02:22 AM
Page generated in 0.23895 seconds with 21 queries
