 Old 09-21-2012, 09:53 AM   #1
RussM's Avatar
Posts: 109   (View Stats)
RussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud ofRussM has much to be proud of
Default P0098 intake air temp sensor high input
Good Day Superior Techs
Had this cell just pop up:
Went through the multiple steps generated by all data to trouble shoot code except don't have meter to check for shorts, checked for frayed wirering, checked for lose connectors, cleaned MAF connectors and sensor, cell still there, only have MSCAI and MS CBE installed when new 86K ago.
Car runs great!!
My mechanic and local speed mechanic at the dealership said coed specifically related to the MAF sensor and should probably replace at cost of $200.
Checked 4 Mazda dealers and all said never had sold a MAF sensor for a 08 Speed 3 as well as both mechanics, said usually bad connection or dirty sensor.
Anyone have a better idea or a way to abnsolutely confirms it is sensor before I just replace a part.
I can borrow any type of meter if I can get recommendation on what to do.
Thanks so much for any assistance rendered.
RussM is offline   Reply With Quote
 Old 09-22-2012, 08:29 AM   #2
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
reset, swap with a bud, see what happens
 Old 09-22-2012, 09:06 AM   #3
RussM's Avatar
Thank you for good advice, but no one around here with a Speed, it also looks like that coed is dealing with the MAP senor not the MAF sensor as the speed mechanic suggested.
Borrowd a meter and will try and get up to it on the bottom left side of intake manifold.
 Old 09-22-2012, 09:30 AM   #4
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Maf is what sees the intake temp, map sees boost air temp. The issue is with your maf. Your car is 4 years old and although not common very feasible that the sensor tool a shyt. Where do you live?
TEAM LUXURY
 Old 09-25-2012, 07:36 AM   #5
RussM's Avatar
Live in SE "hell frozen over" wisconsin!
Thank You,spec Alldata can be wrong, you guys Know alot more about these cars , the coed P0098 in all data sayas Boost air temerture sensor circuit high?
Thanks again!
 Old 09-26-2012, 05:42 AM   #6
Sid3wayS's Avatar
Groans: 97
@RussM
I didnt look up the code at first just went off op, check your map sensor and wires going into it.
TEAM LUXURY
 Old 10-10-2012, 09:31 AM   #7
RussM's Avatar
Map sensor coated in oil and found a broken wire from MSCAI clamp rubbing on wire harness, replaced MAP and repaired wire no coeds, running great!
Don't know where the oil cam from but 86K on engine who knows, no oil smoke out tailpipe, plugs look great, go figure!
 Old 01-15-2014, 10:45 AM   #8
oldmusher's Avatar
Posts: 1   (View Stats)
oldmusher is an unknown quantity at this point
Default P0096 IAT sensor 2 CKT range/performance
Hey Turbonauts!
have the dreaded check engine light on our 2009 Speed3. At 92,000 miles. Code reads: P0096 IAT sensor 2 CKT range/performance Intake air temp sensor. Showed up when it was recently -30 in the morning. The engine runs great at all RPM's. The wiring around the MAF sensor looks intact, non-corroded and tight. It has eaten a lot of blowing snow in the last 6 weeks. Does anyone know where this sensor is Located?
By the way...at below zero temps the little buzz bomb feels like it has gained 20+ horsepower. So...it isn't all bad.
oldmusher is offline   Reply With Quote
Ambient Temp Sensor 802_Anthony Mazdaspeed3/6 General Discussion 18 08-04-2014 04:30 PM
Sensor 1 low input(Knock sensor)? SpeedKAF MazdaSpeed 3/6 - Turbo Induction 0 07-02-2011 10:30 AM
Rear Diff Temp Sensor # rob ms6gt Mazdaspeed3/6 General Discussion 10 01-20-2011 04:42 AM
Page generated in 0.28838 seconds with 23 queries
