 Old 06-04-2011, 05:04 PM   #1
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
Default Question about Crankpulley bolt....
So I was doing some reading and came across this guy:
Broke a piece off of my CAMSHAFT!!!
Here is my question:
If you don't have a crank pulley tool could you theoretically put the car in first gear and have someone hold down the brake pedal and use it to hold the crank pulley still?
For some reason it seems to me like that should work or am I wrong?
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
 Old 06-04-2011, 06:12 PM   #2
cbspeed3's Avatar
Posts: 203   (View Stats)
cbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond repute
might work....give it a try
cbspeed3 is offline   Reply With Quote
 Old 06-04-2011, 06:18 PM   #3
drknyte's Avatar
Groans: 39
I wonder what kind of stress it puts on everything, cause between the brakes to the crankshaft there are a LOT of parts that the force would travel through but then again when you launch the car it puts more stress on that whole drive line system.....
Does this make sense to anyone else?
This is something I`ve always thought about but never discussed.
60ft: 2.167
1/8: 9.052
 Old 06-05-2011, 07:58 AM   #4
kmac's Avatar
Posts: 1,792   (View Stats)
Should work same principle as if the car was automatic and it was in park laying on the parking prawl. U can also hold the pulley with a strap wrench.
 Old 06-05-2011, 08:07 AM   #5
drknyte's Avatar
Groans: 39
Thanks!
60ft: 2.167
1/8: 9.052
 Old 06-05-2011, 08:18 AM   #6
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
Try putting it in a higher gear. It takes alot more torque to turn it against that. It's the old bicycle analogy, steep hill, granny gear, easy to pedal, high gear, quad burn city.
Also, tighten the bolt a hair before you loosen it. That'll break the thread interface and it'll wind right off.
The Following User Says Thank You to darth vader For This Useful Post:
drknyte (06-05-2011)
 Old 06-05-2011, 08:22 AM   #7
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
It won't matter what gear if someone is holding the brakes, so long as it isn't in neutral.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-05-2011, 09:16 AM   #8
drknyte's Avatar
Groans: 39
Thanks bros!
60ft: 2.167
1/8: 9.052
 Old 06-05-2011, 01:30 PM   #9
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
impact gun at 165psi ALWAYS gets the crank bolt right off.
dont need to hold any brakes or anything like that
Rich-PMS is offline   Reply With Quote
Missing Bolt Question MOVOVR MazdaSpeed 3/6 - Turbo Induction 3 03-29-2010 01:05 PM
Urgent Bolt Size Question >> Alpha MazdaSpeed 3/6 - Turbo Induction 10 02-01-2010 11:21 AM
Bolt help iracer7 MazdaSpeed 3 - Engine, Transmission & Driveline 18 07-25-2009 11:26 AM
Fully bolt SS/SC vs MS3 Bigbody250 Street Racing Stories ( Bench Racing ) 12 06-22-2009 09:24 PM
Page generated in 0.28983 seconds with 25 queries
