 Old 07-24-2010, 04:27 PM   #1
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Default Rear Stock motor mount mod
I've searched around but can't find anything on filling in the rear motor mount with urethane or anything else for that matter. Has anyone tried this and results if so. Thinking about picking up a stock motor mount and filling it in, to replace the stock.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 07-24-2010, 04:59 PM   #2
TurboColtGT's Avatar
Posts: 193   (View Stats)
TurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the worldTurboColtGT is the leader of the world
I have it done it. I used 3m Window Weld...
little bit more vibrations felt and it seems to be holding up pretty good 1.5 years later
I'd rather be banned for speaking my mind than lurking in the shadows only thinking what should've been said
2008 MazdaSpeed 3
TurboColtGT is offline   Reply With Quote
The Following User Says Thank You to TurboColtGT For This Useful Post:
86AmishMs3 (07-25-2010)
 Old 07-24-2010, 06:18 PM   #3
86AmishMs3's Avatar
Groans: 338
did it subdue engine movement, improve shifts?
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 07-25-2010, 02:07 AM   #4
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Honestly man, just save yourself the trouble and pick up an aftermarket mount. The install takes 10 minutes. I could even help you out if you want. They're cheap enough, and there is a range of options if you don't want one that is too stiff or too soft. They hold their value well too if you change your mind and don't want it any more. Just my advice. Picked up a motor mount before the car had a hundred miles on it and haven't looked back.
The Following 4 Users Say Thank You to madvillain For This Useful Post:
86AmishMs3 (07-25-2010), gtarman77787 (07-26-2010), jwdp54 (07-25-2010), karl-hungus (07-25-2010)
 Old 07-25-2010, 03:02 AM   #5
awd>fwd
jwdp54's Avatar
Posts: 627   (View Stats)
jwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the world
Groans: 27
Groaned at 53 Times in 33 Posts
yo i have a cpe mm 60 duro as a paper weight since i don't have my car anymore. i'll sell it to ya for 50 bucks and help you install it.
MS3 310whp/320tq- SOLD finally(5/5/10)
evo 8-tuned to E85
jwdp54 is offline   Reply With Quote
The Following 2 Users Say Thank You to jwdp54 For This Useful Post:
86AmishMs3 (07-25-2010), madvillain (07-26-2010)
 Old 07-25-2010, 09:06 AM   #6
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
I filled my stock mount with epoxy. Worked well for a bit but, eventually, all the epoxy cracked and fell out. Now, I have a Street unit mount. Much better.
The Following User Says Thank You to darth vader For This Useful Post:
 Old 07-25-2010, 11:58 AM   #7
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
It's already been done for you by CorkSport. They make urethane inserts that fill the entire motor mount.
Cheap as hell at only $35.00 bucks. I've had the CS inserts for almost 2 years now and everything is holding up great.
this forum serves 2 purposes
 Old 07-25-2010, 03:26 PM   #8
86AmishMs3's Avatar
Groans: 338
hmm i might have to take you up on that offer, is it a quick install (less then 15min), this weather sucks to do anything to your car. What part of phoenix are you in.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 07-26-2010, 01:35 AM   #9
awd>fwd
jwdp54's Avatar
Groans: 27
north phx(19th ave and bell) but don't mind driving to help a fellow speed owner out. plus i like workin on cars. i could do it in less than 10 mins and have i have all the tools needed.
evo 8-tuned to E85
 Old 07-26-2010, 05:45 AM   #10
banditscout's Avatar
Posts: 783   (View Stats)
banditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the world
Groans: 50
The CS inserts are a good way to go if you want to save some cash...However, I recently switched to a CP-e 60 duro, and it's a noticable improvement over the inserts. The full mount keeps the motor from lashing back and forth, so shifting is much improved...especially if you sit in a lot of traffic like I do.
banditscout is offline   Reply With Quote
 Old 07-26-2010, 05:57 AM   #11
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
just installed the rear motor mount for the speed6 two weeks ago, it is a huge difference, im guessing it will benefit the 3 the same way, shifting is better and when you take your foot of the gas there is much less movement in the car, great upgrade, new there all a little over 100 and intall is very easy, just buy a new piece and save your self the trouble of having the bushings pressed in and what not
2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge
speedms6 is offline   Reply With Quote
The Following User Says Thank You to speedms6 For This Useful Post:
86AmishMs3 (07-27-2010)
 Old 07-26-2010, 01:32 PM   #12
mo4130's Avatar
Posts: 118   (View Stats)
mo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant future
Groaned at 13 Times in 4 Posts
What's the point in buying a brand new 23k car and skimping on a $100 part that keeps your engine from hitting the fire wall. Mounts unlike other mods like dp, tips for example, are not just for putting more power to the wheels, its also litterally keeping your car from falling apart or your engine falling out the bottom.
mo4130 is offline   Reply With Quote
The Following User Says Thank You to mo4130 For This Useful Post:
hoyta (07-26-2010)
 Old 07-26-2010, 07:04 PM   #13
FenixTX717's Avatar
Posts: 246   (View Stats)
FenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant future
^ that. An old school trick which works very well. Have had it for almost 2 years on 2 of the mounts in my DSM and have prothane in the other 2. Works great and a tube cost like 15 bucks at the auto store. I could have did all 4 mounts with 1 tube but only needed to do 2.
FenixTX717 is offline   Reply With Quote
The Following User Says Thank You to FenixTX717 For This Useful Post:
 Old 07-27-2010, 03:07 AM   #14
86AmishMs3's Avatar
Groans: 338
as long as the rmm is in good condition i'm game. I'm in gilbert but i can drive up there, we don't have to install since the heat is a bitch.
budget tuning and modding.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
Last edited by 86AmishMs3; 07-27-2010 at 03:07 AM. Reason: MSF Database - Automerged Doublepost
Rear motor Mount Franconemo MazdaSpeed 3 - Engine, Transmission & Driveline 13 09-26-2009 10:47 AM
another SU REAR MOTOR MOUNT armarine04 MazdaSpeed 3 - Engine, Transmission & Driveline 4 04-23-2009 06:45 AM
Page generated in 0.34811 seconds with 29 queries
