| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
(Thread Starter) | Not Ranked : 0 score I've got an 07 speed3 getting close to 80k. I have the dogbone tranny mount, which is pretty stiff and transfers a lot of tranny noises to the cabin. My throwout bearing is loud, it kind of sounds like the engine is knocking but it completely goes away once the clutch pedal is fully pressed. So, I've researched and some say not to worry about it. My stock clutch is still good. Should I replace that throw out bearing? Am I risking anything? |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score Another TOB thread...How useful! Bro, do you even search? |
| The Following User Says Thank You to Agent_Orange For This Useful Post: | Johnasaurus (06-30-2014) |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,502
| Not Ranked : 0 score OP, just roll with it. Normal. And, yes, stiffer mount(s) make it louder. And please search before posting. While you claim to have done so, must not have read much.
![]() Join Date: Nov 2008 Location: Chelsea, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Owned my 08 speed since new, has 81k on it. my throw out bearing has always done it. in fact come to think of it, every manual vehicle i've owned did it to an extent. leave it alone, save your $$. when its time to do the clutch, do the bearing too! |
| Not Ranked : 0 score If it's REALLY loud, it might be the dual-mass flywheel coming apart.
| Noisy Throwout Bearing | urville | 2010 MS3 - Engine, Transmission & Driveline | 58 | 11-24-2015 03:23 PM |
| Lube in place throwout bearing | wolph69 | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-01-2013 08:20 AM |
| Clutch install, is my throwout bearing/ thrust bearing fork dead? | Mad_Aussie | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 04-22-2013 04:40 PM |
| Think my wheel bearing needs to be replace? | contreras | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 09-08-2012 09:11 AM |
| should i replace my struts before getting springs? and another question | mazdaspdmike | MazdaSpeed 3/6 - Suspension & Brakes | 24 | 06-16-2011 01:27 PM |
