| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() | | #161 | ![]() |
| Not Ranked : 0 score |
![]() | | #162 | ![]() |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Thanks Raider. As you can see I'm a noob here. How do I contact the seller, do I join VIP membership first ? |
![]() | | #163 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score you cannot contact them here, they were kicked out for a reason google them and deal with em direct if you want |
![]() | | #164 | ![]() |
| Not Ranked : 0 score You do not wanna do business with a banned vendor. If you go VIP, I will post/pm you who you need to talk to, ok? You need 5 more posts for PM access. I recommend posting a thread with pics of your car, too. |
![]() | | #165 | ![]() |
| Not Ranked : 0 score Thanks again although I'm having second thoughts now I've seen the price of the SST's. When I add in the $200 for them to the cost of the parts and the tools I'll need to buy (torque wrenches, breakers and deep sockets) I'm starting to get close to the dealer's price to handle the repair. Does anyone sell them once they've used them ? What kind of prices ? If you can give me an idea I'll give the membership some thought. |
![]() | | #166 | ![]() |
| Not Ranked : 0 score This is not a "weekender" project. The cams are not marked, and if not 100% set, timing is off. I personally recommend getting the parts at a steal from VIP member who has access/sells OEM Mazda parts, taking to the dealer for install. I personally paid $1200 for this last year on my CX-7. Then found another local dealer said they would do it for $550 plus parts. Parts I think are about $300 from this seller on here. I am good at working on cars, but when I saw all the other fails at non-mazda shops even fucking it up, I sent mine to the dealer. If you get it done, get the old parts. DCR Racing pays $75 for used VVT actuator cores, sent via paypal. |
![]() | | #167 | ![]() |
| Not Ranked : 0 score I haven't seen to many horror stories yet but as I am a weekender maybe I am better leaving this to the dealer. I've read a few how to's and they all seem straightforward with the right tools. I will be rebuilding the turbo myself once the VVT is fixed. I'll look into buying the parts myself and asking the dealer to fit them - thanks for the info on DCR btw. |
![]() | | #168 | ![]() |
| Not Ranked : 0 score I will also assume you are over 70K miles. See: http://www.mazdaspeedforum.org/forum/foru...thread-102153/ Stock out with your cock out, if you attempt warranty. |
![]() | | #169 | ![]() |
| Not Ranked : 0 score Oh yes, trust me, I know about those. I have a story. My wife and I both bought new Mazda's on the same day at the same dealer late in 2006. She got a CX-7 and me a Speed6, both Grand Touring. We put 100K warranties on both. At about 25K my MS6 started smoking and the dealer "fixed it" under warranty. At the time I didn't know what it was and wasn't to bothered to know either since it was covered. Fast forward to a month ago and my wife calls me to tell me there is a horrible rattle from her engine and she can't accelerate. She was a couple of miles from home so I went out and got her. I babied her car home and she drove the MS6. We both now have about 120K on them. I knew immediately that her motor was fucked but didn't know why until I checked the oil. She only had about a quart and a half in it. We towed it to Mazda. Just prior to this my MS6 had started rattling on cold starts and I spoke to a former Mazda tech who assured me it was nothing to worry about and that the fix was $1500 and in his opinion unnecessary on a car that age....so, based on his opinion I ignored it. Anyway, back at Mazda the service department told us it would be $10,000 to replace the motor on the CX-7. At this point I flipped on him because I had done some research on here after we dropped it off and I now knew that the problem was likely caused by the turbo leaking oil into the exhaust which caused low engine oil (with no warnings either) which basically detonated the motor. Since they (Mazda) knew very well about the issue of the smoking turbo and when mine had been replaced they didn't even warn us that my wife’s could go bad I thought it only reasonable that it be covered under warranty. Anyway, we stamped our feet a bit and took it up a few levels in Mazda and they eventually repaired it all for $3,800. We got it back last week. They even had the nerve to ask if we would prefer to just trade it in for a newer model instead of repairing it. The MS6 now needs the VVT repaired, presumably a new chain and tensioners then the turbo rebuild. They quoted me $3,500 for all of it which presumably means a new turbo instead of a rebuild. They “generously” offered to drop their labor charge from $94/hr to $64/hr on what they tell me is an 18 hr quoted job. (I expect the figure in the parts when quoting a by the hr job). As I said earlier I’ve found the rebuild kit online for about $50 and have seen the how to videos from here for removal and rebuild. Mazda can GFT if they think they are doing all the work on my dime. I should use the 2K to buy a better turbo… In the meantime I keep it under 3500 rpm and stay off the boost.....and pray. Will I buy another Mazda after this ? Fuck no. |
![]() | | #170 | ![]() |
![]() Join Date: Jun 2011 Location: Okinawa, Japan
Rep Power: 161 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score I have the timing tools if you want to rent them. Located on MD.
__________________ [FONT="Franklin Gothic Medium"]2007 MS3 // Cobb AP // Cobb SRI // SURE TIP // Forge BPV // ATP 3" Catless Downpipe // Custom Midpipe // Autotech Internals // JBR 88 RMM/TMM 80 PMM // Denso ITV22 // DCR VVT // Custom Head P & P // Wiseco 9:5 CR on Eagle Rods // Prosport Boost & Wideband Gauges // Rebuilt K04 // 20% Tint // H&R Sports // HID 9K Low / 6K Fogs // Engine built at IAG Performance, Westminster, MD // Stratified Tuned (partial due to engine noise = knock)[COLOR="Red"] |
![]() | | #171 | ![]() |
| Not Ranked : 0 score Thanks, what do you charge on the rental and shipping to CT ? |
![]() | | #172 | ![]() |
![]() Join Date: Jun 2014
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Jesus mary and joseph... I did the test and i can basically pull my chain off the fcking pulley :'( It ia me and the bluddy warranty now, i took my car for a service 5000kms ago and they didnt pick this issue up as it was there before i took it in... I thought the stutter was from blocked intake valves etc Fck me sideways... Not Sent from my iPhone and Definitely Not using Tapatalk
__________________ https://www.youtube.com/watch?v=cST7atvUrrw 08 MPS3 GenOne |
![]() | | #173 | ![]() |
![]() Join Date: Jan 2013 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
__________________ '08 red MS3- COBB SRI, COBB RMM, COBB DP, forge BPV | |
![]() | | #174 | ![]() |
Groans: 793
| Not Ranked : 0 score Chain tension needs to be verified with cyl 1 @ TDC. There a quite a few things that would cause a car to not accelerate. The stereotypical VVT failure isn't one of them. The VVT rattle happens at cold start.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #175 | ![]() |
| Not Ranked : 0 score You could pull the timing cover and look for marks on the inside above the timing chain. I don't know if it's necessarily indicative of a loose chain or bad VVT but maybe others can comment on that.
__________________ Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM |
![]() | | #176 | ![]() |
Groans: 793
| Not Ranked : 0 score Lots of people report scars on the valve cover on higher mileage vehicles. I've yet to see anyone confirm they have a car WITHOUT scars on the valve cover.
![]() | | #177 | ![]() |
| Not Ranked : 0 score You can also check the VVT to see if the "button" is worn. Think of the VVT as a short cylinder, the button is on the outer wall. If it's wearing away the metal on the wall around it it's probably toast. If it's missing altogether then drain the oil and hope it comes out with the oil. Some people say there's a chance it could get into the timing gear and cause the chain to hop a tooth, seems unlikely but IDK.
![]() | | #178 | ![]() |
![]() Join Date: Nov 2010 Location: Stormville, NY
Rep Power: 1415 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,027
Groans: 155
Groaned at 44 Times in 37 Posts
| Not Ranked : 0 score Add me to thst list. 174k miles and clear chain grooves on the cover. Im getting my chain done at a dealer. The savings vs risk aren't worth it to me.
__________________ Want to win a v3 Cobb Access Port? Enter the raffle and help a good cause. http://www.mazdaspeedforum.org/forum/forum/f510/cobb-accessport-v3-raffle-good-cause-190013/ |
![]() | | #179 | ![]() |
Groans: 793
![]() | | #180 | ![]() |
![]() Join Date: Feb 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I'm on the same boat, I have rattling sound during cold start and I'm at 143k. I got 3 quotes from 3 Mazda dealer the highest quote 2,100.00 and the lowest 1,400.00.
__________________ 09 White Mazdaspeed 3 Koni Yellow/Eibach pro kit |
![]() | | #181 | ![]() |
I know all of that vvt stuff.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | ||
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Tokay444 (01-12-2015) |
![]() | | #182 | ![]() |
![]() Join Date: Jan 2015 Location: College Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 202
| Not Ranked : 0 score Looks like I'm going to be tackling this in a few weeks |
![]() | | #183 | ![]() |
Groans: 793
And yes, chain stretch and VVT are two separate issues. Likely unrelated.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
![]() | | #184 | ![]() |
| Not Ranked : 0 score That list for sure isn't complete unless there are different VVTs. Having said that there are some older MZRs and maybe some miata MZRs that missed out on VVT. The majority of MZRs produced in the last 2 model cycles have had it though.
![]() | | #185 | ![]() |
Groans: 793
| Not Ranked : 0 score This of course all stems from the head gasket thread. The document however, fits the subject matter if this thread better. Hence the mention.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 01-12-2015 at 05:29 PM. |
![]() | | #186 | ![]() |
![]() Join Date: Apr 2015 Location: Fort Riley
| Not Ranked : 0 score I'm hoping nothing fails on me...we bought the CX-7 used with 91k on the clock, and we've driven over 1k miles in a week, with no issues. Other than the rattle on cold start up which goes away immediately. Looking at getting the chain done in a few weeks. But the dealer has a 2 week wait on any Mazda service work. It's mainly just daily driven, and driven pretty easy... |
![]() | | #187 | ![]() |
| Not Ranked : 0 score Cold rattle is VVT failing. Make the appointment, and get it in there ASAP. |
![]() | | #188 | ![]() |
| Not Ranked : 0 score crap...ok |
![]() | | #189 | ![]() |
![]() Join Date: May 2015
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Can anyone confirm whether it is necessary to remove the right drive axle in order to get the crankshaft locking SST in? I have purchased the parts and tools required to replace my timing chain online and am waiting for them to arrive. In the meantime I would like to have things disassembled, cleaned and ready to go. Visually it looks like there won't be enough clearance, but I won't know for sure until I receive the SST. I am hoping one of you experienced Mazda owners could share some of your knowledge. Cheers. Last edited by CharlieChuckles; 05-19-2015 at 11:03 AM. Reason: dumb |
![]() | | #190 | ![]() |
| Not Ranked : 0 score idk how much of a difference there is on the cx-7, but I didn't have to remove any axle to get to anything |
![]() | | #191 | ![]() |
![]() Join Date: May 2016
| Not Ranked : 0 score Does anybody know please when to replace timing chain kit on CX7 2.3 turbo? My car is 2007 with 358thousand kilometres on the clock and still running nice, smooth and quiet. The engine has never been dismantled, all parts are original since new. What is the chain replacement interval? 500K kilometres? Cannot find any information anywhere. Or just leave it and wait for first signs of rattling sound? Thanks a lot for any help... Odoslané z HUAWEI P7-L10 pomocou Tapatalku |
![]() | | #192 | ![]() |
![]() Join Date: Sep 2017
Rep Power: 0 ![]() Thanks: 3
![]() | | #193 | ![]() |
![]() Join Date: Sep 2019
| Not Ranked : 0 score I have a 2006 Mazda 3S hatchback with 192,000 miles that is throwing a p0011 ("A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)) and p0016 (Crank/Cam Position Correlation – Bank 1 Sensor “A”) Also threw a p0138 (O2 Sensor Circuit High Voltage (Bank 1, Sensor 2) previously but hasn't come back. I noticed the CEL then the car developed a rough idle later in the day. It died while at a stopsign on the way home and wouldn't stay running until the 3rd restart. Then died as soon as I got into the driveway as I stopped in the driveway. It also developed a loud dragging sound about halfway through the drive as if the calipers were sticking. At first it was fairly quiet but became much louder as the drive went on and after the car stalled and was restarted. The noise only occurred while driving. What steps should I take to diagnose this? What parts should I order? I checked the oil and while low, it was registering on the dipstick just around the min line. The car does burn oil and is often what appears to be significantly low (down 1+ quarts when checked after a few weeks or changed). Thank you |
| The Following User Says NO Thank You to Exclus23 For This Un-useful Post: | Db09ms3 (09-04-2019) |
![]() | | #194 | ![]() |
![]() Join Date: Oct 2019
| Not Ranked : 0 score Cheap cialis no prescription <a href="http://cialismrxcialis.com/#">Buy Cialis Online</a> how to buy cialis online |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/replacing-timing-chain-71935/ | ||||
| Grzechot ?a?cucha rozrz?du i jednostka vv / rolki noisey • Mazda MPS Owners Club | This thread | Refback | 02-10-2013 02:23 PM | |
| The dreaded hesitation has returned • Mazda MPS Owners Club | This thread | Refback | 10-17-2012 03:18 PM | |
| Mazdaspeed Forums | This thread | Refback | 08-07-2012 02:37 PM | |
| anyone change their own timing chain tensioner? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 04-30-2012 06:52 AM | |
| Group buys | This thread | Refback | 01-12-2012 08:17 PM | |
| Mazda MPS Owners Club • View topic - The dreaded hesitation has returned | This thread | Refback | 06-17-2011 11:53 AM | |
| Mazda MPS Owners Club • View topic - Timing Chain Rattling and vv unit / pulley noisey | This thread | Refback | 04-28-2011 12:32 AM | |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Timing chain | Boosted Beluga | MazdaSpeed 3 - How-To's | 10 | 03-21-2013 11:48 AM |
| Mazda replaced timing chain/assembly | Docnox | MazdaSpeed 6 - Engine, Transmission & Driveline | 11 | 01-28-2011 11:40 PM |
| Timing chain tensioner and guide | cbspeed3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 12-06-2010 05:27 AM |
| timing chain and tensioner replaced | scoobz | 2010 MS3 - Troubleshoot/Diagnostics | 0 | 06-29-2010 02:59 PM |
| Timing chain slack? | Thestaplegunkid | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 11-05-2009 03:47 PM |
