 Old 11-10-2009, 10:55 PM   #1
Default Rod bending observations
I have 4 bent/broken rods from 2 motors and I made an observation about these that threw me off. All the rods were bent towards the same side. They are bent towards cylinder #4. Thestaplegunkid's bearings showed one sided wear on all the rods - not just the broken ones. I started to think about the geometry of the situation and made some discoveries.
The pictures below tell an interesting story - sorry about the large size but it is needed. The small end bearing is lined up with the web of the rod that supports the loads that run along from the front to back axis of the motor. However, the flanges of the rod (that support side to side load) are NOT lined up with the web and the bearing itself.
Look through the pictures and you should see the imperfections. They are about 0.5mm off. This is what happens when you don't machine the entire surface of the rod. I can only imagine how many of these types of tolerances can stack up.
EDIT: This is something I saw in all the rods I have. It is likely a result of the forging process.
The Following 60 Users Say Thank You to Lex For This Useful Post:
06Speed6 (11-11-2009), AmillieMS6 (11-11-2009), ATAZ (01-05-2010), aviator79 (11-14-2009), bioevolve (11-11-2009), BoostIsBetter (11-11-2009), Chief_Wiggum (11-11-2009), cudaman (01-04-2010), D-Rick21 (11-16-2009), DaleNixon (11-12-2009), Darksun280 (11-11-2009), Demi (11-11-2009), djthom (11-16-2009), djuosnteisn (11-11-2009), doubleflusher (11-12-2009), E4Performance (11-11-2009), Fagwagon (11-11-2009), FearUndersteer (11-11-2009), fhaze (11-12-2009), Fobio (11-11-2009), glocK23 (11-11-2009), gsrtype1 (11-13-2009), hyun (11-11-2009), IshiKage (11-10-2009), jrp (01-02-2010), kgb (11-11-2009), kore2000 (11-11-2009), KoukiS14 (11-11-2009), madvillain (11-11-2009), MarkyMark (11-11-2009), mazda.speed3 (11-11-2009), mazdarati (11-12-2009), meatball18 (11-14-2009), mexicant (11-11-2009), MicaBlackMS6 (11-11-2009), MS3Zoom24 (11-11-2009), Murse (11-11-2009), NJSPEED3 (11-11-2009), Nliiitend1 (11-15-2009), NRSpeed (11-12-2009), nyghtryder (11-11-2009), phantom3 (11-11-2009), psychophyr (11-11-2009), QuickSpool (11-12-2009), RacingToaster (11-10-2009), s-retire (11-11-2009), SharkDiver (11-11-2009), speed23 (11-11-2009), SpeedSixxx (11-11-2009), spnkr21 (11-12-2009), superskaterxes (11-11-2009), Superstretch18 (11-13-2009), Thestaplegunkid (11-11-2009), the_caruch (11-12-2009), tmtbiker (11-11-2009), toprock (11-11-2009), ungrave (11-12-2009), wakeboarddude (11-11-2009), wcm250f (01-10-2010), xcoldricex (11-13-2009)
 Old 11-11-2009, 12:15 AM   #2
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
I hope only a small percentage of MS3/MS6 motors have these forging imperfections.
glocK23 is offline   Reply With Quote
 Old 11-11-2009, 02:26 AM   #3
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
SpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the world
Groans: 778
I would sure hope so as well.
If you think about it, most of the bent rod motors have gone at a pretty early age (low mileage) some of us are higher then others me being 50k in a week or so.
really I guess the only way to tell is to take our motors apart and take a look but hell, if you do that then I guess you should just replace everything with new parts.
Lex, can you fit one of those tiny micro scope cameras down in the crank case and check out the rods and bearings?.... is it even poss to tell from a scopes eye view if the imperfection is there? or you need a digital caliper?
again, hope it's only a small percent with these imperfections and I assume so cause it's not like you hear of everyone motors dropping like flies here on Msf.org...
One thing I think we should do is go back into the blown motor thread and ask all the members with blown motors to check their VIN and see what factory in Japan their car was built at. I know the speed 3 and 6 were built in two different cities factories in Japan.
Maybe it could be poss for the cars with the imperfections to have come from only one single factory.
or I could be all wrong---meaning
I would now assume that all the pistons and rods crank ect...are forged and manufatured in one plant and then sent to both factories. In that case I would assume that there are imperfected rods in cars from both factories.
maybe....the factories got their internals from different factories?....
there are so many variables but if we could pin point where the defective rods come from then we would have a better idea of who could potentially blow.
2003 SilverStone Grey Honduh S2000
SpeedSixxx is offline   Reply With Quote
 Old 11-11-2009, 07:36 AM   #4
lol can we get lex his own section? lol like NATOR LEX haha. atleast someway to get all his findings and threads together in one place
The Following 10 Users Say Thank You to superskaterxes For This Useful Post:
ATAZ (01-05-2010), djthom (11-16-2009), doubleflusher (11-12-2009), FearUndersteer (11-11-2009), MS3Zoom24 (11-11-2009), phantom3 (11-11-2009), predapio (11-11-2009), SpeedNess (11-11-2009), SpeedSixxx (11-12-2009), xcoldricex (11-13-2009)
 Old 11-11-2009, 07:59 AM   #5
BoostIsBetter's Avatar
Posts: 582   (View Stats)
BoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the world
Groans: 32
Groaned at 31 Times in 18 Posts
lex, props to you for all your help to the community. maybe you should start your own company like RaceRoots and not charge up the ass for secrets but help the world instead, haha.
BoostIsBetter is offline   Reply With Quote
The Following 4 Users Say Thank You to BoostIsBetter For This Useful Post:
doubleflusher (11-12-2009), SgtP (11-11-2009), SpeedSixxx (11-12-2009), superskaterxes (11-11-2009)
The Following User Says NO Thank You to BoostIsBetter For This Un-useful Post:
 Old 11-11-2009, 08:53 AM   #6
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
Interesting so, if I understand you correctly, the top of the rod is bent towards 4, thus the bottom is pushed towards the pass side of the vehicle, engine in.
This may explain why we don't see rashes of blown CX-7 mills. Aside from the obvious fact that CX-7 owners aren't rev-happy punk-asses trying to squeeze 5000 hp out of the stock tune, there's a big mechanical difference: the auto trans. The auto has a big ass torque converter bolted to the flexplate and it doesn't impart hundreds of pounds of compressive side force to the crank, like happens when the clutch is used. The force is momentary but, large. I wonder what is an acceptable amount of crank float on these engines and whether the tolerance stack-up is leading some to be extreme in this regard? Are there indications of excessive movement at the other end of the crank like spalling on the inner side of the block or whatever kind of thrust plate limits this movement?
 Old 11-11-2009, 09:08 AM   #7
Doc-1's Avatar
Posts: 407   (View Stats)
Doc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the worldDoc-1 is the leader of the world
Groaned at 30 Times in 15 Posts
To me FORD has a hand in this. When I stopped buying US made cars in 83 this is exactly why. Had a 460 FORD motor go bad at 2,000 miles for just this reason. Will they ever learn. Quality Job 1.....right up your ass.
Doc-1 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Doc-1 For This Un-useful Post:
 Old 11-11-2009, 09:23 AM   #8
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
Did these still have the rings on them? How did they look?
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
 Old 11-11-2009, 09:29 AM   #9
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
you bought junk. . .
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
The Following User Says Thank You to mexicant For This Useful Post:
speed3 (11-17-2009)
The Following 3 Users Say NO Thank You to mexicant For This Un-useful Post:
 Old 11-11-2009, 09:42 AM   #10
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
You should break this down barney style for ppl that dont understand. Good work!
The Following 3 Users Say Thank You to Fagwagon For This Useful Post:
DaleNixon (11-12-2009), doubleflusher (11-12-2009), predapio (11-11-2009)
 Old 11-11-2009, 09:54 AM   #11
WOT @1k RPM!
NRSpeed's Avatar
Posts: 1,570   (View Stats)
NRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the world
Groans: 47
Groaned at 50 Times in 33 Posts
I cant be bothered to search for the info, but wasnt TrickyTwelve inch going to blow the whole thing wide open and teach us all what was really the problem?
Lex, are these from the same year engine?
MazdaSPEED3 2009 - Mica Black
http://www.mazdaspeedforum.org/forum/forum/f8/setting-avatar-new-users-other-noobs-43712/
http://www.mazdaspeedforum.org/forum/forum/f8/uploading-adding-images-your-post-43704/
No BB URL code = sux
NRSpeed is offline   Reply With Quote
 Old 11-11-2009, 09:59 AM   #12
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
yes he was and check out how awesome his first draft was:
http://www.mazdaspeedforum.org/forum/foru...engines-41236/
 Old 11-11-2009, 11:05 AM   #13
There are crank counterweight marks on both sides of the big end of each rod I saw. If the rod is bend, the marks are deeper into the rod. If the rod is bent severely the counterweight hits the bottom of the pistons and material starts to come off.
Based on people's observations and my own, yes, the rod has some side to side movement and yes during a shift it would be offset towards the passenger side. This may be even more significant than the imperfect construction of the rod itself.
These rods seem to mainly bend along the left-right axis of the motor. This can very well be because the cylinder pressure is not centered on the load axis of the rod and the tolerances are not tight enough. This is part of the motor design - no motors are perfect - we are just seeing a combination of cylinder pressure (for various reasons) and enough tolerance deviation (it is mass produced after all) to overwhelm the ultimate tensile strength of the rod along that axis.
Also note that ALL the rods I have are constructed this way. They range from an MS6 to an 08.5 MS3. So there is no point in checking this inside your motor.
 Old 11-11-2009, 11:06 AM   #14
Thestaplegunkid's Avatar
Posts: 150   (View Stats)
Thestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the world
Lex, I just checked my 3 remaining Rods. They all show the exact thing you've measured. A 0.5mm difference in the small rod end centering. And they all correspond to the uneven bearing wear on the large rod end.
And #4's bend is also in the direction of the off center force caused by this.
Excellent find.
Thestaplegunkid is offline   Reply With Quote
The Following 8 Users Say Thank You to Thestaplegunkid For This Useful Post:
06Speed6 (11-11-2009), DaleNixon (11-12-2009), djuosnteisn (11-11-2009), FearUndersteer (11-11-2009), Lex (11-11-2009), SpeedSixxx (11-12-2009), superskaterxes (11-11-2009), xcoldricex (11-13-2009)
 Old 11-11-2009, 11:14 AM   #15
RacingToaster's Avatar
Posts: 426   (View Stats)
RacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the world
Groans: 40
Does that mean that the crank is shifting to one side causing this?
RacingToaster is offline   Reply With Quote
 Old 11-11-2009, 11:25 AM   #16
Excellent find.
Thanks for looking into this. This is probably a large reason as to why we're bending rods all the time and say an Evo or SRT4 are not when the rod dimensions and forging are quite similar. The fact that we have a pretty long stroke really doesn't help as it amplifies the effects of the poor geometry.
More of a reason to limit torque, low RPM load, detonation, and flat foot shifting on the stock bottom end.
EDIT: Some cars will have poorer tolerance stack up (not just the rods, but all tolerances) than others and those are more susceptible to this problem.
Fobio (11-11-2009), SpeedSixxx (11-12-2009), xcoldricex (11-13-2009)
 Old 11-11-2009, 11:57 AM   #17
toprock's Avatar
Posts: 749   (View Stats)
toprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the world
Groans: 40
Groaned at 27 Times in 21 Posts
Lex should have his own forum section for all his observations. My .02cents.
CP-E SRI / Forge BPV / Corksport TP / Corksport CBE
toprock is offline   Reply With Quote
The Following 2 Users Say Thank You to toprock For This Useful Post:
 Old 11-11-2009, 12:03 PM   #18
FearUndersteer's Avatar
Posts: 189   (View Stats)
FearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the world
I applaud your efforts!
So are quality aftermarket rods the answer, atleast to abate this issue?
2009 MazdaSpeed3 | True Red
35% Tint
CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC
FearUndersteer is offline   Reply With Quote
 Old 11-11-2009, 12:13 PM   #19
If pushing the motor and you don't want to take risks, it seems like a simplest solution.
 Old 11-11-2009, 12:40 PM   #20
blackrs99's Avatar
Posts: 314   (View Stats)
blackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the world
Groaned at 8 Times in 5 Posts
So basically this is like a mini crankwalk? That's apparently a strain on already improperly manufactured rods? FML
::: Cobb AP ::: HTP 3" Full Intake ::: Ebay DP ::: CNT CBE ::: JBR Triology ::: JBR SSP ::: JBR RSB ::: CS TMIC ::: MSD Dashhawk ::: White PC RX-8 Wheels wrapped in Continental DWS 225-40-18 :::
::: DIZZY TUNED by Boost_creep :::
blackrs99 is offline   Reply With Quote
 Old 11-11-2009, 12:57 PM   #21
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
i got the good set of 09 mazda rods as well as samsel450r
The Following User Says Thank You to For This Useful Post:
 Old 11-11-2009, 07:11 PM   #22
wassup61's Avatar
Posts: 1,232   (View Stats)
I gawt me some pauterz??
Seriously though, the side loading of these rods is worrisome, but there was a correction in 08.5 with a diamond cut thrust washer (more precise tolerance) that was designed to prevent lateral deflection in the crankshaft.
All wagon, No traction
The Following 2 Users Say Thank You to wassup61 For This Useful Post:
DaleNixon (11-12-2009), mexicant (11-11-2009)
 Old 11-11-2009, 07:28 PM   #23
serium's Avatar
Posts: 448   (View Stats)
serium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the world
Groaned at 34 Times in 12 Posts
Makes me feel a little better with my 08.5 but i drive like an old lady now just because im soo no trying to pay for another engine :/
2008.5 Red Mazdaspeed 3
Performance Mods: OBX RP | SURE Intake | SU-TMIC | Cobb TIH | Turbosmart Hybrid BOV | JBR 80 Duro RMM | Hypertech
Appearance Mods: 15% tint | Blacked-out Emblems, Side Markers and Side Reflectors
Monitoring: Dashhawk
serium is offline   Reply With Quote
 Old 11-11-2009, 07:33 PM   #24
18psiWhiteMS3
Lurkers
Posts: n/a
jeff are you serious???? i have an 09 woooo wooooooo
IshiKage (11-12-2009)
 Old 11-11-2009, 07:37 PM   #25
JumpingJackson's Avatar
Posts: 967   (View Stats)
If i got a new thrust washer for my engine build, it would be the updated one right?
 Old 11-11-2009, 07:58 PM   #26
Don't worry about it... mine was an 08.5 and it blew up just as well as the earlier ones
The Following 2 Users Say Thank You to Thestaplegunkid For This Useful Post:
djuosnteisn (11-11-2009), SpeedSixxx (11-12-2009)
 Old 11-11-2009, 09:18 PM   #27
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Thanks for taking away all my worries.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 11-11-2009, 09:41 PM   #28
kgb
kgb's Avatar
Posts: 808   (View Stats)
Groans: 88
So....Mazda designed our Mission Impossible ECU to target high loads, at low RPM on incorrectly sized rods with a long stroke? FOL (Fck Our Life)
Do you think they knew about the rod size problem....
I'm sure they will now...
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
 Old 11-11-2009, 10:18 PM   #29
Is there a way to check a part number for this? Thestaplegun's motor looked really bad in terms of side loading the rods and it was an 08.5
 Old 11-12-2009, 04:33 AM   #30
SpeedSixxx's Avatar
Groans: 778
just saying...lex did mention that his bent rods came from Ms6 to a 08.5 ms3....
 Old 11-12-2009, 08:10 AM   #31
smakdown61's Avatar
Posts: 1,069   (View Stats)
I wonder if its possible to take it to a lawsuit if mazda denies your warranty claim due to mods. If you have a pre 08.5, this type of evidence plus the new diamond cut bearings they added in points to them trying to cover up a problem.
smakdown61 is offline   Reply With Quote
 Old 11-12-2009, 08:47 AM   #32
they arent going to warranty shit if they claim you werent stock.
 Old 11-12-2009, 10:05 AM   #33
WOT @1k RPM!
NRSpeed's Avatar
Groans: 47
So I googled up Crank walking and found this. Very good info. Also found another and they are all about DSMs.
So, it may be wearing on the thrust bearings in combination with possibly uneven rods? These two powers combined form Captain Capow!
 Old 11-12-2009, 10:18 AM   #34
Captain
It's funny, forzda on 6club was talking about the thrust bearing a long time ago. He even mentioned how to check for it with a 2x4, and what amount of movement was "ok".
HERE was forzda's thread.
www.permtuning.com
Last edited by djuosnteisn; 11-12-2009 at 10:29 AM. Reason: MSF Database - Automerged Doublepost
MarkyMark (11-12-2009), tmtbiker (11-14-2009)
 Old 11-12-2009, 12:30 PM   #35
WOT @1k RPM!
NRSpeed's Avatar
Groans: 47
Yea, seems that Forda says the same thing in one of the links I posted about how important it is to jumper the clutch safety.
Ill be reading up on all this during lunch. Learnin is fun!
 Old 11-12-2009, 01:50 PM   #36
smakdown61's Avatar
What if you claim there is a manufacturing defect?
 Old 11-12-2009, 02:05 PM   #37
QuickSpool's Avatar
Posts: 235   (View Stats)
QuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to behold
Groaned at 9 Times in 5 Posts
I forsee more intrest in PTP's crank straps and 06Speed6's possible billet main.
QuickSpool is offline   Reply With Quote
The Following User Says Thank You to QuickSpool For This Useful Post:
ptperformance (11-20-2009)
 Old 11-12-2009, 02:10 PM   #38
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
So the diamond thrust washer in the 08.5+ should prevent this but plenty of 08.5's have blown?
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 11-12-2009, 02:57 PM   #39
WOT @1k RPM!
NRSpeed's Avatar
Groans: 47
Still hear-say till we get a part number or someone finds the part breakdown.
 Old 11-12-2009, 03:38 PM   #40
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
this has something to do with some people reporting clutch vibrations leading to a rod exiting the block?
2008 STi
Intake
Turboback
AP
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/rod-bending-observations-42105/
Ok mod stage advice.. This thread Refback 01-07-2013 01:16 AM
Forge BPV for the 2010 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 02-22-2010 09:41 PM
Ok mod stage advice.. - Mazda CX-7 Forums This thread Refback 12-22-2009 07:05 AM
A2SportCompacts :: View topic - AFCadet's engine This thread Refback 11-20-2009 08:17 AM
Vague Observations on Boost and Load Tables fjames
Cobb ATR Support
5 09-02-2009 08:48 AM
Intake vs. boost observations Hectik1 MazdaSpeed 3/6 - Turbo Induction 12 05-16-2009 05:07 PM
Open/Closed Loop Transition, Some New Observations superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 1 07-18-2008 11:35 AM
Page generated in 0.60381 seconds with 46 queries
