 Old 10-28-2011, 10:17 PM   #1
sjuliani's Avatar
Posts: 1   (View Stats)
sjuliani is an unknown quantity at this point
Default Setting Timing cam gears 2.3L Turbo Speed3
I'm trying to set the timing on a 07 Speed 3 engine but i'm unsure on how to lock in the cam gears, there does not seem to be a key to tighten the gears in place.
Any help will be much appreciated.
sjuliani is offline   Reply With Quote
 Old 10-29-2011, 07:29 AM   #2
BlueStreak's Avatar
Posts: 1,467   (View Stats)
You need a special service tool (SST) which fits into the slots cut into the back of the cams. You'll also need a plug bolt that will position cylinder 1 at top dead center.
Stefan at Eagle Motorsport (MSF Vendor) can hook you up.
'07 CWP MS3
Forged.
 Old 10-29-2011, 06:24 PM   #3
speed31982's Avatar
Posts: 186   (View Stats)
speed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the worldspeed31982 is the leader of the world
Yeah you can rent for a small fee or buy.
speed31982 is offline   Reply With Quote
 Old 10-30-2011, 05:08 PM   #4
Tech/Sales@EM's Avatar
Posts: 1,173   (View Stats)
Tech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the world
Groaned at 28 Times in 11 Posts
We do have plenty if you need some. There are a few rentals out there now and can easily be shipped to you.
Tech/Sales@EM is offline   Reply With Quote
Tuning TIming Big Turbo Cobb AP Nitr0EngiE MazdaSpeed 3/6 - ECU Computer Tuning 87 07-26-2011 04:49 PM
08 Speed3 Turbo Issues 187ricerocket MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 05-23-2011 10:35 PM
Setting timing? TruboPower MazdaSpeed 3 - Engine, Transmission & Driveline 9 05-22-2011 09:34 AM
Turbo timer on 10' speed3? gogogomoveit 2010 MS3 - Engine, Transmission & Driveline 26 04-22-2010 04:06 PM
Amp setting/Line out converter setting? 2k6speed6 MazdaSpeed 3/6 - Car Audio & Electronics 0 07-31-2009 12:10 PM
Page generated in 0.25494 seconds with 23 queries
