| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
Groans: 111
(Thread Starter) | Not Ranked : 0 score After greasing the shifter assembly 3 days back as much as I could without disassembling it it started to come up in like 75% of the cases. Now, I wonder if there is any secondary spring that gave up (the one that I can see seems to be fine) or if it's just because of lack of lubrication (the grease didn't seem to penetrate everywhere because it's not liquid enough, but in time it probably will) or if it's something else. When I greased the shifter assembly I also found that one of the bushings was blown so I ordered the JBR solid shifter bushings, but I guess that will not fix the problem. So anybody else ran into this and can tell me what the problem is before starting to disassemble it entirely?
Groans: 136
| Not Ranked : 0 score It's the spring on the shifter itself. Pull it out of the car if you have to, and clean it and lube it properly. Tapadatass
__________________ |
| The Following User Says Thank You to silvapain For This Useful Post: | mituc (10-14-2012) |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| Not Ranked : 0 score Your shifter is bent and is going to snap soon. Happened to me a month ago. Thin metal at the reverse lockout pin and when it is bent, it is sticking inside the pivot ball. Fix it now before you have a bad day.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
| The Following 8 Users Say Thank You to Turbo_Steve For This Useful Post: | 06Speed6 (10-18-2012), Dash08 (10-17-2012), Easter Bunny (10-17-2012), Kyle Undefined (11-11-2012), mituc (10-17-2012), Mizzle (11-10-2012), Raider (10-17-2012), tddvrrn (10-18-2012) |
Groans: 111
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score If you take the shift boot off, you will see the only thing separating 1st and reverse is a little rubber bump stop and a plate. When you push down to go into reverse the bump stop goes below the plate and allows you to push the knob over to the reverse position. You may have an issue there, but any of these fixes will require taking the boot off, so you may as well just take a look.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following User Says Thank You to Voltwings For This Useful Post: | MazdaBoy2.3 (10-18-2012) |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
Had the same thing happen to me. It all started with the exact same problem you're having. Get it fixed before it snaps. Mine snapped on a 4-3 downshift during very aggressive driving and almost lost it. Don't wait, it will snap soon. | |
Groans: 111
(Thread Starter) | Not Ranked : 0 score Good. I'm ordering the Cobb STS then, I hope that will be better. It will take like 3 weeks to get here though, I'll just try to be more gentle during gear shifts (and I thought I was!).
Groans: 293
It's the fucking king of the hill, man. Look into it before you commit to the Cobb. | |
| The Following User Says Thank You to Dash08 For This Useful Post: | mituc (10-18-2012) |
![]() Join Date: Feb 2011 Location: N/A
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 174
| Not Ranked : 0 score My shifter took a shit too while parked on a hill in reverse. My problem was it would push down, but would not pop back up by itself. I had to manually pull it up. Disassembled shifter, lubed, put back together. Still would not work. Took it to dealership and they gave me a new one under warranty no problem. |
| The Following User Says Thank You to nickm757 For This Useful Post: | mituc (10-18-2012) |
Groans: 111
![]() But Cobb makes quality parts so I should be good, that's why I dind't even check something else since I was aware that Cobb makes one. I may not like the full 30% throw reduction and I'm also thinking to keep the height close to stock, so the Cobb one may work well for me.
Since I started having the problem a few days ago when shifting between the normal forward gears everything is exactly like before. And I know this because I'm sensitive and paranoid enough to feel even the slightest difference. I'll just replace it (I'm still under warranty though) and I'll be fine I guess.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | ||
Groans: 293
A short time later, it snapped completely off. As for the shifter and for all performance upgrades, search around a bit before you buy. Yes, Cobb makes great stuff, but there are many other brands that make equally good, if not better, parts. | |
Groans: 111
(Thread Starter) | Not Ranked : 0 score Ok, mine didn't snap yet but until I replaced it earlier today it was a nightmare. I was needing at least 30 seconds, today one minute and a half, to put the car in reverse. A week ago I was putting my both hands on top of the shifter to push it down, since 2-3 days ago I had to tap it with my fist. FAIL shifter came out: WIN shifter came in: Hello kitty bushings removed too: ...and I installed the JBR ones. The blown bushing was in the opposite corned of the 5th gear, and my shifter bent towards 5th. I think that may be the culprit because I started having problems shortly after I felt the shifter assembly leaning towards 5th and eventually sounding like it was hitting something when shifting into 5th. The Cobb shifter is close to perfection. It would have been perfect if that pin was just a tad shorted (less than 1mm, maybe 0.5-0.7mm) to allow that side rod to be pushed a bit more when shifting into 1st and 2nd.
![]() Join Date: May 2012 Location: fontana, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 893
Groans: 68
Groaned at 62 Times in 29 Posts
| Not Ranked : 0 score Because genjuan
__________________ [SIGPIC][/SIGPIC]2012 Black Mica JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers 324whp 368tq Vdyno CF 1.01 268whp 300tq AWD Mustang Dyno 3 GAL. E85 mix STRATIFIED 13.10 @ 108.1 (Nt05's) Auto Club Speedway |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score Did you guys file a report and post in the thread? For the bent one, when you replace it, keep and and file a report under the same thread so they know what's going on. |
| Sideswipe Magnet ![]() Join Date: Aug 2012 Location: Clearwater, FL
Rep Power: 2827 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,163
Groans: 332
| Not Ranked : 0 score This actually just happened to me, on Saturday night. Snapped exactly where the other picture shows. For several months now I've been dealing with the same issue, having to manually pull up the stem from coming out of reverse. Unfortunately, I bought the car from a Ford dealership and they just kept greasing the spring, but I kept telling them it wasn't the issue. It was like that since the day I bought it. Was going to take it to the local Mazda dealership but with work and all, never could find the time. I did a search awhile ago, but it was before this thread was made, and I kind of forgot. I'm glad I know what caused the issue. I just ordered a COBB STS, because I fell in love with it in my friends MS3. Found this thread by searching for bushing reviews, haha. Going to go with JBR.
__________________ I would love to change the world, but they won't give me the source code. // Logic never changes, just the syntax. // To be the best, you've got to beat the best. Black Mica 2008.5 Mazdaspeed 3 GT // Totaled by 18 wheeler // rfinkle2 pump toon 309 HP - 327 TQ // E85 toon 336 HP - 357 TQ // Too many mods to list Emerald Green 2002 Miata Mods: Koyo 37mm Radiator // Tein Street Flex Coilovers // Flyin' Miata Front and Rear Sway Bars // 949 Racing Endlinks up front // 15x8 949racing 6UL Wheels // Toyo R1R tires // Hard Dog Roll Bar Waiting list: Full vinyl wrap Events: EMWNM '13'14 // MME '13'14 // MNM '14 // NATOR FL BBQ '13'14 LynzeCs bottom bitch. I shall call LynzeC my sloot and she will be mine and she shall be my sloot. Come on, sloot. Come on, little sloot. |
Groans: 324
| Not Ranked : 0 score |
| MS3 OEM Shift Lever Knob Available | dkapetansky | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 08-30-2012 06:56 PM |
| Wont shift into reverse | LandonElf | 2010 MS3 - Troubleshoot/Diagnostics | 3 | 04-16-2011 08:53 AM |
| Refusing To Shift Reverse.. | Silver Ecstasy | 2010 MS3 - Engine, Transmission & Driveline | 9 | 02-25-2011 11:47 PM |
| Park Brake Lever Cover | Simoli | MazdaSpeed 3/6 - Appearance | 3 | 12-08-2010 08:59 AM |
| What happens if you shift into Reverse while driving? | Haltech | Automotive News | 0 | 09-09-2009 06:20 AM |
