 Old 06-03-2010, 05:41 PM   #1
sleeper329's Avatar
Posts: 511   (View Stats)
sleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the world
Default Smoke at idle
So ever since i put in my test pipe ive noticed ill get black smoke sometimes if i let the car idle for a few minutes. It performs fine and ive done a little reading and am guessing this is the PCV valve leaking causing the smoke..?
If so will this help:
PT-Performance.com
Then lastly if that might be the fix for it, is there any how to for its install? And having been driving the car with this smoking have a possibly done any permanent damage to the motor, turbo, etc?
^^USE THIS LINK AND COUPON CODE SURIOT AT CHECKOUT FOR A DISCOUNT!^^
sleeper329 is offline   Reply With Quote
 Old 06-03-2010, 06:20 PM   #2
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
mine did not smoke when i only had a test pipe but it did when i installed a downpipe. the ptp "pill" should work (i had it before).
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 06-03-2010, 07:08 PM   #3
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
Or it could be the turbo seals. The pill did not work for my car but for the price worth a shot. You may also want to contact Brad (Bnoon) and ask him about him banjo bolt replacement for the k04. Some frown on this but it has worked for people.
Parting out!
http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/
Spoolme is offline   Reply With Quote
 Old 06-04-2010, 06:56 AM   #4
sleeper329's Avatar
Cool, I'll probably order this over the weekend then.
Does it come with install instructions? b/c i dont even know where it goes. lol
 Old 06-04-2010, 08:19 AM   #5
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
man, look around here and at 2-4-7 and you should be able to figure it out, it goes in the big vac line from the intake to the valve cover, at the valve cover end.
 Old 06-04-2010, 09:04 AM   #6
sleeper329's Avatar
Ok i know what youre talking about then. Real easy.
 Old 06-12-2010, 10:44 AM   #7
Jessed87's Avatar
Posts: 149   (View Stats)
Jessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to behold
I tried every smoking fix that exists and none of them worked. Big turbo is the fix my friend.
Jessed87 is offline   Reply With Quote
 Old 06-13-2010, 01:01 PM   #8
ms3brendan's Avatar
Posts: 1,017   (View Stats)
ms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the world
Isn't black smoke okay? It's just the car running rich? I thought it's the white/blue smoke that's bad since that's the color of oil burning..
2012 BMW 135i //M-Sport
ms3brendan is offline   Reply With Quote
 Old 06-13-2010, 01:56 PM   #9
Decepticon's Avatar
Posts: 1,221   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
5w40 full synthetic oil will help band aid the situation...that's what Mazda recommends in the mean time.
06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...
R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3.
Decepticon is offline   Reply With Quote
Exhaust Smoke???? Ian MazdaSpeed 3/6 - Troubleshoot/Diagnostics 48 11-28-2013 07:25 PM
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
No Smoke SEAFOAM? SpeedSixxx MazdaSpeed 6 - Engine, Transmission & Driveline 6 03-08-2010 04:58 PM
smoke at idle ms3-87 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-31-2008 01:15 PM
Page generated in 0.28085 seconds with 26 queries
