Like Tree24Likes
Closed Thread
 Old 07-23-2012, 07:19 AM   #81
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
What do you recommend on a stock motor? Would I see any benefits running a 1 step colder plug or should I just stick with OEM specs?
3Gee Tee is offline
 Old 07-23-2012, 07:54 AM   #82
If you are running boost levels>stock, you may benefit, otherwise stick with the factory heat range.
tmillner likes this.
rfinkle2 is offline
3Gee Tee (07-23-2012), moomooz12 (07-23-2012), RiceBurn2.3T (08-17-2012)
 Old 07-23-2012, 07:56 AM   #83
3Gee Tee's Avatar
10-4, thanks for the input.
Followup question: Which brand? I hear good things on this forum about NGK and Denso so I assume they're both comparable?
3Gee Tee is offline
 Old 07-23-2012, 08:05 AM   #84
It looks as if people are slowly moving to NGK because of some recent findings of cracked porcelain on the Denso's.
The NGK will need to be regapped because the out of the box gap is a bit large for the ms3.
rfinkle2 is offline
3Gee Tee (07-23-2012), jmhinkle (03-19-2013), moomooz12 (07-23-2012)
 Old 07-24-2012, 08:47 PM   #85
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
I hate to say it rob, but the matte black wrap you have on your car looks DOPE..... how much did it end up costing you?
2008 MS3 gt
470hp/463tq on GT35r at 29psi
burn813 is offline
 Old 07-24-2012, 08:59 PM   #86
BudUMfan's Avatar
Posts: 1,204   (View Stats)
BudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the world
Groaned at 9 Times in 7 Posts
I am running stock boost...for now with step colder NKG's...no issues
BudUMfan is offline
 Old 07-25-2012, 03:43 AM   #87
3Gee Tee's Avatar
What brand and did you have to regap them?
3Gee Tee is offline
 Old 07-25-2012, 08:13 AM   #88
BudUMfan's Avatar
I have NKG and gapped to .030, I will be running 19.5lbs when I retune.
BudUMfan is offline
The Following User Says Thank You to BudUMfan For This Useful Post:
3Gee Tee (07-25-2012)
 Old 07-25-2012, 12:39 PM   #89
lulz @Raider
burn813's Avatar
@rfinkle2 answer my question mang
2008 MS3 gt
burn813 is offline
 Old 07-25-2012, 01:15 PM   #90
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Only use plug gapper tools to open up the plug gap; not to actually measure the gap. Use a set of feeler gauges to measure gap properly.
Tapadatass
Livingframe likes this.
silvapain is offline
The Following 3 Users Say Thank You to silvapain For This Useful Post:
3Gee Tee (08-15-2012), MSMS3 (08-26-2013), theurgy (07-25-2012)
 Old 08-15-2012, 01:09 PM   #91
speed0450's Avatar
Posts: 22   (View Stats)
speed0450 is a jewel in the roughspeed0450 is a jewel in the roughspeed0450 is a jewel in the rough
From reading the thread, since I currently only have a cobb sri and I am running stock boost levels should I go 1 step colder or just stick with the stock heat range. Also have the denso problems been worked out? Thanks
speed0450 is offline
 Old 08-15-2012, 01:15 PM   #92
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
if you had read the thread, you would have read, a whole bunch of times, that stock boost=stock heat range plugs.
maybe it is time to work on the comprehension part of reading?
tddvrrn is offline
The Following User Says Thank You to tddvrrn For This Useful Post:
smoogs12 (08-15-2012)
 Old 08-15-2012, 02:06 PM   #93
speed0450's Avatar
thanks for your input. but also some of the people that are on stock boost are running one step colder and was hoping to hear from them on there opinions of how the car is running with them. i do comprehend reading thru posts and searching before I post. that is the reason that i donated to help the forum stay up and running for me to gain knowledge as everyone else. fyi... ..has never been in my system.
Masterbaiter likes this.
The Following User Says NO Thank You to speed0450 For This Un-useful Post:
xhymer (08-17-2012)
 Old 08-15-2012, 02:21 PM   #94
theurgy's Avatar
Posts: 2,580   (View Stats)
I'm currently running ITV-22's while I'm in between tuning solutions at the moment.
I am currently still on stock tune and boost and it runs fine.
theurgy is offline
speed0450 (08-15-2012)
 Old 08-15-2012, 04:10 PM   #95
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
@speed0450 you want to run the hottest plug you can without pre-ignition.
Tapa
MSMS3 likes this.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
MSMS3 (08-26-2013)
 Old 11-17-2012, 12:40 PM   #96
khoney's Avatar
Posts: 3   (View Stats)
khoney is a jewel in the roughkhoney is a jewel in the roughkhoney is a jewel in the rough
Exclamation Use of anti-sieze on new spark plugs
Twist in until it stops by hand using the extension of the ratchet.. than one 1/4 inch turn to secure. Be sure to use a dab of anti seize on the threads and a dab of di-electric grease on the top of the plug where the coil connects to.
FYI for everyone replacing plugs (especially NGK). It is recommended that anti-sieze NOT be used on initial installation of many spark plugs, especially if you have aluminum cylinder heads. NGK specifically has a tech bulletin related to this (see below). Many plugs these days have a special plating on them that is specifically for anti-sieze purposes. Pretty much any plug with shiny silver threads has this plating. As an old-schooler, this came as a surprise to me, but I no longer apply antisieze to new plugs after reading this:
http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
If you inspect your plugs and reinstall them, the plating can be compromised and then anti-seize may be warranted. Just wanted to pass this along, because I know it flies in the face of what we've been told for many years.
khoney is offline
The Following 3 Users Say Thank You to khoney For This Useful Post:
furinax (11-13-2015), HaXiR (04-13-2015), theurgy (11-17-2012)
 Old 03-19-2013, 06:07 AM   #97
Mfinlay04's Avatar
Posts: 827   (View Stats)
A little concerned NAPA was my previous source for Denso ITV22 plugs and always had them readily available from their warehouse. Granted this was in SoCal, but none of the Midwest Napa's have any or show any in any warehouse or from the mfg. I surely hope these plugs are not getting fazed out... I know they are available online but if they are being discontinued from Denso I might need to stock pile them until a reasonably priced replacement arises.
2006 MS6 Titanium Grey
Tuned with
Mfinlay04 is offline
 Old 03-19-2013, 06:17 AM   #98
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
The Denso one step plugs are notorious for self destructing in our cars. If you are running one steps please use the NGK models for now. Dustin has handfuls of the Denso's people have sent him with cracked or missing internal ceramics that fall down to the ground straps or come off completely.
jmhinkle is offline
The Following 4 Users Say Thank You to jmhinkle For This Useful Post:
m.a.vega1 (11-11-2013), MSMS3 (08-26-2013), rfinkle2 (03-19-2013), silvapain (03-19-2013)
 Old 03-19-2013, 07:05 AM   #99
Mfinlay04's Avatar
Hmm I've been running then for 2+ years zero issues. I ran NGK once took them out after 1k miles as I did not like the way they ran. Changing the gap from .05 down to .028 really messes up the electrode imo
Tuned with
 Old 03-19-2013, 08:20 AM   #100
Axle Breaker
jmhinkle's Avatar
Groans: 162
Take your chances as you wish, It's a known and documented problem the Denso is kind of looking into. Gapping the NGK's is far better than busting that ceramic off inside your cylinder. Luckily two of mine only fell down on the ground strap.
jmhinkle is offline
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
 Old 04-10-2013, 04:20 PM   #101
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
I like the stock plugs the best, I am using the NGK stock plugs right now stock heat range and these runs are using the stock NGK with NOOOO meth at 24 psi .. and i had no knocking at all.
I have problems with Denso plugs fouling or falling apart and i really have 0 issues whenever i run stock plugs
I left the gaps at .30 as they came as well, but im running kenne belle boost a spark
http://www.mazdaspeedforum.org/forum/foru...6/#post1997252
and +1
I had a Denso Cermaic Crack on me, luckily it did not fall apart but when pulled from motor is was fawked
Nitr0EngiE is offline
 Old 04-26-2013, 02:15 PM   #102
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
I'm struggling to see a need to go a step colder if I don't see any knocks.
I will be at stage II 93 octane on a COBB AP OTS map within the month (running a stage 1 now), so maybe re investigate the knocks situation? Or should I just go ahead and throw a step colder in before I see any signs that I actually need them?
I just have doubts that it is actually needed with just a tip, intake, and test pipe. Opinions?
Silver 2007 Speed3 GT
HawkeyeGeoff is offline
 Old 04-26-2013, 02:22 PM   #103
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I ran stock plugs with full bolt-ons, minus an intercooler. I put in ngk step colder plugs a couple weeks ago because it was time for a change anyway, and I have lots of flow mods and a tune in the process.
I didn't notice a difference, my stock plugs were beast.
Blue Pu.
anavrinIV is offline
HawkeyeGeoff (04-26-2013)
 Old 04-26-2013, 02:29 PM   #104
Yeh that's kind of what I'm thinking. I think i'll just watch it and make sure I get no knocks or misfires and we are in golden territory.
Thanks for the advice!
 Old 08-25-2013, 12:29 PM   #105
Temashi's Avatar
Posts: 11   (View Stats)
Temashi will become famous soon enoughTemashi will become famous soon enough
Good stuff ! Still not sure if I should upgrade my plugs with all the issues ppl are having.
Temashi is offline
 Old 08-26-2013, 10:38 AM   #106
Posts: 2,830   (View Stats)
Originally Posted by Mfinlay04 View Post
Hmm I've been running then [Denso] for 2+ years zero issues. I ran NGK once took them out after 1k miles as I did not like the way they ran. Changing the gap from .05 down to .028 really messes up the electrode imo
You gapped the NGK's incorrectly, if you did not like the way they ran.
If you do it properly there is no issue in gapping them from .045" to .028" or even .026". You may have scraped the iridium or bent the ground strap out of proper alignment.
Done properly, the strap will still be very close to perpendicular to the center electrode, regardless of what seems like a pretty extreme reduction.
Our cars are hard on plugs, expecially if you run higher than stock boost and romp the car pretty regularly. I've decided to routinely change them out every 20,000 miles. I'm at 88,000 miles. OEM's were NGK's, I'm on my 4th set of 6510 NGK's, one step colder.
No problem regapping any of them to .028."
MSMS3 is offline
hnda etr (08-26-2013)
 Old 09-27-2013, 11:04 PM   #107
Livingframe's Avatar
Posts: 41   (View Stats)
Livingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the worldLivingframe is the leader of the world
Hello MSF.
Cliff notes: Index your spark plugs and mod the ground electrode. good
for 8-12whp from 3800-6200whp on the stock tune.
I discovered something that I feel like could benefit everyone here. First off, this is a
gain derived from a modified/indexed spark plug setting:
MYFIRST_2013dyno_1 | Flickr - Photo Sharing!
on another dyno, I backtracked as what was done was not verifiable on the
butt-dyno. this chart will show three runs: all at .026"
Blue - Factory plug, factory plug gap indexing
Red - Factory plug, all plug gaps facing 6:00 *
Green - My modified plug, indexed to 6:00
* Reasoning behind a 6:00 gap position - facing intake valves/fuel sprayers/explosion force acts on piston in the rotational direction of the engine. i.e. making benefit in
similar manner that proper ignition timing helps it turn faster.
plug testing | Flickr - Photo Sharing!
^ this dyno is registered in SAE whp. the top number at '239' is '245' on STD and
correlates to the '262' number on the top dyno. Only difference is that the MPT
dyno I iced my stock intercooler for 45 min before the runs. at LaMotta's I did
not use ice at all, drove in from the street cooled for 30 min with a fan and
as soon as I could change plugs, 18-20min and reindex, we made another hit.
I do have video of the runs but have to put it together. The modified plug
helped me as I drove the car better from a 14.5 down to a 14.1. I have all
the papers. At some point, I was able to better dial in my 60' and get into
13s in full Orlando heat at full weight. I do have a few other things helping this
car, however its been fun to 'find' a little extra help with some hidden ponies.
I don't know how to post the images in the page so you'll have to go off-site
to my flickr acct to see the dyno images. I'll leave you with a pic of the plug
mod I do.
PLUG | Flickr - Photo Sharing!
The indexing is achieved with 14mm tapered seat washers. They come in a
set. The gain is global, all the time; part throttle... transition to WOT. Its
very smooth. Take it for what it's worth... for me it's been worth a lot.
Car has had closer to equal forces acting on the pistons for some time with
the indexed plugs. I have had them set up this way for a couple months now.
Right around 2000 miles I indexed my stock plugs and then about a thousand
miles later I ordered a couple sets of the LTR6IX-11 NGK plug. Recently I
drove up to the Mazda Meet/Eat in Jax from Orlando on a 1/4 tank. 136mi.
Partial throttle MPG increases. I also had a splash of Torco octane additive.
I get about 24mpg in town. I can get close to 30+ on the highway if I'm driving
sanely.
Let me know how I can better explain the gains I am experiencing in my car.
Its something that's 'there' for the taking. I can also put some kits together
if enough people express interest. LMK. Thank you, Michael
SDG:Racing/Intertune Tv - Videographer/Driver
2013 MS3: 1.954 12.943@108.94 full weight, factory tire on 93 octane. modded intake and updated mid pipe only changes since 12.988.
Best 60' - 1.91 on factory 2050 tire, Best MPH - 110.35 @ ENM '14
AT LEAST +10WHP OVER STOCK SETTING FROM SPARK PLUG MOD EXPLAINED: https://vimeo.com/85412223 reserve your set!
Livingframe is offline
The Following User Says Thank You to Livingframe For This Useful Post:
BAT-man (12-07-2013)
 Old 11-08-2013, 09:57 PM   #108
Broad Street Bully's Avatar
Broad Street Bully is a glorious beacon of lightBroad Street Bully is a glorious beacon of lightBroad Street Bully is a glorious beacon of lightBroad Street Bully is a glorious beacon of lightBroad Street Bully is a glorious beacon of light
So I'm confused a little. On a different thread on here, edgeautosport claimed that the denso plugs were on constant backorder, yet here people are stating that the ngk plugs are the way to go. Is one set better than the other or do we agree that it's just a matter of preference?? I have a cs sri, tip, dp, cbe, and ap running stage 2 ots map. I just ordered the denso itv22. Also, there seems to still be some agreeing to disagree on putting anti seize on the plugs. I have read so many threads on here regarding spark plugs but I feel like it just makes it more confusing with all the opinions.
Oh and hpfp also. Sorry
Red Sea Pedestrian
Last edited by Broad Street Bully; 11-08-2013 at 09:57 PM. Reason: MSF Database - Automerged Doublepost
Broad Street Bully is offline
 Old 12-07-2013, 12:32 AM   #109
FreshAsWoodie's Avatar
Posts: 50   (View Stats)
FreshAsWoodie is a jewel in the roughFreshAsWoodie is a jewel in the roughFreshAsWoodie is a jewel in the rough
Really don't understand this even after reading. I am guessing I will be needing to go a step colder or 2. Also what would I should gap it at. My mods are in my sig. All help will be appreciated.
08.5 Crystal White Pearl MS3
Rotors StopTech Drilled and Slotted / Pads EBC Reds / ISC coilovers
Cobb AP / Cobb SRI / Cobb TIH / Cobb FMIC / Corksport Downpipe / HPFP Internals / Forge BPV V3
FreshAsWoodie is offline
 Old 12-07-2013, 05:39 AM   #110
JpMuRkS's Avatar
Posts: 335   (View Stats)
JpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond reputeJpMuRkS has a reputation beyond repute
I wanna run NGK copper should I be jumping down 2 heat ranges? And on the first post it doesn't say which heat range of the NGK coppers 5306 and 4306 and what our stock heat range 7??
Sent from my SAMSUNG-SGH-I727 using Tapatalk
CPE 3.25 turbo inlet - Garret GT2871r - 3bar map sensor and harness - ATP catless downpipe - CPE 3" single exit exhaust - CX Racing FMIC piping - Treadstone TR11 FMIC core - Tial BPV recirculated - CPE injector seals - Autotech internals - NGK spark plugs one step colder .027 gap - custom oil catch can - JBR rear motor mount - JBR Transmission mount - Sure rear diff front and back mounts - EVO X wheels wrapped with GY egale F1 - Acessport v3 she's a FREEK Tune 93&E85 - EBC front slotted rotors with Red stuff pad - OEM rear rotors with red stuff pads - Bilstein rear shocks - KYB front adjustable struts - Cx9 spin on filter - Heavy shift knob - Sure short throw - fog light mod -
2006 Mazdaspeed 6 GT
2003 Mercury Marauder SOLD
2008 Harley Davidson Nightster 1200cc (exhaust, intake, dyno tune)
2001 Buick Regal GS winter beater for sale pm me
JpMuRkS is offline
 Old 12-07-2013, 02:28 PM   #111
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Can't see your sig in Tapatalk, but you don't need to go 2 steps colder unless you are REALLY pushing more boost - like in the 30's I'm guessing, running nitrous or some other setup that makes crazy power. For minimal mods, you don't even need to go 1 step colder. If you're moderately modded and running higher than stock boost pressure, 1 step colder is fine. Gap should be set to 0.026-0.028" - tighter (0.026") for higher boost and custom tunes, looser (0.028") for OTS maps. If you have blowout 0.028", reduce to 0.026". 0.025" is about the tightest I've heard people run.
Point is, you want to run the hottest plug you can, while controlling heat and detonation.
See above post about 2 steps colder.
Also, people run Iridium plugs because of the longevity they offer, and even then, in a lightly modded car the plugs only last around 15k miles or so. Going to copper plugs will require changing them even more often because of the softer material. Rethink that one..
Last edited by hnda etr; 12-07-2013 at 02:28 PM. Reason: MSF Database - Automerged Doublepost
hnda etr is offline
The Following 3 Users Say Thank You to hnda etr For This Useful Post:
Agent_Orange (12-07-2013), FreshAsWoodie (12-07-2013), ms6mil (12-07-2013)
 Old 12-07-2013, 07:18 PM   #112
I talked to my friend at work and he pretty much said the same thing. 1 step colder he said wouldn't really be needed. I have the Cobb TIH, Cobb SRI, Cobb FMIC. A downpipe and hpfp internals. He said I would be good with Denso stock heat range. I'll probably be looking at buying some tomorrow or sometime soon. Thanks again for the info.
 Old 03-11-2014, 09:03 AM   #113
El Beaner's Avatar
Posts: 4,262   (View Stats)
Just wondering who else has run the Autolites? Amazon has a killer deal right now on them - $5.99/each prime shipping and Autolite has a rebate of $2.50 per plug
From reading in the thread only 1 person posted about running them so not sure about going that route.
SOLD 2012 LSM Tech - 11/17/17
El Beaner is offline
 Old 03-11-2014, 09:22 AM   #114
darthxar's Avatar
Posts: 560   (View Stats)
I just noticed a local store near me had these for 5.99 each as well. I was thinking that at that price I could change them every 10K miles and not worry too much about their longevity. But I have not seen much feed back from anyone on these plugs
darthxar is offline
 Old 03-11-2014, 09:34 AM   #115
El Beaner's Avatar
Found this thread that has people saying they are not bad just gapped at .50
Are autolite iriduim plugs thaaaat bad?
 Old 03-11-2014, 12:30 PM   #116
darthxar's Avatar
Looks like the autolites are probably fine, as long as you don't expect to long of a life from them. Could order a couple sets while there is the rebate and just change them at 10k to 15k before any problems develop.
darthxar is offline
 Old 03-11-2014, 01:47 PM   #117
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
you can get the one-step colder NGK's for very cheap from AdvanceAuto if you use their discount codes which you can get online. I got myself 3 sets for less than two sets would cost anywhere else online.
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline
 Old 03-11-2014, 04:40 PM   #118
Axle Breaker
jmhinkle's Avatar
Groans: 162
My roommate has been running the autolites for over a year. He has a GTX3071 and meth injection. He beats on the car pretty hard. Never has blow out and hasn't replaced them yet. They seem to work well for him.
jmhinkle is offline
 Old 03-15-2014, 02:23 PM   #119
I think there are enough satisfied users with the Autolite iridium plugs to say they are gtg. But the surface of their center electrode is iridium enhanced, whereas the NGKs are a pure iridium coating. The NGKs will last longer and are priced similarly, sometimes cheaper. The stock plugs are NGK sourced. The one step colder 6510s are what I run with my mods and I'll continue to use them.
Whatever you run, gap them .026" to .028".
MSMS3 is offline
 Old 03-15-2014, 02:31 PM   #120
Axle Breaker
jmhinkle's Avatar
Groans: 162
On what planet? The cheapest deal I've ever gotten on NGK's was right at $8 per plug with shipping. Local prices with tax put them over that range. NGK's definitely have never been at $5 a plug or $2.50 after a rebate. I've never run the Autolites, but my roommates last longer than my NGK's do as well. Not to mention he runs stock temp plugs on 30 psi x76 car. I had to buy a set at this price because bang for buck they will dominate the NGK even if I replace them twice a year.
jmhinkle is offline
The Following User Says Thank You to jmhinkle For This Useful Post:
MSMS3 (03-22-2014)
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/spark-plug-database-colder-than-stock-stage-5692/
Need help with my 07 Speed3 : mazda This thread Refback 04-09-2015 11:26 PM
2007 Mazda Speed 3 Starting Troubles - Page 3 This thread Refback 04-01-2013 05:41 PM
Maintenance question.. This thread Refback 07-16-2011 12:44 AM
[MAZDASPEED AーSPARK] OCN ウェブ検索結果 This thread Refback 04-21-2011 07:40 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 74 08-02-2019 08:18 AM
4 or 6 puck stage 3 clutch ? occschemguy MazdaSpeed 6 - Engine, Transmission & Driveline 17 02-16-2009 06:18 PM
Spark plug gap Jesse MS3GT MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-16-2008 04:53 PM
�Copyright 2008 ; 2019 Cymru Internet Services LLC | FYHN� Autosports HQ
Page generated in 0.63325 seconds with 45 queries
