Like Tree24Likes
Closed Thread
 Old 01-13-2015, 08:36 PM   #201
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Gap them to specs per the op and you'll be fine.
Using bad grammar from my cell phone.
ASHMS3 is offline
 Old 06-08-2015, 05:51 PM   #202
pastry00's Avatar
Posts: 154   (View Stats)
pastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud of
Groaned at 5 Times in 1 Post
Default Spark Plugs
I am currently installing a downpipe on my car. I have the Denso Itv22 iridiums I believe they are one step colder and I have them properly gapped for stage 1+. Will I need a different gapped plug for running stage 2?
pastry00 is offline
The Following User Says Thank You to pastry00 For This Useful Post:
edwinrivera5 (02-22-2016)
 Old 06-08-2015, 06:11 PM   #203
tbcota25's Avatar
Posts: 1,542   (View Stats)
tbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the world
Gap them between 0.026-0.028 and you will be fine
Sent from my iPhone 6 using Tapatalk
PapaBruno likes this.
2012 Black Mica
Mods
CS catless DP, CS RP
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
CS Short Shit Kit and Shifter Bushings
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
JBR Reticulation Tube
Cobb AP v2
H&R springs
JBR Rear Sway Bar
Self Built 3 Port EBCS
maisonvi Shift Knob
Tuned on 93 and corn
tbcota25 is offline
 Old 06-08-2015, 06:45 PM   #204
Fixed. 1/4" gap is a tad big.
tbcota25 and PapaBruno like this.
Raider is offline
 Old 09-20-2015, 02:11 PM   #205
jkms3's Avatar
Posts: 15   (View Stats)
jkms3 is a jewel in the roughjkms3 is a jewel in the roughjkms3 is a jewel in the rough
AutoZone sold me a set of Bosch Iridium 9617 plugs. The electrode it's bigger than the stock FoMoCo ILTR6A 8G plug's. Can I use the Bosch or it's that dumb?
jkms3 is offline
 Old 09-22-2015, 06:52 PM   #206
azarashi's Avatar
Posts: 709   (View Stats)
azarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the world
I had this happen with me when i got Autolites, they were just every so slightly bigger. I had to pick up a different spark plug socket cause even though it was the same size socket, the one I had wouldnt fit.
2008 Mazdaspeed 3 GT - Cobb SRI, HKS BOV, Cobb AP V2, Sure RMM, EBC Front Rotors, Hawk HPS, ROCA PMM, Yokohama YK580, SenSen Rear shocks
Planned: Cobb TIP, Autotech HPFP, MattD RMM, Koni Street Shocks/struts
azarashi is offline
The Following User Says Thank You to azarashi For This Useful Post:
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/spark-plug-database-colder-than-stock-stage-5692/
Need help with my 07 Speed3 : mazda This thread Refback 04-09-2015 11:26 PM
2007 Mazda Speed 3 Starting Troubles - Page 3 This thread Refback 04-01-2013 05:41 PM
Maintenance question.. This thread Refback 07-16-2011 12:44 AM
[MAZDASPEED AーSPARK] OCN ウェブ検索結果 This thread Refback 04-21-2011 07:40 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 74 08-02-2019 08:18 AM
4 or 6 puck stage 3 clutch ? occschemguy MazdaSpeed 6 - Engine, Transmission & Driveline 17 02-16-2009 06:18 PM
Spark plug gap Jesse MS3GT MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-16-2008 04:53 PM
�Copyright 2008 ; 2019 Cymru Internet Services LLC | FYHN� Autosports HQ
Page generated in 0.27961 seconds with 26 queries
