 Old 06-28-2009, 03:12 PM   #1
Default Spike of KR only happens sometimes at WOT
Just got back from a 2200 mile road trip through all kinds of temperatures, elevations and conditions. Had a chance to really monitor how the car behaves.
I get very large spikes of KR (6-8) only under certain conditions. Here they are:
1. Car has coolant warmed up already but has only been driven for 10 minutes or less. Getting into some boost here results in KR
2. Car is heat soaked. I have meth injection and an ETS but having the car sit in the california sun and getting on it results in spikes of KR until it cools off. This is not something unexpected and is easy to avoid.
3. What is unexpected is that at times, I would be around 3000 RPM in 5th or 6th and I would stab the throttle (WOT) to quickly pass. Boost would spike to 21-22psi (settles to 15-16psi) and I would get a KR spike of 7 or so. I would back off immediately and do it again. Nothing, no KR spike, nothing larger than 0.4. I would do this repeatedly while on the hwy but could not reproduce it. In other words, happens randomly.
I'm looking for some insight or similar experiences.
Car behaved flawlessly otherwise.
 Old 06-28-2009, 03:32 PM   #2
phailerider's Avatar
Posts: 4,639   (View Stats)
i think its clear you need to seriously consider building the engine.
 Old 06-28-2009, 03:38 PM   #3
Isn't that jumping the gun a little?
 Old 06-28-2009, 03:45 PM   #4
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
Early in the day I took a quick drive for lunch (Pretty much just jumped in the car and went) and my KR warning lit up like 3 times for 3.2, 5.2 and 4.0 KR@partial throttle 4th gear just below 3k (have it set at 1,2&3) Before this the highest I've ever seen was .7 KR. I few minutes ago I took a drive and the highest my KR went to was .4 and it was mostly in vacuum cruising in gear. I think there's a correlation between the car being completely warmed up and KR. Only thing on my car is whats listed in the sig, no power mods yet.
ms3077 is offline   Reply With Quote
 Old 06-28-2009, 03:51 PM   #5
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
wtf randy?
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
The Following User Says Thank You to DaleNixon For This Useful Post:
phillyb (06-28-2009)
 Old 06-28-2009, 04:12 PM   #6
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
Was this sarcasm?
GQ_WhiteMS3 is offline   Reply With Quote
 Old 06-28-2009, 08:05 PM   #7
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Hectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the world
Groaned at 9 Times in 6 Posts
Originally Posted by GQ_WhiteMS3 View Post
Was this sarcasm?
LOL I hope so.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
 Old 06-28-2009, 08:46 PM   #8
Gr33ntumb's Avatar
Posts: 348   (View Stats)
Gr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond repute
i get same thing
but along with the KR of 5.9, my car makes popcorn popping sounds and stutters
what are your ltft and stft ? i get -15 to -20 at idle .. ( WOT is ~0 )
im guessing im too rich and fukin thing pre-ignites when engine is hot . or leftover fuel ignites ... not sure really what knock is but i sure know what it feels like now
im still under warranty tho and got a CEL just got to let mazda check it out , hope they can figure it out
i also read somewhere that it could be bad compression in one cylinder....
anyway i hope i get a new engine because i guess with having it knock like that i have reduced the lifetime of the engine.,., or if they get er fixed ill probly just sell it
bah this is all blabla, im fuking bored at work and havent drove the car in a few days and just cant wait to get back home and get it looked at. sucks to work on a boat... you wish half your life away .... kinda
CS 3inch intake, CS FP internals, CS Test pipe, Forge V2, AP v3, JBR 88a RMM and mud flops
Gr33ntumb is offline   Reply With Quote
 Old 06-28-2009, 09:34 PM   #9
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
jeeeeesus are you guys serious?! 5.9, 6.0, 8.0?! i thought mine was bad at 0.4-1.1 in vacuum...
 Old 06-28-2009, 09:37 PM   #10
ms3077's Avatar
Groans: 974
Yeah, freakin ticking time bombs mang! Lmfao @ Randy's comment!! Epic.
 Old 06-28-2009, 09:48 PM   #11
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i've had this happen to me, very rarely...like once or maybe twice. flooring it in fifth, spike high...low 20's or so, and 6.0 knock with an audible ping. never did it again.
this is not partial throttle kr of 6, this is under some load, right?
Lex (06-28-2009)
 Old 06-28-2009, 09:51 PM   #12
maybe a bit
The Following User Says Thank You to phailerider For This Useful Post:
ms3077 (06-28-2009)
 Old 06-28-2009, 10:39 PM   #13
That's exactly what I've experienced. Each time the spike was around 21-22psi right after going WOT. I usually never floor it in that gear but being on the hwy for hours on end I got a chance to play with it some in 5th and 6th. Any idea what it is philly? After this I'd try and reproduce it and I'd get no more than 0.4 KR.
EDIT: Philly are you on the stock pump?
 Old 06-29-2009, 12:44 AM   #14
phillyb's Avatar
Groans: 1,940
yeah, stock pump. i don't recall if pressure was low...idk. not enough fuel, lots of air, big kr number, that could make sense.
i really have no idea though
 Old 06-29-2009, 05:23 AM   #15
DaleNixon's Avatar
Groans: 91
Haha! Just yesterday I got 7.7 KR in cruise control at -5 vacuum. You're a lucky bastid if you're only seeing up to 1.1.
 Old 06-29-2009, 08:09 AM   #16
How did the "ping" sound like to you? To me it didn't sound like knock. I wonder if it's another noise triggering the knock sensor. The wastegate opening?
 Old 06-29-2009, 08:31 AM   #17
spheed3's Avatar
Posts: 487   (View Stats)
spheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond repute
I get the same thing. Usually after being on the highway for 30-40mins then getting off and punching it in fourth gear will always get me 5-7 degrees of KR. I believe this is part of the cars fuel economy strategy by advancing timing as much as possible while cruising. I've found that easing into boost after a cruising will usually result in no KR.
Black Mica 08.5 GT
I'm parting out. Buy my stuff: http://www.mazdaspeedforum.org/forum/foru...ing-out-59908/
spheed3 is offline   Reply With Quote
 Old 06-29-2009, 10:39 AM   #18
phillyb's Avatar
Groans: 1,940
mine was knock...you could physically feel the car hesitate for a slight moment
 Old 06-29-2009, 10:49 AM   #19
The stumble you felt is the timing being pulled. So it is the reaction of the car to the noise, not the actual noise or knock. When a car knocks you don't feel any hesitation - you actually don't feel anything.
 Old 06-29-2009, 11:21 AM   #20
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
so I wonder what the delay is...from when knock occurs to the point when timing is pulled. does the ecu pull it in anticipation of knock? or is it actually waiting for the noise, then pulls timing?
BONE STOCK.
94jedi is offline   Reply With Quote
 Old 06-29-2009, 11:23 AM   #21
It pulls timing once the noise is detected. However, you only feel the stumble once timing is pulled which is the same time your DH will report it.
 Old 06-29-2009, 11:46 AM   #22
phillyb's Avatar
Groans: 1,940
ohhh...yeah, retarded timing = pinging...idk the order. that's all i'm witnessing
 Old 06-29-2009, 12:58 PM   #23
KayWhy's Avatar
Posts: 752   (View Stats)
KayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the world
Groaned at 9 Times in 5 Posts
ALL stock cars have KR its a way of life - some have more than others. The best way to combat knock is open up exhaust, colder plugs, colder tstat meth and tune
KayWhy is offline   Reply With Quote
 Old 07-08-2009, 08:41 AM   #24
Bringing this back up because I found something interesting.
These KR spikes have occurred since I installed the CPE rear mount. Turns out that the bolt that goes through the mount and attaches to the engine/tranny binds. As you load the engine, at some point it clicks/moves slightly since there no longer is much play at the rear of the mount. This causes a large spike of KR. This is the reason it happens only sometimes.
Let it sit for a while, it binds again, and releases again causing the KR. The design with the through bolt and nut at the end are more prone to this compared to the stock mount that has the nut WELDED to it.
I greased up the mounting faces of the mount where the long bolt/nut could bind and so far I have yet to reproduce the large KR spike on the hwy or in the morning.
Will keep you posted but this explains a few things:
1. Random KR spikes when getting on the throttle that are not repeatable.
2. KR spikes when getting OFF the throttle and unloading the assembly.
3. KR spike during the first little while of driving in the morning.
This is something that everyone with a non stock mount (or mounts) should look into.
 Old 07-08-2009, 09:15 AM   #25
spheed3's Avatar
Very interesting. I'll try greasing mine up as I get the same thing with the same mount.
Black Mica 08.5 GT
 Old 07-08-2009, 09:30 AM   #26
Remember not to get grease on the bushing on the CPE mount as it doesn't like petroleum products.
 Old 07-08-2009, 09:37 AM   #27
spheed3's Avatar
I was gonna try my trusty 3M silicone paste as it's my go to lube for just about everything...yes everything.
Black Mica 08.5 GT
Boost spike at 5250rpm? Blackspeed MazdaSpeed 3/6 - Turbo Induction 1 05-26-2009 07:36 PM
Abnormal boost spike? curtspeed6 MazdaSpeed 3/6 - Turbo Induction 4 04-13-2009 11:04 AM
Strage KR Spike badams118 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 01-31-2009 05:38 PM
Controlling boost spike? booya620 MazdaSpeed 3/6 - Turbo Induction 0 10-19-2008 06:32 PM
Page generated in 0.44855 seconds with 31 queries
