Like Tree7Likes
 Old 12-28-2009, 07:36 PM   #1
Qwik6's Avatar
Posts: 695   (View Stats)
Qwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the world
And from behind they did. 3 quarts came out to be 56 bucks!!! Changed the fluid. Keep in mind I was running amsoil before this. I didn't notice any improvement. If anything its harder to shift now. Waste of 60 bucks.
2006 MAZDASPEED6
FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL
Qwik6 is offline   Reply With Quote
 Old 12-28-2009, 10:21 PM   #2
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
phew. i was thinking about doing this.
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 12-30-2009, 12:45 PM   #3
shpankey's Avatar
Posts: 496   (View Stats)
Yikes dude. Amsoil is good shit, I don't think I would have done it with that in there. From stock fluid this stuff is amazing, but probably not a lot of difference from Amsoil.
Though I will say this... the Ford stuff supposedly doesn't really work its magic right away, especially when it's cold. It really comes alive in the heat and also just gets better and better over time. Some say you won't see the difference until AT LEAST 500 miles and then after a few thousand and continues to improve all the way to 5,000 miles after install. So give it time, I have no doubt you will see an improvement as you get more miles and especially when it heats up (summer). So don't feel like all is lost yet.
I seen the difference instantly, but I've had issues with my tranny and I changed out stock fluid.
shpankey is offline   Reply With Quote
 Old 12-30-2009, 09:51 PM   #4
Qwik6's Avatar
Thanks. I'll give it some time to break in.
2006 MAZDASPEED6
 Old 12-31-2009, 02:48 PM   #5
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
it will probably take more than 3 qts but that will be over the max fill ... i believe if u just stick your finger in there and u feel the fluid u should be ok ... if u have a service manual u will see what i mean. I put in 3qts but spilled a little so its close enough to 2.6 lol
easy is offline   Reply With Quote
 Old 12-31-2009, 02:51 PM   #6
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
Overfilling is a recipe for blown seals, leaks and internal damage. Remember, there's an expected air volume inside the case and there's a bunch of whirling gears pumping fluid and air around. If you overfill with an essentially incompressible fluid, something's gotta give.
 Old 01-24-2010, 02:28 PM   #7
wildfrisco's Avatar
Posts: 22   (View Stats)
wildfrisco is on a distinguished road
On another forum someone said the 6-speed is actually a Getrag 6MTT450:
GETRAG Corporate Group - 6MTT450 TRANSMISSION
wildfrisco is offline   Reply With Quote
 Old 01-24-2010, 02:37 PM   #8
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I have heard both stories, but I trust wassup61 so I am going with his.
Suspension:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/transmission-cured-45288/
Dual mass to single mass - Page 3 - Dodge Caliber SRT-4 Forums This thread Refback 04-21-2014 09:18 AM
Aisin BG6 kaufen - WEB.DE - Web-Suche This thread Refback 11-21-2013 03:42 AM
Darn gearbox oil problem ? Mazda MPS Owners Club This thread Refback 08-09-2013 03:28 AM
Gear-changes when cold ? Mazda MPS Owners Club This thread Refback 03-26-2013 12:45 AM
Huile transmission manuelle Mazdaspeed 2010+, où trouver ? - Mazda 3 Quebec This thread Refback 01-16-2013 01:12 PM
Gear-changes when cold • Mazda MPS Owners Club This thread Refback 10-09-2012 12:31 PM
Mazda MPS Owners Club • View topic - Gear-changes when cold This thread Refback 09-13-2012 07:58 AM
Transmission - Mazda 3 Quebec This thread Refback 09-12-2012 07:34 AM
Transmition - Mazda 3 Quebec This thread Refback 09-11-2012 08:37 PM
Altezza Club Of NZ/Australia -> Gear Oil This thread Refback 06-13-2012 12:47 AM
Noise when turning at low speeds! Help! This thread Refback 03-21-2012 09:03 AM
Clix This thread Refback 01-31-2012 02:53 PM
Mazda MPS Owners Club • View topic - Darn gearbox oil issue This thread Refback 01-16-2012 02:47 PM
Mazda MPS Owners Club • View topic - Gear-changes when cold This thread Refback 01-10-2012 05:49 PM
VWVortex.com - MS3 owners (pre-2010), need HELP - pics and info on failed/failing rear motor mounts This thread Refback 11-04-2010 12:38 PM
Tranny fluid - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-17-2010 03:05 AM
trany fluid This thread Refback 03-02-2010 05:20 PM
Statistics for k-mansparts.storesecured.com (2010-01) - main This thread Refback 01-11-2010 06:02 PM
Tranny fluid - Mazda6 / Atenza This thread Refback 12-26-2009 01:07 PM
Transmission Oil Change - How Often? cheez 2010 MS3 - Engine, Transmission & Driveline 18 10-14-2009 01:12 AM
transmission AK-speeder MazdaSpeed 3 - Engine, Transmission & Driveline 6 08-24-2009 09:44 PM
Page generated in 0.45007 seconds with 28 queries
