| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Mar 2008 Location: Minneapolis, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 804
(Thread Starter) | Not Ranked : 0 score ***NEW*** TSB thanks to Dadasracecar (added 4/8/08) Click link below for Cam Driven Fuel Pump TSB NHTSA Recall Campaign Number: 07V295000 Component: ENGINE AND ENGINE COOLING Details: ON CERTAIN PASSENGER VEHICLES, THE NO. 4 LEFT SIDE ENGINE MOUNT BOLT MAY LOOSEN IF A SUDDEN RAPID ACCELERATION IS REPEATEDLY PERFORMED. Consequence: IF THE VEHICLE IS CONTINUOUSLY DRIVEN UNDER SUCH CONDITION, THE NO. 4 ENGINE MOUNT BOLT MAY LOOSEN AND PULL OUT OR BREAK, ALLOWING THE TRANSMISSION TO BE OUT OF POSITION. IN EXTREME CASES, THE DRIVE SHAFT MAY BECOME DETACHED. IF THIS OCCURS THE VEHICLE WILL LOSE POWER AND WILL COME TO A STOP, INCREASING THE RISK OF A CRASH. Corrective Action: DEALERS WILL INSPECT AND REPLACE THE NO. 4 ENGINE MOUNT BOLT WITH A MODIFIED ONE, AND, IF NECESSARY, REPLACE THE NO. 4 ENGINE MOUNT RUBBER AND BRACKET WITH NEW ONES FREE OF CHARGE. THE RECALLBEGAN ON JULY 13, 2007. OWNERS MAY CONTACT MAZDA AT 800-222-5500 . Units Potentially Affected: 5700 Recall Initiated By: ODI Date added to NHTSA datbase: 07/10/2007 NHTSA Recall Campaign Number: 07V052000 Component: EQUIPMENT Details: ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH OPTIONAL ACCESSORY ALL WEATHER FLOOR MATS, THERE IS INSUFFICIENT CLEARANCE BETWEEN THE FLOOR MAT AND ACCELERATOR PEDAL. Consequence: IN THIS SITUATION IT IS POSSIBLE THAT THE ACCELERATOR PEDAL MIGHT GET STUCK BEHIND THE FLOOR MAT, WHICH MAY PREVENT THE VEHICLE FROM PROPERLY DECELERATING WHEN THE ACCELERATOR IS RELEASED INCREASING THE RISK OF A CRASH. Corrective Action: OWNERS WILL BE INSTRUCTED TO RETURN THE FLOOR MATS TO DEALERS AND WILL BE SHIPPED A NEW FLOOR MAT FREE OF CHARGE. THE RECALL BEGAN ON MARCH 7, 2007. OWNERS MAY CONTACT MAZDA AT 1-800-222-5500. Units Potentially Affected: 1700 Recall Initiated By: MFR Date added to NHTSA datbase: 02/15/2007 SERVICE BULLETIN:09012007 NHTSA ITEM NUMBER:10023192 MFG Bulletin Date: 20070901 Component: ELECTRICAL SYSTEM:WIRING:INTERIOR/UNDER DASH Bulletin Summary: MIL ILLUMINATION (DTC P2006) VOLUNTARY EMISSION RECALL CAMPAIGN 4807H AND OBD-II COMPLIANCE VOLUNTARY EMISSION RECALL CAMPAIGN 4907H. *NJ Date added to datbase: 20071101 SERVICE BULLETIN:0101007 NHTSA ITEM NUMBER:10021521 MFG Bulletin Date: 20070301 Component: ENGINE AND ENGINE COOLING:ENGINE Bulletin Summary: MIL COMES ON WITH DTC P2006 (VARIABLE SWIRL CONTROL SYSTEM SHUTTER VALVE STUCK CLOSED). *KB Date added to datbase: 20070514 SERVICE BULLETIN:0102206 NHTSA ITEM NUMBER:10023313 MFG Bulletin Date: 20070907 Component: SUSPENSION:FRONT Bulletin Summary: FRONT CRANKSHAFT BOLT SERVICE WARNING. *NJ Date added to datbase: 20071114 MTOL - 5636 Dealer Repair Information Symptom and Conditions Some customers may experience a chattering noise when passing over bumps and/or driving on a rough roads,that may be confused as a dash rattle at the base of the windshield. Condition may be the result of a stick slips noise that occurs between the cowl grill and the windshield. Repair Procedure When you encounter a customer with this concern replace the insulator pads on the 8 hooks of the cowl grill with improved part as listed. Part No. L206-50-794 Qty. 8 (4 per side)
__________________ There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior ![]() 35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential Last edited by Jesse MS3GT; 04-08-2008 at 04:15 PM. Reason: Update |
| The Following User Says Thank You to Jesse MS3GT For This Useful Post: | usmc_adams (04-23-2010) |
![]() Join Date: Mar 2008 Location: Windsor Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 197
| Not Ranked : 0 score Got a call this afternoon from my dealer about a recall. Something to do with Door latch/lock re-enforcement??? Going in tomorow afternoon to get it done. I'll post more info after the work has been done.
__________________ 2010 Victory Red HHR SS 2008 CPW MS3 (SOLD) 2004 Black SRT-4 (SOLD) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,016
| Not Ranked : 0 score hmmmmmmmmmmmm |
| Not Ranked : 0 score They said it should take about an hour to complete and the "parts" just came in today. So I'm not sure if they are going to replace somehting or what but they wanted me in their ASAP to get it done.
| Not Ranked : 0 score Yeah so I'm not sure what the dealership was smoking. I get there and ask exactly what the recall is.......its for the locks. Its the whole If someone kicks your doors the right way they will unlock thing. I was like ok get it fixed than. They take my car into the bay and come out 5 mins later and say yeah your vehicle does not need the recall. Not a happy camper right now about them wasting my time along with having to leave work early to bring my car in.
__________________ 2010 Victory Red HHR SS 2008 CPW MS3 (SOLD) 2004 Black SRT-4 (SOLD) Last edited by HiggyMS3; 03-26-2008 at 02:25 PM. |
![]() Join Date: Mar 2008 Location: Oklahoma
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
| Not Ranked : 0 score I thought they fixed that with the older models..... sucks you had to waste your time. Dealers are morons. |
![]() Join Date: Apr 2008 Location: Roseville/Sacramento
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score mitchells also works very well
__________________ 2008 Sunlight Silver GT - Cobb SRI, HKS BOV Recirc, SU Test Pipe, TWM Shifter Bushings, 35%/5% Tint, Parrot Bluetooth Unit, Decals | To Come - Boost Gauge, Springs+Sways, CBExhaust, Wheels |
![]() Join Date: Mar 2008 Location: Yakima, Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Missing the VVT and CDFP TSB here.
__________________ 2007 MAZDASPEED 3, MS CAI, MS CBE. |
![]() Join Date: Dec 2008 Location: Peachtree City
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score How serious is the motor mount loosening? Does this happen very often? |
![]() Join Date: Apr 2009
| Not Ranked : 0 score Im going in to a dealer cross state to look at an MS3. Would they know which recalls have been fixed in the car? It's an Acura dealer, so they don't sell Mazdas often. |
![]() Join Date: Mar 2009 Location: Woodridge,IL
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score I'm glad the recall 07V2295000 is on here because my 07 Speed 3 for some odd reason never had this reall performed before I bought it, and low and behold last night the bolt snaps, of course it has to be Sat night when it breaks so now I have to tow the car in tomorrow morning but I'm going to raise hell for the fact it was a certified used car through mazda without having the recall performed. I am not a happy camper but thanks to you guys I can seriously talk to my dealer about some lingering questions I now have about their service work / certification there. |
Groans: 356
| Not Ranked : 0 score axle clicking tsb..............anyone????
![]() Join Date: Jun 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I just bought a 2008 MS3 and i was wondering after reading this thread if your in cali area if you could suggest a dealer to get the recalls checked and or fixed |
![]() Join Date: Apr 2009 Location: oakland, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 387
Groaned at 56 Times in 24 Posts
| Neutral : +1 score maybe you should get a Yaris.... i heard they are very dependable....
__________________ chief moped rider..... i just never let my friends see the moped. mopeds are great. they will do anything! |
| The Following User Says NO Thank You to The Frush For This Un-useful Post: |
some unsolicited advice: if you are going for easy big power, choose a dif platform. if you want the best/fastest daily driver, the ms3 is for you. even though my car will never be 400+hp, its still fast as fuck and i couldnt be happier.
__________________ chief moped rider..... i just never let my friends see the moped. mopeds are great. they will do anything! | |
| The Following 2 Users Say Thank You to yang_jackson For This Useful Post: | BoostIsBetter (07-11-2009), karl-hungus (07-11-2009) |
![]() | Not Ranked : 0 score
I'm not going for big easy power. i have driven 2 ms3 and liked them and there's no way in hell i would want a fwd car to have 400+ hp, it would lose all it's fun. i had a focus that had a bunch of cosworth stuff and had 228 wph on a mild tune and it was good enough for me but i was t boned and decided i would look into a turbo car that's fun to drive. the only reason i said "real turbo cars" was due to the reason that they have been around longer than the speed3. i'm not intentionally putting the speed3 down it's a good step forward in to the turbo game for the 5 door car. i was just in a bad mood, im currently looking at a silver speed3 bone stock except or some wheels. not sure what kind has no center cap's
__________________ Some say he urinates 98 RON petrol, and that he can smell corners. No one knows when he was born, or how. But we do know why he was placed upon the Earth. To drive quickly. He has a penchant for prog rock, and rumour has it, likes his eggs sunny side up....... All we know is he's called The STIG!! | |
![]() Join Date: Oct 2009 Location: Ft. Lauderdale, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score I just brought my car in for some warranty work. My driver's side seatbelt latch was squeaking when I went over bumps, apparently there's a TSB for this. When I drop the car off again to get the work done I'll get more info about the TSB. There's also a TSB for Bose radio's eating CD's. My dealer said not to use MP3 CD's in my MP3-capable Bose CD-Changer because "they get stuck." Sounds like BS to me. I told him whenever I'm playing a burned CD, I can't change discs, even though the lights illuminate, nothing happens. However, the CDs will change if using a store-bought CD. I'll keep everyone posted on what I find. |
![]() Join Date: Sep 2009 Location: Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 483
| Dismember ![]() Join Date: Mar 2008 Location: Panama City, FL
Rep Power: 1242 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 821
Groaned at 27 Times in 13 Posts
__________________ 2012 Nissan Titan 4x4 |
![]() Join Date: Aug 2008 Location: Fremont, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score Hey the Drive shaft TSB seems to be only for the regular mazda3 but I think that is occurring with my mazdaspeed3 did any one get this done on their MS3. I would like to know thanks |
![]() | | #24 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score Mine was clicking, they replaced the entire shaft about a month ago MS3.
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score mine is clicking too
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() | | #26 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score whats it sound like if its clicking? and how do you know? my car has like a clicking sound coming from the back of the car like everytime i go over bumps and shit. |
| The Following User Says NO Thank You to 07SP33D3 For This Un-useful Post: |
![]() | | #27 | ![]() |
Groans: 754
| Neutral : +1 score click, click, click ......... you hear it.
![]() You need a Proctologist not a Mechanic!
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. | |
![]() | | #28 | ![]() |
Groans: 278
thats how many started atleast
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" | |
![]() | | #29 | ![]() |
| Not Ranked : 0 score |
![]() | | #30 | ![]() |
that exactly right. If I go reverse and forward I can repeat all the time. I have check all my suspension, sway bar and endlinks and I can't find nothing odd. it has to be it. thanks for the help guys. I schedule it for service on friday will see how it goes. | ||
| The Following User Says Thank You to DISITRB For This Useful Post: | IshiKage (12-14-2009) |
![]() | | #31 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
| Not Ranked : 0 score I'm starting to get it... Only once as I move either forward or backward.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
![]() | | #32 | ![]() |
| Not Ranked : 0 score One more thing. What do say to the dealer as far the service bulletin? They are telling me that there isn't a service bulletin like that for the MS3 I knew they were going to give shit I have not even show up there and its already problem. Is this something you pay for? |
![]() | | #33 | ![]() |
Groans: 754
Just told them there was clicking from drivers side front during load changes, that I could only hear it with the window down, and that it sounded like a bad CV joint. They checked it out, ordered a new axle. Replaced under warranty.
![]() | | #34 | ![]() |
Thanks for the help. | |
![]() | | #35 | ![]() |
Groans: 754
As far as the dealer is concerned........ In other words everything else is removed for visits, and I would remove the SRI too if I was going in for any warranty work engine related. You have........ TT front mount, catch can, forge bpv cobb sri, bc coils and rims LOL... good luck, depends on your dealer really, I would consult the Good dealer and Bad dealer lists on the forum to see if there is a "good" dealer in your area.
![]() | | #36 | ![]() |
![]() Join Date: Dec 2009 Location: Middle Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| The Following User Says Thank You to shpankey For This Useful Post: | FreeFlyFreak (12-22-2009) |
![]() | | #37 | ![]() |
Groans: 754
| Not Ranked : 0 score Glad you liked it.... LOL
![]() | | #38 | ![]() |
![]() Join Date: Apr 2010
Groaned at 16 Times in 8 Posts
| Not Ranked : 0 score The STIG is Michael Schumacher.
Last edited by Mikey95hd; 04-18-2010 at 07:39 PM. Reason: MSF Database - Automerged Doublepost | |||
![]() | | #39 | ![]() |
![]() Join Date: Apr 2010 Location: Flemington, N.J.
Rep Power: 0 ![]() ![]() ![]() Thanks: 42
| Not Ranked : 0 score so if i take my car to the mazda dealer and tell them these are the recalls can you fix them even if nothing wrong that i know of can they charge you for this? and or does ne of these recalls must be screwing with my car before they will fix it?
__________________ 98 Honda Accord V6 (R.I.P.) 03 VW Jetta GLI VR6 6SPD- APR Stage 2 (93 Octane Program), APR Carbon Fiber Carbonio CAI, Neuspeed Coilovers, Neuspeed F&R Rotors, BBS 18', APR Performance Exhaust (R.I.P.) 08 Mazdaspeed3 Mica Black-PG Torque damper, CP-e Xcel Nano SRI w/ pre-filter, Forged BPV V2, 4000 watt lanzar, 2 12' kickers at 2000 each |
![]() | | #40 | ![]() |
![]() Join Date: Jun 2015
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Cheers & glad to be a member on a site devoted to Mazda's. I just bought a nice 2011 MazdaSpeed 3 and it will be delivered the end of June (2014). Looking forward to my little go-cart on steroids. Have owned Porsche 944 Turbos and loved them but they were 1986 models and a lot has changed since then. Will post pic's and more info. when my car arrives! |
| The Following 3 Users Say NO Thank You to swearingen797 For This Un-useful Post: |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/tsb-s-recalls-mazdaspeed-3-a-151/ | ||||
| Mazdaspeed 3 - opinions - beyond.ca car forums community for automotive enthusiasts | This thread | Refback | 06-02-2015 04:05 PM | |
| Mazdaspeed 3 - opinions - Beyond.ca - Car Forums | This thread | Refback | 03-25-2014 04:24 PM | |
| 2009 civic si or 2009 mazdaspeed 3 (this thread is old) - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 08-26-2009 01:43 PM | |
| 8th Generation Honda Civic Forum - 2009 civic si or 2009 mazdaspeed 3 | This thread | Refback | 12-03-2008 11:16 AM | |
| 2009 civic si or 2009 mazdaspeed 3 - Page 2 - 8th Generation Honda Civic Forum | This thread | Pingback | 11-16-2008 03:32 PM | |
| Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 03-25-2008 09:57 PM | |
