 Old 03-28-2009, 02:03 PM   #1
mordxp's Avatar
Posts: 12   (View Stats)
mordxp will become famous soon enough
Default Unusual Engine Sound
Hello fellas. I tried to look for the ansewr to my question in the previous posts but couldnt find anything that would sattisfy me So here is the deal: Form time to time I hear sound from the engine, its like knocking/ticking sound, but it happens only when I start the car and it goes away after 2-3 sec. Should I be worried??BTW Tomorrow I planed to put my mods on, and idk if should put it on hold and bring the car to dealership...Thanks!
mordxp is offline   Reply With Quote
 Old 03-28-2009, 02:05 PM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
sounds like the injectors. rev the car up a little and you should here the sound for a little bit after the revs too. The injectors are loud on this car
 Old 03-28-2009, 02:37 PM   #3
ZMB
ZMB's Avatar
Posts: 159   (View Stats)
ZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant futureZMB has a brilliant future
Groaned at 5 Times in 2 Posts
Here ya go! I have the same exact issue i just hope u have warrenty still...
http://www.o-m-g-w-t-f.com/stuff/Maz...02-08-1896.pdf
2006 White Water Pearl MazdaSpeed6: 35% all around tints, VG Shark Fin, Blacked-Out Sidemarkers, Auto Exe Carbon Fiber Badgeless Grill, Eibach Springs, Front Lip, Street Unit Motor Mount, SLS Test Pipe, Corksport Downpipe, Cp-e Rear Diff Mount, Cp-e FMIC, Custom Magnaflow Exhaust, Custom 3" Inlet Pipe, Silicon Tube Upgrades, Cobb Intake, SM OCC, Cobb Accessport, ACT Clutch Kit, PT-Performance K04 SST - KMD Tuning Fuel Pump Internals.
Lover of Krazy House Customs (.com)
ZMB is offline   Reply With Quote
 Old 03-28-2009, 05:34 PM   #4
Strizzo's Avatar
Posts: 148   (View Stats)
Strizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of light
shouldn't matter if he is out of warranty, a tsb is a known issue so they should fix it regardless. make sure to have them drive it a bit after they do the work, they mine back together out of time and i had to bring it back to them.
Strizzo is offline   Reply With Quote
 Old 03-29-2009, 07:58 AM   #5
ZMB
ZMB's Avatar
My powertrain was voided and they would not do the work under warrenty : ( they claimed $500 for the part and 8-10 hrs labor...fail...
Also for anyone wondering if they have this problem... The noise ONLY happens when starting the car and it will ONLY last for 2-3 seconds, so any other ticking noises while driving,stopping, or any other schenario isnt going to be this pin. Ill try to grab a sound clip so u guys can hear, its unmistakeable from any other noise coming from the car.
My mazda tech claimes that this will rob you of about 10-15 hp and lower your gas mileage.
Could there be any other more serious issues by having it broken?
 Old 03-28-2009, 02:43 PM   #6
mordxp's Avatar
mine is MS3 2008.5 with less then 10k miles on it, it says only about 2006-2007 models, is it possible to happen for 2008.5 ??
 Old 03-28-2009, 03:04 PM   #7
mordxp's Avatar
just want to add one more thong, it mostly happens when the car is cold( after the whole night), when I went to check it now couldnt hear anything bc car was still warm.
 Old 03-28-2009, 03:06 PM   #8
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
if your car is NOT in the range indicated by that TSB that TSB does not apply.
a built motor is not a built motor without being sleeved
fbpem1 is offline   Reply With Quote
 Old 03-28-2009, 03:18 PM   #9
ZMB
ZMB's Avatar
I don't see why it couldn't happen to a differnt year model, boosted3 and myself were comparing the noise and it sounds exactly the same and his car doesn't fall into the catagory if that TSB
 Old 03-28-2009, 03:21 PM   #10
mordxp's Avatar
the thing is that year of production does not apply but vin# does!
 Old 03-28-2009, 06:49 PM   #11
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
My car ticks like crazy, always has. Not just at start up.... All the time. I assume its normal since iys done it for 30k now !
TRU-BOOST is offline   Reply With Quote
 Old 03-28-2009, 09:16 PM   #12
javispeed3's Avatar
Posts: 7   (View Stats)
javispeed3 is an unknown quantity at this point
got the same thing.......when I drive the car hard I get that clicking noise ,then one day I sat in driveway looked in engine bay didn't see or hear anything unusual , got back in engaged the clutch and sound went away, haven't taken it to the dealer ,assuming it's a clutch or flywheel issue.........
javispeed3 is offline   Reply With Quote
 Old 03-29-2009, 08:14 AM   #13
mordxp's Avatar
Here you go guys, this is the exact same noise that comes out of my engine when is start up cold
The Following User Says Thank You to mordxp For This Useful Post:
ZMB (03-29-2009)
 Old 04-06-2009, 09:00 PM   #14
Zala's Avatar
Posts: 16   (View Stats)
Zala has a spectacular aura aboutZala has a spectacular aura aboutZala has a spectacular aura about
YouTube - MS3 VVT malfunction.
Hello all,
I know I don't post at all, but I thought I'd chime in on this one. I had this exact problem creep up on me about 1 1/2 weeks ago. I simply took it in and they verified that is was the variable valve actuator and fixed it up in one day. It was all covered through the warranty. I actually got a check engine light when I picked it up due to the timing being off. I had to take it back, but it got fixed up right away.
Zala is offline   Reply With Quote
 Old 03-29-2009, 08:20 AM   #15
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
Ugh that sounds nasty. Also, I still can't believe how much the engine in this car moves. Thank God for aftermarket motor mounts!
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 03-29-2009, 08:35 AM   #16
ZMB
ZMB's Avatar
Yep thats the noise, sad part is sometimes its worse lol...
 Old 03-29-2009, 08:39 AM   #17
TRU-BOOST's Avatar
I dont think they can just refuse a warranty repair like that. My understanding is that the law states they must be able toprove the damaged was caused by your mods. Considering there is a TEB and this is a known issue, your dealership is on some bullshit.
BTW i dont think mine does this. I will have to have someone else start it while i listen one day. My car is so damn loud its hard to tell ! I have one of the very first few built. I took delivery of mine in NOV 2006.
 Old 03-29-2009, 08:45 AM   #18
ZMB
ZMB's Avatar
Oh its so loud u can EASILY hear it inside the car, there really isnt a need to have someone start it for ya.
 Old 03-29-2009, 08:51 AM   #19
mordxp's Avatar
ZMB did you hear that noise every time you stared the car??
TRU-BOOST, you would hear it definitely form inside of the car and even with closed windows.
 Old 03-29-2009, 09:17 AM   #20
ZMB
ZMB's Avatar
At first no, but after about 2 weeks or so yeah, happens every time i start the car now...
Want me to PM you the part that ya need?
 Old 03-29-2009, 09:35 AM   #21
mordxp's Avatar
yeah that would be great
 Old 03-31-2009, 12:49 AM   #22
dirtyspeed3's Avatar
Posts: 78   (View Stats)
dirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond reputedirtyspeed3 has a reputation beyond repute
Groans: 35
You guys think that is bad you should have heard my 07 Spec V on cold starts. Sweet jesus that thing was loud and rattling The QR25 was about as smooth as a jackhammer lol.
dirtyspeed3 is offline   Reply With Quote
 Old 03-15-2010, 06:53 PM   #23
jellowood's Avatar
Posts: 85   (View Stats)
jellowood is a name known to alljellowood is a name known to alljellowood is a name known to alljellowood is a name known to alljellowood is a name known to alljellowood is a name known to all
I have ver similar sound on my new 2010. Can hear it from inside the car. I'll have to open the hood and compare the sound from the video
Jeff
2010 MS3 Velocity Red Mica w/Tech Pkg, Corksport SRI and turbo inlet
jellowood is offline   Reply With Quote
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 1 04-13-2012 09:13 PM
HKS Sound SgtP Mazdaspeed3/6 General Discussion 25 06-16-2011 06:23 AM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
eBay Find of the Day: Unusual Kawasaki-powered Sportcycle Haltech Automotive News 0 11-07-2008 03:50 PM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 0 07-10-2008 11:10 AM
Page generated in 0.41984 seconds with 30 queries
