 Old 02-22-2009, 06:02 AM   #1
Lvis's Avatar
Posts: 192   (View Stats)
Lvis is a splendid one to beholdLvis is a splendid one to beholdLvis is a splendid one to beholdLvis is a splendid one to beholdLvis is a splendid one to beholdLvis is a splendid one to beholdLvis is a splendid one to behold
Groaned at 19 Times in 2 Posts
Default weakest motor mount..? what mount takes a dump first?
basically if u were on a budget and wanted to get 1 motor mount replaced to better the performance what would it be? which 1 should be replaced?
Lvis is offline   Reply With Quote
 Old 02-22-2009, 06:16 AM   #2
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
i have broken all 3
rear first
trans second
passenger 3rd
fbpem1 is offline   Reply With Quote
 Old 02-22-2009, 06:21 AM   #3
Lvis's Avatar
Originally Posted by fbpem1 View Post
i have broken all 3
rear first
trans second
passenger 3rd
ouch .. im hoping that replacing 1 good motor mount will prolong the life of the other 2 good mounts
this will probably be the first mod cause its cheep
 Old 02-22-2009, 06:24 AM   #4
fbpem1's Avatar
no if anything it puts more stress on them haha, just buy all 3 theres some good deals going on from a few companies now. i will replace all 3 of my mismatched mounts with 3 of one company soon enough when they come out, 1 piece billet ftw
 Old 02-22-2009, 07:34 AM   #5
kingpin748's Avatar
Posts: 2,611   (View Stats)
kingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the world
Groans: 78
Groaned at 48 Times in 31 Posts
The rear MM is the one that usually goes. That's the most common one replaced and what I have done.
You can buy all three but it significantly increases cabin noise/vibration.
http://www.mazdaspeedforum.org/forum/foru...r-cp-e-mm.html
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 02-22-2009, 07:51 AM   #6
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Man i'm at 50,000 miles woth no break. I examined my tranny mount like laloosh said too and it looks perfect...
 Old 02-22-2009, 07:56 AM   #7
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
All you have is the inserts man?
That's all I've got for now.
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 02-22-2009, 11:33 AM   #8
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
rear mount is the one people normally replace first
 Old 02-22-2009, 12:37 PM   #9
bf360's Avatar
Posts: 2,069   (View Stats)
if you upgrade the rear prepare for the drive side to break, if i were you i would do the rear and driver at the same time, passenger should be alright
bf360 is offline   Reply With Quote
 Old 02-24-2009, 12:41 PM   #10
meatball84's Avatar
Posts: 17   (View Stats)
meatball84 is an unknown quantity at this point
i just did the corksport inserts on my rear mount. feels great now
CP-E Catted Downpipe, MAZDASPEED Cold Air Intake, RPCM Turbo Inlet, HKS SSQ Blow Off Valve
meatball84 is offline   Reply With Quote
 Old 02-28-2009, 10:36 PM   #11
darkstarmotorsports's Avatar
Posts: 882   (View Stats)
darkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the world
Groaned at 6 Times in 2 Posts
I would recommend getting all 3 done.
We have a deal right now for all 3 mounts for $255 shipped.
You weren't have to ever worry about a mount again with Medieval Motorsports mounts. The Passenger side mount alone is so built so strong, it'll last longer then the life of the car.
Also all Medieval mounts are backed by a LIFE TIME WARRANTY
darkstarmotorsports is offline   Reply With Quote
 Old 02-28-2009, 10:52 PM   #12
wassup61's Avatar
Posts: 1,232   (View Stats)
If you are looking for a long lasting cost effective solution look to the TRZ rear mount. It is bulletproof and keeps your motor from rocking like crazy. We can get one for a great deal and it will make a noticeable difference in your shifting, driving, and "spirited driving"
Best deal at PG as always,
-Jeff at PG
All wagon, No traction
 Old 03-01-2009, 12:15 AM   #13
medieval's Avatar
Posts: 213   (View Stats)
medieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the world
Also all Medieval mounts are backed by a LIFE WARRANTY
Dark Star is correct, We here at Medieval back our mounts for a life time. Doesn't matter if you used it on a burglar or if your dog ate it, it breaks, we replace it.
This is our rear mount for the Speed 3. All the stock motor mounts are weak by comparison. The rear and transmission seem to clock out first.
medieval is offline   Reply With Quote
The Following User Says Thank You to medieval For This Useful Post:
darkstarmotorsports (03-01-2009)
 Old 03-01-2009, 03:50 PM   #14
Independent528's Avatar
Posts: 7   (View Stats)
Independent528 is an unknown quantity at this point
i am looking into gettin an 09, but honestly how serious is this issue? have the majority of people on this forum experienced motor mounts breaking? is it somethin i should worry about when i end up buying the car?
Independent528 is offline   Reply With Quote
 Old 03-01-2009, 05:46 PM   #15
phillyb's Avatar
Groans: 1,940
srs? people break mounts. idk about rear mounts, but upgrading the rear mount is a good idea purely based upon how the car drives and shifts afterward...alone.
people break side mounts, here is my story - http://www.mazdaspeedforum.org/forum/foru...ount-bolt.html
it is only one of many who break mounts
 Old 03-01-2009, 06:12 PM   #16
kingpin748's Avatar
Groans: 78
Not everyone needs to replace all three mounts. Get the rear and see how it works out.
 Old 03-01-2009, 07:44 PM   #17
bf360's Avatar
ive broken 2 out of 3
 Old 03-01-2009, 08:19 PM   #18
ptperformance's Avatar
Posts: 4,123   (View Stats)
Get the solid rear mount listed here PT-Performance.com.
There is going to be vibes with any mount on the market. If your going to put up with vibes then you might as well as get something thats going to work. The PTP solid mount will not come apart, will not work loose, will not break and comes with a warranty (no idea how you would break it but maybe someone can impress me). There is a rubber isolator built into the rear mount already (motor side of the mount), so why have 2 contact points that have rubber in them. I have no idea but you might want to take a look at ours because there are no parts on it that could fail. This is just my .02 and if you look around you will find that most have all had a problem with there rear mounts. Thanks.
 Old 03-02-2009, 10:26 AM   #19
If you're not going to doing a lot of aggressive driving, and this car is going to be your DD. I would just get the rear mount, for a peace of mind over the stock mount.
Medieval has a nice peice, and you can't beat the price in these hard economical times.
Mazda 3/Mazdaspeed 3 Rear Motor Mount
 Old 03-02-2009, 11:03 AM   #20
k-speed's Avatar
Posts: 56   (View Stats)
k-speed is a jewel in the roughk-speed is a jewel in the roughk-speed is a jewel in the roughk-speed is a jewel in the rough
the rear mount is good for daily driving. TRZ has been good
k-speed is offline   Reply With Quote
 Old 03-02-2009, 11:05 AM   #21
The Medieval mount will provide less vibrations than the TRZ, so I highly recommend a Medieval for DD.
 Old 03-02-2009, 11:08 AM   #22
phillyb's Avatar
Groans: 1,940
VIBES FTW
 Old 03-02-2009, 11:12 AM   #23
wassup61's Avatar
The vibrations from the TRZ are negligible and I did not notice them at all. That being said, vibrations transferred to the cabin are directly related to bushing stiffness and deflection under load.
The Poly TRZ is relatively soft and provides excellent dampening of engine movement, going softer just sets up a Corksport insert situation where the mounts break in and then act as the stock mount, even if it is a dogbone style.
-Jeff at PG
 Old 03-02-2009, 12:01 PM   #24
All this filling is making me hungry. Get something solid, she will thank you later (LOL).
 Old 03-02-2009, 12:03 PM   #25
LMAO!!!!!
 Old 03-02-2009, 12:31 PM   #26
phillyb's Avatar
Groans: 1,940
lol indeed
 Old 03-02-2009, 01:19 PM   #27
Wide tire man
dbrier's Avatar
Posts: 957   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
So what is the "softest" aftermarket mount? I'll want the best one for DD and the occasional autocross.
The Corksport inserts sound like the least intrusive, but the reviews are mixed. Most like them, even in the long term, but a few think they "wear out".
I'm too old for a buzzy car.
2012 Crystal White Pearl Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs.
Too many wheels & tires to list.
dbrier is offline   Reply With Quote
 Old 03-02-2009, 01:44 PM   #28
wassup61's Avatar
The softest aftermarket mount was the CP-E "Old" mount with the blue 50 durometer bushing. They had problems with the hot pour method with their bushings tearing so they had to take it back to the drawing board.
The simple fact is that there is considerable axial torsion (flexion) put on the mount and any soft solutions will be just that, soft, allowing the motor to rock. The best solution out there by far is a polyurethane mount. The inserts will wear, rubber will tear, but the degredation of polyurethane is limited, it holds well, will not vibrate your coffee out of its cup, and is proven to be durable (prothane suspension bushings for example).
Solid mounts are out of the question based upon what you describe as your overall goal, so I wont even touch on delrin or billet.
Look into the TRZ poly mount, and I will set you up with a great deal on a PROVEN, long lasting, well balanced, warrantied product.
DO IT ONCE AND DO IT RIGHT
PM me or email me at msfprotegegarage@gmail.com
Thanks for listening/reading,
Jeff at PG
 Old 03-02-2009, 02:38 PM   #29
ThrillaSpeed3's Avatar
Posts: 278   (View Stats)
ThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the worldThrillaSpeed3 is the leader of the world
the trz rear mount is a charm. that is definitely the first one to work wit.
but as time goes on, u might feel the need to replace the others.
im at that point.
If u had a friend named Jack, and Jack was stuck on a MazdaSpeed 3.
Would u help Jack off the MazdaSpeed 3?
Lets say that I had a pocket full of fuck. And you wanted one.
I will say no, cause "I Don't Give A Fuck"
I'm gonna sow your asshole close, and keep feeding you,
and feeding you, and feeding you, and feeding you!
M.E.T.H.O.D :phillyb: MAN
"Good motherfucking choice, motherfucker! It'll get you drunk! You'll be fucking fat girls in no time!
You might even fight a nigga or two! Mm-mmm, bitch!" -Samuel Jackson Beer
ThrillaSpeed3 is offline   Reply With Quote
 Old 03-02-2009, 11:39 PM   #30
im at that point.
If a cusomer hasn't purcahse a mount yet, I would start off with the Medieval rear mount. You can't beat the $59 price tag with a LIFE TIME WARRANTY.
Then as you feel time is right, go ahead and upgrade to Medieval's other 3 mounts from there.
Medieval has had plenty of reviews with satified customers having all 3 of their mounts installed.
Just do a search for Medieval, and you'll see...
Mazdaspeed Forums - Search Forums
CP-E Motor Mount MazdaMan13 Custom Performance Engineering (cp-e.com) 2 11-07-2008 11:36 PM
Broken passenger mount...it took a dump literally..... Betelgeuse MazdaSpeed 3 - Engine, Transmission & Driveline 31 10-24-2008 06:33 PM
New CP-E motor mount fqspd3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 05-30-2008 02:15 PM
Page generated in 0.47784 seconds with 35 queries
