| MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
(Thread Starter) | Not Ranked : 0 score So, how long does it take to do that and remove the alternator? Any tips/info would be appreciated. I've heard it's not hard, but I've never done it, so I'm not sure what's involved. I didn't see any 'how tos' on it. BT install is this Sat. Thanks!
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() Join Date: Sep 2009 Location: Belmont, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 13 Times in 4 Posts
| Not Ranked : 0 score It super easy, all you need to do is locate the tensioner pulley, which is the pulley all the way aft on the car under the alt, and relieve the tension from it and take the belt off. I think it takes a 14 mm or something like that. The whole process took me about 15 minutes.
__________________ 09 mgm sp3 Cp-e hpfp, jbrone sstp, heavy weight knob, gutted midpipe, ets tmic, trz rmm, ht tune, cobb sir/tip. rx wheels with some fat meats |
| The Following User Says Thank You to mo4130 For This Useful Post: | dougefresh_ (05-24-2011) |
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |
(Thread Starter) | Not Ranked : 0 score I'm a dumbass... Here I am scouring the non-existent 'how to's' earlier, when I forgot I have a subscription to "AllData".... and it's gonna expire in a month to boot! So, alternator is a joke... 1 shield, 2 plugs, and 3 bolts. I'll def be yanking the serp belt and pulling the alternator. In case someone comes across this thread, and hasn't downloaded the WSM (like me bc it's afu): I just blew up the pic in PS, so the thumbnail should be bigger.
| The Following 4 Users Say Thank You to dougefresh_ For This Useful Post: |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score just curious, was it as easy as it looks? it seems pretty tight back there. |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score @dougefresh you need to go dl everything from alldata and well compile a compendium of catastrophic proportions !!
__________________ |
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
Also, removing belt and re-routing to put it back on is easy as pie, especially with a second set of hands, the belt tensioner all the way retracted and a VERY long flathead screwdriver. DON'T forget to unplug battery and the alternator before screwing with it. lol.
__________________ | |
| The Following 5 Users Say Thank You to p057 For This Useful Post: | Amnesiac (08-14-2014), Decepticon (11-12-2012), dougefresh_ (02-20-2012), jracer (02-25-2012), SLOWHATCH (02-20-2012) |
![]() Join Date: Mar 2011 Location: Nor Cal- Pittsburg
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
| Not Ranked : 0 score 12 x 1.5mm to -3AN. That is the thread pitch on for that oil feed line in the block. I suggest the XRP stuff. They are all I use. Jason
__________________ JRL Tuning 510-459-7229 www.full-race.com |
(Thread Starter) | Not Ranked : 0 score It wasn't that bad. We hadn't done it before, and it took like 20-30mins. We struggled with this giant plastic box thing that you have to open for a little bit. Iirc it has 3 tabs that need to be pried open at the same time.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] Last edited by dougefresh_; 02-20-2012 at 01:03 PM. |
| The Following User Says Thank You to dougefresh_ For This Useful Post: | p057 (02-20-2012) |
Groans: 220
| The Following User Says Thank You to p057 For This Useful Post: | dougefresh_ (02-20-2012) |
Groans: 105
| Not Ranked : 0 score that heatshield was a PITA, especially with my downpipe in the way. i never got it out, just had to work around it. took about an hour and some. |
![]() Join Date: Oct 2013 Location: Tallahassee, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 218
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Sorry to bring this thread back alive but I've got a problem. Had to drop the alternator to get to the bolts on my stock dp, in order to install the aftermarket one. Maybe didn't HAVE to but it seems to make the process easier and I figured "can't be that tough", so dropped the alternator and got the stock dp out. Now, trying to put it back on, all hell is breaking loose. The stock heat shield won't go in and keeps hitting the aftermarket downpipe, and the bolts to the alternator itself refuse to thread back into the block. If I try to force any of the bolts in, the alternator itself sits funny. Not really sure what to do. 12 hrs into the most frustrating dp install of all time and it being 5am, I called it quits and went to bed. Thoughts? Sent from my SCH-I535 using Tapatalk
__________________ JP Last edited by Jap11g; 02-26-2014 at 09:23 AM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
__________________ JP | |
| Not Ranked : 0 score Well. Bolt snapped in the block trying to install that devil alternator. Sent from my SCH-I535 using Tapatalk
![]() Join Date: Aug 2015 Location: Schaumburg, IL
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
I found a replacement plug, but the pigtail wire colors don't match the vehicle harness. Does anyone have a pinout of this connector that shows which wires go where?
| Not Ranked : 0 score You know, instead of facepalming - actual help would've been appreciated. That said, I was able to get a pinout from a friend with AllData. Attached for anyone with the same issue in the future.
| Not Ranked : 0 score good that you find it but the facepalm is either because you revived a 6 year old thread or because you pulled hard on the wires without unlocking it... If i remember right, the crank sensor is also on the same harness, just make sure you didn't damage along the others...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (02-08-2020) |
The crank sensor is on the same harness, you're right. I'll unhook it from there so I can get enough slack to solder the new connector in. The wires broke cleanly inside the alternator connector (right at the crimp terminals) so I'm sure the rest of the harness is fine. With as cheap and easy to come by as the replacement connector was, I'm guessing this is a common problem among Mitsubishi Electric alternators across multiple vehicle brands. As for reviving a 6 year old thread... I figured why make a new one when this is already on-topic?
![]() Join Date: Dec 2017 Location: Chico CA for school. Originally From the Bay Area
Rep Power: 27 ![]() Thanks: 15
| Not Ranked : 0 score I've had to pull my alternator twice, once because it was dead, and the second time because I had a massive mystery oil leak from that area. I pulled it and pretty much everything else on that corner of the engine, and then cleaned it all up. I didn't actually end up finding anything, so I threw it all back together and it never leaked again.
__________________ 2009 CWP GT MS3 Damond Motorsports RMM PMM and TMM Autotech HPFP Cobb SF Intake Cobb AP Autotech HPFP Corksport RSB+FSB Corksport Adjustable Short Throw Corksport Metal Skid Plate Koni FSD |
| Display Modes | |
| K04 oil feed line & oil drain line | NJSPEED3 | MazdaSpeed 3/6 - Turbo Induction | 12 | 09-14-2009 10:46 AM |
| anyone put a HO alternator on their ms3? | builthatch | MazdaSpeed 3/6 - Car Audio & Electronics | 40 | 01-10-2009 12:26 PM |
