 Old 04-17-2009, 12:25 PM   #1
Adam is so pro's Avatar
Posts: 410   (View Stats)
Adam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the world
Default WTF do I have to do to fix my RMM after PMM failure.
Took it off and put it back on and retorqued it. Still cocked. ISO ANWSER NAO.
Edit: Do I have to mess with the Allen bolts?
Adam is so pro is offline   Reply With Quote
 Old 04-18-2009, 04:46 AM   #2
buddhabum's Avatar
Posts: 254   (View Stats)
buddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond repute
What did you replace your PMM with? OEM?
'06 MS6 Black Mica
Street Unit Block, CP Pistons (9.0:1), Pauter Rods, CPBoost Top-mounted Turbo Exhaust Manifold w/ Tial 38mm External Wastegate, Custom 3", CP-E FCF (No Boost cut, 3.25" MAF), CP-E PnP Standback V2, CP-E HPFP, CP-E FMIC Core w/ Custom piping, Denso Spark Plugs, Custom Inlet w/ 3.25" MAF Housing, VCTS Delete, EGR Block-off, Saikou Michi OCC, Fidanza Flywheel, HD Signature 18x8" MSR Wheels, HTR Z III's 235/40/18, BS Delete, TWM Stage 2 SS Kit, Dashhawk, Perrin EBCS.
buddhabum is offline   Reply With Quote
 Old 04-18-2009, 08:23 PM   #3
wassup61's Avatar
Posts: 1,232   (View Stats)
It is possible that the passenger mount failure bent your subframe. Another possibility is that your transmission motor mount has dropped a little due to similar failure as the passenger mount.
Jeff at PG
All wagon, No traction
A GMAC failure could doom GM dealers Haltech Automotive News 0 12-14-2008 10:10 PM
Study: Automakers' failure would cost U.S. more than aid Haltech Automotive News 0 12-08-2008 02:00 PM
Oil prices fall 10% after bailout failure Haltech Automotive News 3 09-29-2008 04:35 PM
Nearly 300,000 HHRs to be recalled for latch failure Haltech Automotive News 0 09-09-2008 06:40 AM
Intel's G35 failure needs a fix Haltech Computers & Technology News 0 04-09-2008 02:20 PM
Page generated in 0.25231 seconds with 22 queries
