 Old 02-26-2014, 09:05 PM   #1
cocoleveo7686's Avatar
Posts: 238   (View Stats)
cocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to allcocoleveo7686 is a name known to all
Groaned at 34 Times in 21 Posts
Default bigger tip and intake?
I have a 06 ms6 with kn sri, cobb tip, test pipe, and tmic
I am getting internals soon but what size is the cobb tip? Whats the biggest tip for the ko4? Same with intake? Would I benefit getting a bigger one like maybe 10 more hp?
cocoleveo7686 is offline   Reply With Quote
The Following User Says NO Thank You to cocoleveo7686 For This Un-useful Post:
Agent_Orange (03-01-2014)
 Old 02-26-2014, 09:10 PM   #2
spdtrux's Avatar
Posts: 481   (View Stats)
Groaned at 9 Times in 6 Posts
Visit Cobb and JBR web sites for the info you seek.
Tip/SRI combos run from 2.5"- 4" w/ reducers to K04 and are silicon or metal
I just bought a HTP 3" in for sale section. For my K04 set up.
w/ bigger intakes you need to MAF CAL
99 JEEP WRANGLER SPORT
The Following User Says Thank You to spdtrux For This Useful Post:
stanley0910 (02-26-2014)
 Old 03-01-2014, 10:17 AM   #3
I contacted cobb but haven't gotten any response.
 Old 03-01-2014, 10:33 AM   #4
speed23's Avatar
Posts: 1,480   (View Stats)
A bigger tip doesnt help much if there is still at bottleneck at the intake. Either get a bigger intake and tip or just leave your setup as is. I bet a bigger tip only would give you like 1 hp...lol
 Old 03-01-2014, 10:48 AM   #5
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
I like the larger intake, HTP 3.0" definitely made the engine feel more responsive.
Just remember you'll need to scale the MAF sensor to install a larger than stock intake. You didn't list an Access Port? You need that to scale the MAF.
2008 Gen1 MS3
Self tuned on E85
 Old 03-01-2014, 10:51 AM   #6
Well thats why I was thinking of selling my cobb tip and k&n sri and buying a bigger setup but im not sure if the cobb is 3". Id like to get a 3" intake with a 3-3.5" tip
Yes sorry I do have an accessport already on a stage 1 map. Someone posted the difference between a 3" and. 3.5" Intake that gained 8whp. I think the k&n sri is 2.5" so there definitely has to be a difference. When I put a 3" on my vr6 gti vs a 2.5 the difference was noticeable
Last edited by cocoleveo7686; 03-01-2014 at 10:51 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-01-2014, 11:05 AM   #7
SKiZZ's Avatar
Posts: 288   (View Stats)
SKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond repute
HTP 3.5" Intake System + 51R Battery Tray Combo Kit (MS3) - Hi-Tuned Performance Products
There's your sign.
2013 CWP Mazdaspeed 3
SKiZZ is offline   Reply With Quote
 Old 03-02-2014, 08:59 AM   #8
Mistersix's Avatar
Posts: 2,585   (View Stats)
This^ You don't even need new hardware. You could find power in a custom tune over that OTS map. You can work with the hardware you have and make improvements threw the software.
I ran a 3.5 incher on my car for a few months just for the hell of it. After tuning it i found gains of 5-8hp at about 5k and about 3hp at 6k. They were consistent gains comparing logs on VD but i felt no difference while driving and 40-100mph times were about the same compared to the Cobb SF i was running.
So yes, in my experience there are small gains to be had with a bigger intake on the K04. Is worth the money? Not to me. I sold it to a fella going BT as he would be better served by it.
The Following 2 Users Say Thank You to Mistersix For This Useful Post:
ihasmazda (03-13-2014), speed23 (03-02-2014)
 Old 03-02-2014, 09:54 AM   #9
I am goin to get fuel pump internals before I go custom map. I personally don't wanna get a tune until all my mods are done. Maybe if I find an intake cheap enough ill get it
 Old 03-11-2014, 09:52 PM   #10
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
since you have a MS6, the BIGGEST TIP you can run with the OEM battery is a 3". And that will rub just a lil. You can modify your battery tray to prevent this. But there is NO difference power between a 2.5" or 3" TIP. Look at any TIP, it's just a funnel from the small 2" turbo inlet to the larger dia of the MAF.
As for a intake on the K04, you can run stock OEM MAF to a 4" MAF. its all about how you tune. I currently run a 3.75 intake on my K04 turbo. ANYTHING larger than the OEM 2.68" MAF will REQUIRED A change in tune.
redboat is offline   Reply With Quote
 Old 03-12-2014, 12:21 PM   #11
Thank you. What if I get the jbr 3.0 intake but for the gt series. Can I use a reducer to the stock k04, will there be enough room? Just incase I decide to go gt series?
 Old 03-12-2014, 05:46 PM   #12
redboat's Avatar
well it depends on the angle of the bend where the MAF housing is with relation to the location of your battery. But isn't the JBR 3" Intake silicone? I would suggest the HTP 3" since that is metal and you can swap out the couplers for diff size turbo inlets. Plus there's relocate the Valve cover vacuum port closer to the turbo inlet for better sucition.
Also consider just buying a HTP 3" or 2.5" TIP, and run a SRI that best fits your budget or current power goals. Since you don't have internals, a 2.5" TIP would be fine with an OEM size MAF SRI. Then move up to a 3" SRI once you get internals.
 Old 03-13-2014, 08:55 AM   #13
I have a cobb tip and k&n sri right now but I wanted to go full 3". The price on the jbr is pretty good. I would go 3.5 but dont wanna mess with battery tray. I have a d34 optima in there now
 Old 03-13-2014, 05:32 PM   #14
SKiZZ's Avatar
You don't need the tray on the 3.5. Warps the battery box a little but that's it might be different on a 6 though.
 Old 03-13-2014, 05:59 PM   #15
redboat's Avatar
You'll get the same gain from a 3.5" as a 3" on a K04 turbo.
Buy my SRI then....
http://www.mazdaspeedforum.org/forum/foru...filter-165155/
on a MS6, the largest TIP you can run is a 3"
Bigger Turbo on CX-7 speedcig CX-7 > Turbo Induction & ECU Tuning 35 12-05-2017 07:48 AM
Bigger intake/exhaust or new turbo? KevMS6 MazdaSpeed 3/6 - Turbo Induction 19 08-22-2013 11:40 PM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Bigger is better! Hectik1 MazdaSpeed 3/6 - Suspension & Brakes 13 07-01-2010 07:35 PM
Page generated in 0.37155 seconds with 26 queries
