 Old 02-22-2010, 05:13 AM   #1
johnnyspeed6's Avatar
Posts: 1,364   (View Stats)
johnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the world
Groaned at 16 Times in 14 Posts
Default Blue Smoke
I dont think its a big deal but im curious .. anyone had the following issues?
#1 Car was sitting an hour or so, started it ....... drove a few feet .. came to a stop sign....a good sized plume of blue smoke came out from under the car .. then went away.. nothing out of the tail pipes or anything after that... this was about a month ago .. never happened before.
#2 Went last night after work for a few beers .. car sat about 90 minutes...after that I started, pulled up to the ticket paying lady in the garage.... a plume of blue smoke came out from under the car again .. went away .. I drove off and nothing after that ... freakin strange.. I cant imagine what it is or why is does it.. any ideas ?
2008 HG Bullitt Mustang. Long Tube headers, SCT tuner,MGW short throw, FRPP hot rod cams high flow cats, charge motion plate delete
johnnyspeed6 is offline   Reply With Quote
 Old 03-03-2010, 03:35 AM   #2
Guess no one knows .. but yesterday was #3 ... went to walgreens ... only about 1 miles from the crib .. idled in to the lot swung around to park and boom .. plume of blue smoke comes from under the car and floats off ... strange ..
 Old 03-03-2010, 03:51 AM   #3
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
SMURF GENIES!
so wait is this coming from the exhaust? or directly under the car?
Current Fail:
The Following User Says Thank You to MATT DAMOND For This Useful Post:
98zjdave (03-03-2010)
 Old 03-03-2010, 02:42 PM   #4
Originally Posted by MATT DAMOND View Post
SMURF GENIES!
Everytime I see the smoke it blows from the back to the front ... But I cant really say if its directly under or from exhaust .. I never notice it until it blows by me .. which I why I think it is coming from under the car ... and I always look out the back when im driving but there is nothing there .. really strange
 Old 03-03-2010, 02:48 PM   #5
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
hows your oil level? change the oil recently? (maybe spilled a bit somewhere that gets hot). I know a buddy of mine with a test pipe gets a nice puff every once in a while when pushing it hard
 Old 03-03-2010, 02:49 PM   #6
Rhino's Avatar
Posts: 29   (View Stats)
Rhino is a jewel in the roughRhino is a jewel in the roughRhino is a jewel in the rough
When I had a smoking turbo I never notice when driving, only when idling for a long period of time or on initial startup, and not until it was blown back into my field of view. But it was coming from my exhaust.
I think it's time for you to run the bad turbo oil seal test. Start you car and leave it parked, let it idle for up to 5 minutes, and you will find out if it's coming from your exhaust tips. Mine started going James Bond smoke screen style under those conditions. At the very least it will help with the process of elimination.
06 Speed6
Rhino is offline   Reply With Quote
 Old 03-04-2010, 03:50 AM   #7
To the OP .. my oil level is fine and im on 2k since last change .. So that cant be it... But ill do the 5 minute idle and see if I get the smoke .... and it is like the OP described,, just every once in a while it would show up when it was blown into your line of sight .. will report back findings.
 Old 03-04-2010, 08:21 PM   #8
laocas01's Avatar
Posts: 307   (View Stats)
laocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the worldlaocas01 is the leader of the world
im having a similar problem (check thread "yet ANOTHER problem") and i got a leak-down test done to my car to find out that pistons 2 has a 16% leak and 3 has a 13% leak so my piston rings are bad. its not too expensive to do the test, i was charged $68 and it took like 30-45 mins. maybe you wanna look into that
laocas01 is offline   Reply With Quote
 Old 03-04-2010, 08:25 PM   #9
BoostedBlack6's Avatar
Posts: 261   (View Stats)
BoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond repute
Switch to 5w40 and you will be fine. Thats what I did and mine was smoking horribly.
2006 Black Mica MS6: Cobb AP, Stage 2 v105 93, MSD Dashhawk, Speedie6 TIP, CPe Nano SRI, HKS SSQV, Custom FMIC, Custom 3" Single Exhaust w/ Dynomax Race Muffler, H&R Sport Springs, SPC Adjustable Balljoints, TWM Stage 2 Short Shifter w/ SU bushings, 18" Drag DR-34s
BoostedBlack6 is offline   Reply With Quote
 Old 03-04-2010, 08:31 PM   #10
yearzero's Avatar
Posts: 439   (View Stats)
yearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the world
just sell a kidney and go big turbo.
yearzero is offline   Reply With Quote
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
No more Turbo Smoke Addikted To Boost MazdaSpeed 6 - Engine, Transmission & Driveline 12 07-27-2009 06:38 AM
Blue Exhaust Smoke JCMS07 MazdaSpeed 3 - Engine, Transmission & Driveline 16 12-02-2008 11:56 PM
Page generated in 0.30400 seconds with 26 queries
