 Old 04-02-2019, 05:56 PM   #1
Izapyou's Avatar
Posts: 41   (View Stats)
Izapyou has a spectacular aura aboutIzapyou has a spectacular aura about
Default Both Rear New Axle Seals Leaking HELP!
I don't understand what is happening. I replaced the axle seals on the differential when I replaced the axles. I bought the axle seals from the dealer. I was very careful not to nip the seals when installing the axles. You can't really install these wrong. I felt the seals seat when I carefully installed them. The old ones were very hard to get out btw. I think I overfilled the differential and that's what is coming out through the seals maybe? The leak is super slow and light. Any advice would be great, don't want to mess up the differential.
Izapyou is offline   Reply With Quote
 Old 04-05-2019, 02:33 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Speed 3 or speed 6? If 6, rear or front?
 Old 04-05-2019, 06:48 PM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Hmm...
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 04-05-2019, 06:48 PM   #4
Fstrnyou's Avatar
Neutral  :  -1 score
Double post
Other rides:
History:
 Old 04-06-2019, 11:12 AM   #5
Izapyou's Avatar
Speed 6 rear axle seals
 Old 04-10-2019, 12:34 PM   #6
memin's Avatar
Posts: 994   (View Stats)
I have the same issue, right rear axle seal is leaking .Do you have the part # for the seals??
 Old 04-10-2019, 01:26 PM   #7
Izapyou's Avatar
I don't but I know that that seal works for multiple cars talk to mazda and ask them what it fits and go to the parts store and get then cheaper and I had the dealer redo the seals under warranty and seem to be fine idk what the fuck happened but we are good to go
Question will leaking injector seals cause low comp stariondriver MazdaSpeed 6 - Engine, Transmission & Driveline 6 10-12-2018 01:39 PM
Leaking Rear diff axle seal BigjohnB20 MazdaSpeed 6 - Engine, Transmission & Driveline 14 07-01-2017 07:16 PM
Leaking front axle Bob-o MazdaSpeed 3 - Engine, Transmission & Driveline 22 04-29-2014 04:28 PM
Mechanic says axle housing bearing is leaking? steevieg Gen2 MS3 General Discussion 8 04-13-2014 08:31 PM
rear end leaking Sal's_MS6 MazdaSpeed 6 - Engine, Transmission & Driveline 9 05-07-2011 08:12 AM
Page generated in 0.26774 seconds with 24 queries
