![]() Join Date: Jun 2012 Location: Sanford, FL
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Nov 2015 Location: Flint and Livonia MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score I have yet to build, or break in a turbo'd motor but if its anything like N/A stuff you want to avoid stress and revs. And for that matter, vacuum is beneficial when seating rings. (it draws oil past the rings and helps lubricate the process). I know that with old flat tappet cams there is a very specific way to "run them in" to avoid wiping the lobes. If one were to replace cams (and therefore "lifters"?), would they have to follow a similar process? for reference, it usually entails holding the engine between 3-3500 rpm for 20 min, varying the rpm slightly over that interval.
__________________ 2007 MS3 True Red HKS BOV-K&N CAI-APV3-CS TMIC CS Short Throw-Whiteline Bushings-CS Rear Bar 1968 Mustang Built 289 w/ factory heads Built C4 Bulit 8" posi Runs low 14's at 100 flat |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score Lots of engine decel, frequent oil changes, and do not be "easy" on it. I'd avoid boost for the first 50 miles or so (but do almost N/A wot pulls). Vary the rpm a bunch and you will be in business. Everyone has their preference... I know @phate; boosted in the first 5 miles LOL.
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | 5doorsoffury (01-26-2017) |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
__________________ 3rd rebuild on the way...maybe... | |
I am. I got the tools I'm just in the final parts of the machining. Head being done and the internals balanced. I did my research and they are the only ones I could find that make the 4032 piston aftermarket. I needed it 88 mm too so. | |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score It wasn't a built motor but when i got my car new i broke the motor in with varying rpms and moderate boost with a lot of engine breaking. I did a lot of dino oil changes before synthetic got used. A built motor just means a looser tolerance in things like the rings ect... I always thought it was about heat cycling not too hot and engine brakeing to cool things down.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following User Says Thank You to 5doorsoffury For This Useful Post: | razerer (01-27-2017) |
![]() Join Date: Dec 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 14 Times in 6 Posts
| Not Ranked : 0 score So what's recommended? Soft break in or hard break in ? Sent from my iPhone using Tapatalk
__________________ Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate- |
Call me dumb if I'm wrong but I'm not using the 2618 pistons which have the looser tolerances. I have the 4032 it can run the tighter tolerances because it's the stock piston material. And heat cycling is when your on the dyno. I'll be breaking in on the street. But I'm not sure. I'm going to break it in hard. I wasn't sure about boost. I was thinking like 8 - 10 psi the most but wasn't sure about it so I asked. Sent from my iPhone using Tapatalk
__________________ 06 MS6- Cobb SRI, TIP, SURE TMM, V1 SU RMM, Forge V1 BPV(Previous Owner installed) Built motor - SP63 4032 pistons 88mm, Manley H-beam rods, King AL main bearings, King tri-metal rod bearings. Future looking - HPFP internals.. YES i know , cobb ap, CS turbo and dp. | |
| Not Ranked : 0 score soft, no boost
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score A) ask your engine builder they will know the best way for you to break in your motor B) You should do N/A like WOT pulls like mentioned (0.00 as measured on the vac/boost gauge). Minimal boost for first 50-100 miles. C) TONS OF VARYING RPM'S AND ENGINE BRAKING D) As mentioned don't baby it, once that 50-100 miles is down and you get the oil changed, start ramping up boost a bit (I just went full out at that point with the new stocker). Heck I didn't mind boosting slightly in that period either 5PSI and under babying it will sometimes cause issues with seating the rings (most important to do within the first 50miles). I've done my stock new motor this way and I'm getting perfect compression, been running 20psi with E85 for the last 15,000 miles out of 20k on the motor and it hasn't missed a beat.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score Hard break in. @JgamB; barely made it 2 miles before he went WOT (okay, maybe it was 10 miles). He had a WGDC base-map ready to go before 50 miles or so and has been driving his engine hard ever since. ~550whp for a while now and no issues at all.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
![]() Join Date: Mar 2014 Location: Barre, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 344
| Not Ranked : 0 score Never broken in a boosted engine but all of the N/A engine have been done by varying RPM, engine braking, being easy in the first 50 miles like said, then after that high load which builds higher cylinder pressures and forces the rings to set quickly.
__________________ 2015 Mazda 3-slow 99 Brilliant Black Miata- slow too |
Groans: 111
| Not Ranked : 0 score Start the car after the rebuild, fill with break-in oil, fill with coolant, burp the system, go for a 10-30 miles drive, change the oil also with break-in oil, drive the car normally with no more than 50% throttle, change the oil after another 200-250 miles but fill only half with break-in oil and half with normal oil, and slowly start getting into it. My built engines started to see above 20-22PSI of boost about 400 miles after the rebuild, but until then they saw a lot of downshifting and decels from 5000-5500rpm down. The seating of the rings depends on this vacuum in the cylinders which pulls them in the other direction and helps them wear and seat properly. That's also the reason why both hard or soft break-in procedures are successful when done properly: boost, then hard decel, so the rings seat for the hard break-in, long but softer decels for soft break-in. With my second engine I went through a semi-soft break-in, meaning that with that first oil fill which I kept in the engine for about 20 minutes/10 miles I was slowly accelerating in 2nd gear up to like 5000rpm and was letting the car decel from there in the same gear. Then with the next oil fill I boosted up to about 10-12PSI (so harder acceleration, in higher gears including 6th as I was on some sort of highway and could not use 2nd gear) and continued these acceleration-deceleration alternations. Now I'm at about 700 miles in the 2nd engine and I started to throw 28-30PSI at it. One thing against the hard break-in is that some part is not perfectly seated (a bearing, a ring, whatever) and it needs a bit more to wear in, it can overheat or even snap. Jay from Real Str. Performance leans more towards soft break in.
| The Following 2 Users Say Thank You to mituc For This Useful Post: | SPEEDingTicket (01-28-2017), TMOtester (04-01-2019) |
(Thread Starter) | Not Ranked : 0 score ok. update time!! and another question i got the engine installed, running and with no leaks (yay no leaks) however upon driving it around to break engine in, i noticed my temperature gauge was saying its running hotter than stock. it almost went to the H. i coasted down a hill and able to drive it home. on the way back, the temperature gauge dropped back to normal operating temperature range (middle of gauge). even gave it one last little N/A pull and it didnt move. is it normal for a new engine to run hotter at the beginning or could a faulty thermostat cause this. i live in fl where it never gets colder than like 50 normal (20s sometimes during our "winter") and thinking of pulling thermostat out and have it coolant free flowing through the engine continuously. |
| Not Ranked : 0 score How much coolant did you actually put in the system? If you didn't put in almost 2 whole gallons, you've got to let the coolant burp through the system. Keep adding in more coolant and heat cycling the engine (don't let it get above ~230) until you've got 2 gallons in the system.
(Thread Starter) | Not Ranked : 0 score I've got about two in there. Some came out through leaks so I bought a third bottle and a quart of that is gone too. Idk what the temp went to but if it went any closer, I would have shut the engine off immediately. I'll check it when I get home again Sent from my iPhone using Tapatalk
![]() Join Date: Jul 2016 Location: Outside of york, pa(dallastown)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Quick question on these break in processes, @mituc on your directions for the soft break in process it says a 10-30 miles drive. So that a 10 to 30 Mile drive? Then it says to change the oil again with breakin oil again, driving ng it normally with no more then 50% throttle, then do the oil again. Well during that period of 50% throttle driving, should you introduce any boost or keep it minimal like 1 or 2 psi ya know basically na pulls, and you don't state anything during that period to be downshifting with lots of decel and engine braking, Im assuming that when you say normal driving during that period of breakin your including those characteristics, am I correct?
__________________ 2007 Mazda Speed6 GT Power: rebuilt stock motor* JBR full power path stage II intake w/JBR TIP* ATP catted downpipe w/ second cat delete* Corksport HPFP internals* Corksport BeCuse injector seals* Corksport Turbo* Corksport 3.5 Bar MAP sensor* Corksport EBCS* Treadstone Tr8 w/ RPM CX racing piping kit* Suspension: Corksport Lowering Springs Brakes: Still stock Driveline: Sure Motorsports R6* Sure Motorsports Juggernaut* Sure Motorsports Dreadnaught* Sure Motorsports shifter bushings* Corksport weighted Black shift knob Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning* |
Groans: 111
The idea is for the break-in oil to do its initial thing on the piston rings and also incorporate all the lubricants used in the build process, as well as carrying away from the engine any metallic debris naturally resulted in the break-in (that fine metallic powder from the rings will end up in the oil filter). In this stage you only need these 2000-3000rpm to maintain oil pressure and to complete a certain amount of engine cycles to ensure the proper initial break-in and clean-up. Engine braking is recommended in this stage, just don't use high revs. Letting the engine rev down from 3000-3500rpm to 2000-ish. Ideally this stage should be completed on a less busy road so that you can accelerate slowly out of boost up to 3000-ish and then just let off the acceleration until the engine goes down to 2000, and then accelerate again.
You should do engine-braking in this stage as much or more than you boost to 4-5-6PSI. Downshift whenever you have the occasion and let the engine rev down naturally from 4000-4500rpm, this will help the rings seat and even out. Imagine the driving style in this stage as some kind of a spirited driving but also fearing a speed ticket: don't give it too much, but not too little either. With all the engines I helped building so far (two of mine, two of my friends) in this second stage we used a 50/50 blend of break-in oil (AMS Oil SAE-30 Break-in oil) and some decent engine oil that we could get from the shelf of a store or from the shop (Mobil 1 0w40, the Mazda Original Dexelia Ultra 5w30, and so on). Yes, we mixed semi-synthetics with a lot of zinc additives with a semi or full synthetic, but as long as you have the break-in oil there you're good. In your case will be easier to find some semi-synthetic or even better some dino oil there (the semi-synthetics we get here have too many additives anyway). The idea of the blend is to offer the motor a bit of protection but not too much protection, and also promote the continuation of the break-in process. Diluting the break-in oil will also reduce the overall content of zinc which is necessary if the car still has one or two cats on (and ours all do). This stage can continue for up to 1000 miles and a few days. Avoid short trips with the car in this interval. After this stage use whatever oil you want just make sure it's not ester synthetic (redline, royal purple, motul ester, millers, and so on), but some synthetic oil. Add a quart of break-in oil to that and you will be good for the next 1500-2000 miles before you go with your favourite oil.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI Last edited by mituc; 02-07-2018 at 02:24 AM. | ||
| Not Ranked : 0 score Not sure where ya think I'm located, on the moon, lol, but I can get just about all oils available. I have Lucas, amsoil, motul, penosin, shell, Brad Penn breaking oil, anyways lots of oils, so any particulars let me know something I should look for or nah. I think I grasp most of what ya through out there which I really appreciate the info man. The one thing I didn't see was in these intervals when should I be dropping the oil for change each time, coz I know the first few hundred I thought have a few changes in them
Groans: 111
I had a pretty hard time finding some good break-in oil with more Zinc in it. I has basically 3 choices:
For the first engine I build I used the redline break-in in the second stage (for the 1st stage of the break-in, that 20-ish mile first drive,I managed to source some Millers GRO) and then it vanished from all on-line stores in Europe. For the rest of the builds we actually exhausted the stocks of AMSOil SAE-30 of a known on-line store here because we bought like 10 quarts each time, 6 to use for the first stage of the break-in and 4 to blend later (3 quarts for the 2nd stage with 50/50 blend, one more quart for the longer oil change after 1500-2000 miles). So this was our story, yours should be less bumpy
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() Join Date: Sep 2017
| Not Ranked : 0 score What oil is everyone using for the break in process in a built engine |
![]() Join Date: May 2012 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groans: 43
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score When I built my motor 700 miles ago. I used 2618 drove it 20 miles with up to 20psi with lots of varying rpm decel changed the oil drove 150 with short single gear wot pulls 26 psi and long decel changed oil now just driving it normal have gone to mexico since. This was all done from the start with e35 and meth map Running good... SO FAR hahaha
__________________ 2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck ![]() E35 meth d012 26psi ![]() 420/451 self tuned/built |
| Not Ranked : 0 score What oils did you use and are currently useing |
![]() | | #24 | ![]() |
| Not Ranked : 0 score I was thinking about using Amsoil Z-Rod.
![]() | | #25 | ![]() |
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score how bout using a good dyno oil line Castol or Penzoil and such with a zinc additive? I use Lucas Zinc additive in my Javelin because i have to with a flat tappet cam but wondering what peoples thoughts were about it in these cars. I will be running a CS catted downpipe.
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Amsoil Z-Rod is specifically designed for older engines with flat tappet cams. The "Z" is for Zinc.
![]() | | #27 | ![]() |
Groans: 111
Then I started using Motul ester sport 5w50 and redline 5w50.
![]() | | #28 | ![]() |
I am going to be running a CS catted DP and I am more then willing to run zinc for the initial break in if its not going to wipe out the sensors and catalyst. Trying to be as legal as I can for the state...
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 | |
![]() | | #29 | ![]() |
Groans: 111
So for the first few hundred miles you can run some break-in oil with high zinc content, but not after that. The zinc will affect the cats after a relatively long time (think 10k+ miles), so if you run it for the first 200-500 miles you will be perfectly fine. On the other hand taking your engine builder advice is always a good idea. There are several right ways to break-in an engine so even if the general consensus here is slightly different doesn't necessarily mean someone is not right.
![]() | | #30 | ![]() |
| Not Ranked : 0 score The engine builder that I went to is a family friend who really only likes to work on old American v8s. witch isn't a bad thing, he did a fantastic job on multiple AMC engines and a chevy engine for me and my father threw out the years. Being his expertise is not in half breed turbocharged 4 cylinders, the deal that we made was for him to do the machine work and for me to assemble it witch I did. When breaking in my AMC 360, he told me to lug the engine down and don't horse it around for 1000 miles, then change the oil and give it hell. I know this cant be done with MZR's, seems like the idea that I have from reading some posts is to fire it up run it for 50-100 miles with no to minimal boost with a bunch of decal factored in, then my plan was to change the oil then slowly start to throw boost at it from when I decide to change it to about 500 ish miles, another oil change then let it have it.. right or wrong the thing shouldn't grenade again. plan on going threw FREEKTUNE so I know the base map will be safe and tuning will be proper.
| Newly Rebuilt Engine Running Poorly | C3xauto | CX-7 > Engine, Transmission & Driveline | 9 | 08-03-2016 06:28 PM |
| Overheating of newly rebuilt engine | EmPeEs6 | MazdaSpeed 3/6 - ECU Computer Tuning | 56 | 08-22-2015 05:07 PM |
| Advice for purchasing MS6 2006 rebuilt engine | kevinrussell15 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 01-21-2015 10:58 AM |
| Engine rebuilt - noise and KR | mrQQ | Mazdaspeed3/6 General Discussion | 54 | 06-29-2014 05:51 AM |
| Need Help! Rpm drops to 0 during engine breaking then dies | xdm88 | Mazdaspeed3/6 General Discussion | 36 | 08-23-2011 12:23 PM |
