  • 1 Post By lowtone20hz
 Old 12-03-2019, 12:38 PM   #1
lowtone20hz's Avatar
Posts: 3   (View Stats)
lowtone20hz is an unknown quantity at this point
Default Cylinder Head Bolts
I recently had to remove the head and get it cleaned up, serviced, etc. When reinstalling the head, am I able to reuse the stock head bolts? The shop manual doesn't mark them as replace and it has a section on page 01-10-27 about bolt inspection. Am I correct that I can reuse the bolts as long as they are within spec? Thanks.
lowtone20hz is offline   Reply With Quote
 Old 12-03-2019, 02:38 PM   #2
Police - Grammarhead
Vansquish's Avatar
No. The head studs are torque-to-yield devices. If the proper torquing procedures is followed during installation, the studs will stretch. While you *could* reuse them, I think it would be fair to say that most people on the forum would recommend replacing them.
 Old 12-03-2019, 03:28 PM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Yeah them bolts are a one time use dealio, so just buy new Mazda OEMs.
Stockish
Db09ms3 is online now   Reply With Quote
 Old 12-06-2019, 04:50 PM   #4
Ok, thanks for clearing up the confusion. I went ahead and got some.
Db09ms3 likes this.
 Old 12-09-2019, 10:12 AM   #5
Posts: 2,233   (View Stats)
new bolts are cheaper than doing the job again....
Jeff23spl is online now   Reply With Quote
Head Bolts jaguar_mike CX-7 > Engine, Transmission & Driveline 10 02-10-2016 03:18 PM
Oem Head Bolts rusharp MazdaSpeed 6 - Engine, Transmission & Driveline 13 02-07-2016 09:36 AM
How much will stock head bolts hold... mOBSCENE MazdaSpeed 3 - Engine, Transmission & Driveline 20 04-23-2015 03:29 PM
MS3 Cylinder head bolts(Ebay) joey Mazdaspeed3/6 General Discussion 12 09-22-2014 07:48 AM
Page generated in 0.25305 seconds with 23 queries
