 Old 06-13-2010, 04:21 AM   #1
Matx's Avatar
Posts: 1,681   (View Stats)
Matx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the world
Default Downpipes
Ok Iam looking to get one soon and Iam unsure what one to get, any info on the diff. ones and advice on which one to buy would help lots. Thanks
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
Originally Posted by backward_0 View Post
.... I will be more than happy to fuck your world off....
Matx is offline   Reply With Quote
 Old 06-13-2010, 04:31 AM   #2
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Get the CPE...it goes turbo to catback
 Old 06-13-2010, 10:10 AM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
For the ms6, the only dp that I know of that uses a test pipe is the Corksport. Everyting else goes from the turbo to the cat back.
I am currently running a ATP catless dp which I have been running for about 60k miles, it is a solid basic catless dp.
I am replacing it with a Xtremeboost catless dp which I had customized and 2200* ceramic coated. I liked that he could literally add anything to it that I wanted, and I liked that the flex section is about as close to the turbo as it can get. I am hoping that the higher flex section will maybe help with some exhaust rattle that I have been having issues with.
Catless downpipes tend to be a little bit louder than a catted version and they can make a popping noise from fuel combusting in the exhaust system between shifts and on decel. The actual tone of the exhaust is mostly controled by the catback exhaust.
2006 Mazdaspeed 6
 Old 06-13-2010, 10:27 AM   #4
Matx's Avatar
What do you guys think of Protege Garage - Ultimate Exhaust Upgrade
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
 Old 06-13-2010, 10:44 AM   #5
Speeeeeed
06Speed6's Avatar
Its not a bad system if that is what you want to know. For the money its hard to beat.
2006 Mazdaspeed 6
 Old 06-13-2010, 10:46 AM   #6
Matx's Avatar
wondering if its worth the money or should I just get the DP
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
 Old 06-13-2010, 03:00 PM   #7
Speeeeeed
06Speed6's Avatar
Exhaust manifolds are worth the extra power, but they can sometimes be a pain to install because you have to take so much more stuff off to get the old one out so the increase in wrench time is fairly big.
2006 Mazdaspeed 6
 Old 06-13-2010, 03:10 PM   #8
ptperformance's Avatar
Posts: 4,123   (View Stats)
We have catted and non catted DP's listed on the site. Full stainless steel from flange to flange.
Ours are difficult to install but very much worth the money for the power gains.
Last edited by ptperformance; 06-13-2010 at 03:10 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-13-2010, 07:38 PM   #9
Matx's Avatar
You got a link t the DP on your site looked and dident see it.
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
Downpipes, which one should I get? julioroman 2010 MS3 - Turbo Induction 16 05-13-2010 04:21 PM
Downpipes dkspeed MazdaSpeed 3 - Engine, Transmission & Driveline 50 02-26-2010 06:25 PM
downpipes pvms3g MazdaSpeed 3 - Engine, Transmission & Driveline 12 05-21-2009 01:04 PM
CPE downpipes phailerider Custom Performance Engineering (cp-e.com) 27 11-25-2008 10:58 AM
Page generated in 0.30129 seconds with 23 queries
